-Official Traxxas JATO Thread-
#3151
TN
RE: -Official Traxxas JATO Thread-
learned a lesson today, installed new gpm frame on jato looks killer a lot stronger ,started running ,tuning get temp up 225 make a couple passes check temp, temp gun showed hi i freak out because i thought it went to 300 f but after looking it went only to 230f had more power than i ever had, i de tuned it before i realize it was only 240 degrees f so get a good temp gun that goes high enough
#3153
As far as fuel it really depends on the brand in my opinion. I was running the crappy 33% nitro from traxxas in my Jato and I switched to 30% nitro from Maxys Fuels and boy did my motor wake up. 30% will not hurt the motor and you will increase your performance a little. Just make sure to retune.
#3154
TN
i used to run traxxas ,trintywas not to bad,sidewinder about the same as trinty, i now run odonnells it reminds me of being at the track when the top fuel nitro run smells just like it burns the eyes but wakes up my motor
#3155
TN
just ordered the motor saver air filter and filter oil also fixing to order 30% odonnells racing fuel thanks for the info quietnas1
#3157
PA
o'donnells very good and byrons are the only fuels i use, i use 20% odonnells and/or 30% byrons. But i dont run 30% all the time as it does ware your engine down faster, now they are recomending we use 25% instead of 30% and mainly in race modded or turbo engines.
#3160
Ok FatMan I remember devo say a 24 tooth clutch bell and a 54 tooth spur gear will give you more top end. It was posted in the 3.3 thread. Hope this helps and thank devo for the info not me cuz I had no idea lol.
#3162
TN
just got in my motor saver air filter installed , could tell by the design it flows a lot better than stock ,it said to richen the high speed needle because of the flow thats cool
#3163
SC
Just thought that I would throw an update in here. Got everything cleaned out and put back together minus the motor. I went and got my carb yesterday and need to get a 5mm socket to get the carb off the motor later today. Once I do that I will pull out the carb and replace everything. After that I should be good to go! It might rain later so probably won't get to try and start it until tomorrow but oh well. Let me say though, after pulling this thing apart and cleaning everything, it looks amazing. It looks so much better now that everything is cleaned off and looking good. Can't wait to get everything back together and up and running. Thanks for all the help.
#3164
SC
Well some good news and some bad news. I got everything fixed up last night and went out to test. I got it to start but it wouldn't idle at all. I made some adjustments and realized I forgot to set the idle screw fully. I fixed that and it fired up instantly and sat and idled for about ten seconds, I hit the gas and it went off for about ten feet and stalled. The whole night it would start right up idle and when I hit the gas it would stall. I couldn't figure out why. I got it a few times to just drive around very slowly in circles but when I gave it more gas it stalled. I am starting to think the motor just doesn't have enough compression. Any thoughts? The glow plug could be bad also its pretty old.
#3167
SC
What would cause the ez-start to just spin without the motor spinning? I have this problem. It spins the motor most of the time. But every so often the ez-start just spins and the motor does not. Also does the trx 2.5 require a long glow plug? Because I bought medium length glow plugs and it doesn't seem like they are working very well. I'm still working on getting it started tonight.
#3168
PA
pconn5- first the ez- start problem is the one way bearing starting to go sometimes if you take it out dry it and lube it with wheel bearing grease that may prolong it. As far as the glow plug goes i don't know cause i always change my plug to (O.S. 8 )plugs.
#3169
SC
Thanks, yea I kind of figured that was the problem but was just checking. It turned the motor over fine the second time I went out to try and start the engine. This time though the engine would not start at all. I could here it firing and it would run for maybe a couple of seconds but then it would just die. A couple of times I had it started but when I hit the gas it just dies out. I tried leaning out the lsn and still nothing. Im having a strong feeling my engine is dead, but the fact that it was idleing the first time I tried to start it makes me think a little otherwise. Im kind of at a loss as to what to try now.
#3171
SC
It was at factory settings. At factory settings it would start and idle for a good amount of time then it would stall when I hit the gas. I got it to drive slowly for about 10 sec then it stalled again. Tried leaning from there and it didn't really help. Richened and it also didn't help. Checked the fuel system and fuel is flowing out of the line fine. A couple times when it started I had fuel spitting out the exhaust. I know this means it is rich so I leaned it out. It still did it though even after getting the hsn and lsn down pretty lean. It also seemed like there were bubbles forming around the glow plug.
#3172
I'm working on a buddies T-Maxx that was also bubbling around the glo plug. It would also shut off at full throttle. I found that it was missing the brass washer that goes around the glo plug and was not making a complete seal. Male sure it has the brass washer and that it is not warped.
