RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
Traxxas Nitro Rustler Steering Problem
Reply
Old 10-12-2004, 04:10 PM
Iceman1032
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Traxxas Nitro Rustler Steering Problem
On my Rustler I can steer to the right but when I turn left it does not do anything. On the Controller I turn the steering knob all the way to the left and then it works just fine, I can steer both left and right. But when the steering knob is right in the middle I can only steer to the right. Any suggestions. Nothing is bent up front all parts are in working condition, just a wierd flaw of some kind. PLEASE HELP!!!!!!
Iceman1032 is offline
Old 10-12-2004, 04:21 PM
Unbreakable207
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Traxxas Nitro Rustler Steering Problem
WOW! very weird indeed.
Umm... try trimming it to the point where it does work and then take out the steering saver and adjust it to be lined up.
Unbreakable207 is offline
Old 10-12-2004, 04:22 PM
AddictedtoRC
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Can you explain that again
AddictedtoRC is offline
Old 10-12-2004, 04:52 PM
redheat8
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Are you sure that your servo is centered? RED
redheat8 is offline
Old 10-12-2004, 05:47 PM
Iceman1032
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have taken the rustler to hobbytown usa and they say everything is fine on it, they have tried replacing certain parts that may affect the steering but everything seems to be fine. As of right now they have called traxxas to see if they know what could be the problem with the steering. the problem is that the rustler will not turn left and can only turn right. On the contoller if you turn the knob all the way to the left then steering is all ok, you can turn left and right. But when the knob is centered, lined up with the red line, you can only turn the rustler to the right it will not turn to the left.
Old 10-12-2004, 06:05 PM
Government_Man
Government_Man's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I would switch the linkages from the reciever to the servos so the turning does the throttle servo and see if your transmitter is broken (unless you've tried that, you can never be too sure.) That might mess up your reciever or servos, so don't try it if somebody yells at me. You could check your crystal and see if the plugs or whatever are messed up also.
Government_Man is offline
Old 10-12-2004, 06:18 PM
dalosiman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Have you hit anything with it? If so you may have stripped a gear in the servo. Been there and done that which is why I run only metal gear servos now.
dalosiman is offline
Old 10-12-2004, 07:04 PM
Nitro Rustler Racer
Nitro Rustler Racer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
had that problem, got a new radio everytin started to work fine.
Nitro Rustler Racer is offline
Old 10-12-2004, 08:22 PM
NITRO 888
NITRO 888's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sounds like a bum servo to me .
NITRO 888 is offline
Old 10-24-2004, 04:20 PM
Kondore
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
HEY MAN...I KNO UR PROB..I HAVE HAD IT BEFORE...MY DAD SHOWED ME THE SOLUTION. (1) TURN UR CONTROLER AND CAR AND PUT STEER CENTER TO THE CENTER. (2) TURN UR CAR OFF AND THEN UR CONTROLER(THIS IS IMPORTNANT). MAKE SURE UR TIRES ARE STRAIGHT. DISCONECT THE PART ON THE SERVER THAT MAKES TIRES TURN WITHOUT TURNING THE THE TIRES. REPLACE THE PART..I THINK THATLL FIX IT...IF ITS CONFUSING..I MIGHT SEND U PICS OR JUNK. PEACE
Kondore is offline
Old 10-24-2004, 04:22 PM
Kondore
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
eMAIL ME AT devfrut@yahoo.com if u got probs on the nitro rustler or anything else..i might be able to help.
Kondore is offline
Old 10-24-2004, 04:24 PM
Nitro Rustler Racer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
belive me i had those problems for 3 years until i took that radio and through it into my junk box and ordered a new system from futaba
Contact Us Archive Advertising Cookie Policy
