how does a nitro engine stay running????
WI
i was wondering when u start ur truck and u take the glow plug igniter off how does its ignite the feul??
i was thinking of this during math...lol
Ryan
Ryan
RE: how does a nitro engine stay running????
Diesel engines aren't like nitro's. They ignite their fuel purely from heat generated by compression. Some of them do have glow plugs, but they're only used to heat the engine to help with cold starting.
In a nitro, the element of the glow plug holds heat after combustion, and that ignites the fuel in the next cycle. Remember, even when a glow engine is idling, combustion occurs several times per second, so it isn't having to hold that heat for very long.
A couple of things actually.
1. the glow fuel engine is a "semi-diesel" meaning that some of the ignition energy comes from the heat of compression
2. the kicker is the glow plug element, the alloy metals in the element wire cause a catalytic reaction with methanol (the primary ingredient in glow fuel), the main byproduct of this reaction is heat, enough when combined with the heat of compression will ignite the air fuel mixture.
Does that help?
Does that help?
NH
i have seen engines on ebay for planes that run on desil and they look the same as a nitro motor. Wonder what would happen if you put desil in a nitro engine. I know that my trx 2.5 will run on wd 40 for a short time.
ORIGINAL: ncgrunt
Hrm, hadn't heard that before. Learn something every day
What dya expect from The Fuelman, lol.
ND
do a search on here or google for 'davis diesel'
