RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
-Official Traxxas JATO Thread-
Reply
Old 08-06-2010, 06:42 PM
  #3501
manthatcarisfast
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: -Official Traxxas JATO Thread-
hi, sorry i didnt know where else to post this but i have a question. i ran into a problem with my jato 3.3. i have had it for a few years, and havnt had to many problems with it. i was running it the other day for the first time in a while, and all of a sudden, i lost remote control over the car. i couldnt steer the car, brake it, or make it accelerate. it just stopped recieving all commands i gave it. the car was just idleing. i changed the batterys in the back end of the car, as well as my remote batteries, and it still wont work. im not sure what is wrong with it. if anyone could get back to me or help me troubleshoot then that would be great. thanks.
also on a side note, my brake pad/assembly is pretty loose and i was wondering how i could go about tightening it up. it takes a long time for the car to come to a stop, due to a long braking distence and i would like to reduce that if i could.
thanks
if you have any questions about my problem i would be happy to answer them
edit: i think it is either a problem in my remote or a problem in the chip that receives the signel from my remote. (i forget what this is called). i was wondering if there is anything that is most likely wrong with it. when i turn on the switch located on the car, i can hear it engage power. so its not a battery problem. and the car is not out of range of the controller, as i have it sitting 3 feet from the car and no response.
manthatcarisfast is offline
Old 08-13-2010, 03:29 PM
  #3502
meef rustler
meef rustler's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Replace the wire harness... You know the little thing that holds the 4 batteries on the truck. The whole thing. I am going to my LHS today because mine has that sam problem the battery wire is severed.
meef rustler is offline
Old 08-13-2010, 03:31 PM
  #3503
meef rustler
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mine also engages but I've had this problem before.
Old 08-16-2010, 03:32 PM
  #3504
jbrobertsonjr
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hello everyone my jato has a problem the trans makes a squeeling noise at idle still pulls and shift any ideas
jbrobertsonjr is offline
Old 08-24-2010, 05:21 PM
  #3505
Massive690
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I need a new pipe for my Jato. Just running stock right now. What do you guys recommend? I cant afford any BUKU stuff, wife will kill me. Just an all around good pipe. I only run on the street.
Thanks!
Massive690 is offline
Old 08-24-2010, 08:50 PM
  #3506
jbrobertsonjr
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
sorry man i run buku it the best buku gave it so much power more my tranny when out
Old 08-31-2010, 08:25 AM
  #3507
quietnas1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Whats up fellas. Havent been here for awhile. Been bz working and running my trucks on my days off. Im gonna throw in my 2 cents on the Buku. Only pipe I run on my Jato. Absolutely insane!!!! Power galore and a great sound.
quietnas1 is offline
Old 09-14-2010, 08:35 PM
  #3508
jriemer43
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ok guys i just got a traxxas jato and it wont roll freely, its really stiff, and when the car is started it feels lik sumtin is majorly hold it back, but its rolls really freely backwards, i put a new spur gear on it. would help if mayb loosened the screws?
jriemer43 is offline
Old 09-15-2010, 10:00 AM
  #3509
quietnas1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: jriemer43
Why did you put on a new spur gear? Check your gear mesh. Also check to see if your brakes are on to tight. They should not be engaded at idle. Don't loosen any screws.
Old 10-21-2010, 08:24 PM
  #3510
laextreme
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
will the picco .26 or .28 fit in the jato with out modifications??
laextreme is offline
Old 10-21-2010, 08:58 PM
  #3511
1QwkSport2.5r
1QwkSport2.5r's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: laextreme
No. You need a big block mount for 1, and for 2 IIRC you might have to shim the engine up a little bit on the mount itself. I know this is the case in some monster trucks. I only know of one person that put a big block in a jato and had success with it but he used a Mach 427 in his Jato with 1st gear disabled.
1QwkSport2.5r is offline
Old 10-21-2010, 09:09 PM
  #3512
laextreme
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
could i modify the stock mount to make it work?? im pretty good with working with metal.
Old 10-21-2010, 09:11 PM
  #3513
cooldriver385
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I just got my new TRX 3.3 engine dropped into it.
cooldriver385 is offline
Old 10-21-2010, 09:15 PM
  #3514
1QwkSport2.5r
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: laextreme
I just looked at my jato, and Unless you make some sort of adapter plate for the engine to sit on on top of the stock mount, maybe but then you'll have to run a much bigger clutch bell or spur gear to get it to mesh properly.
The holes on my Jato engine mount is about 14mm apart (2.5 Jato but 3.3 is same dimension), My big block motor mounts in the LST2's are about 24mm apart. The Jato engine mount does not have any extra metal to drill new holes into. There is a big block conversion motor mount you can buy for a Jato.
Old 10-21-2010, 09:17 PM
  #3515
1QwkSport2.5r
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: cooldriver385
Thats a smallblock - laxtreme wants to put a big block engine into his Jato which requires a different mount. The Stock one will not work for this purpose.
Old 10-21-2010, 09:20 PM
  #3516
1QwkSport2.5r
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here's a link to the New Era Models big block kit
http://www.neweramodels.com/item.cgi...=&part_id=3321
Old 10-21-2010, 09:21 PM
  #3517
laextreme
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
could i use the tmaxx mount and drill new holes in the chassis? the reason i just dont order the new era big block kit is cuz parents wont let me order parts online (only 16) and my local shop orders from horizon hobby and they dont carry it.
Old 10-21-2010, 09:25 PM
  #3518
1QwkSport2.5r
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: laextreme
I really doubt it. I dont know a whole lot about the T-Maxx, but I highly doubt you'll be able to just drill new holes, and have it work. You also have to keep in mind that a big block engine puts out quite a bit more power than a smallblock engine will so there will be added stress on all of the chassis components. If you try to make a smallblock mount work, it might bolt up but given the extra power it might crank and cause all sorts of problems.
I'd suggest saving your money and asking your parents to order the part for you. You can call New Era and order over the phone (have your folks do it for you.)
You might be able to make it work with stock parts, but I doubt it would work for very long. Thats just my opinion.
Old 10-21-2010, 09:28 PM
  #3519
laextreme
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i already have the traxxas cvds and plan on gettin the steel tranny gears which should beef it.
Old 10-21-2010, 09:33 PM
  #3520
1QwkSport2.5r
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: laextreme
Thats a start.. I'd be more concerned about the engine mount. Also be advised a regular big block header and pipe probably wont fit the Jato's chassis. I'd do a little more research before trying to shoehorn this thing together. If it were me (and mind you, I don't like OS engines) instead of going through the hassle of putting a .26 or .28 in it, I'd get an OS 21TM which uses the smallblock mount pattern and will drop right into any traxxas vehicle with little or no modifications. big block power in the space of a smallblock. OR stick with a 3.3 or Losi 3.4.
Old 10-21-2010, 09:44 PM
  #3521
laextreme
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
but how does the .21tm os compare to the picco .26?? closely related power?? im looking for top end speed like 70++.
Old 10-21-2010, 10:01 PM
  #3522
laextreme
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
also which heade would i use for the .21tm?? and would the stock blue resonator pipe work?
Old 10-21-2010, 10:10 PM
  #3523
laextreme
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
http://www.rcuniverse.com/forum/m_73...tm.htm#8777681 i read here that the .26 picco drops in tho...
Old 11-08-2010, 10:41 AM
  #3524
martin34
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi guys i a rebuilding a jato for a winter project.I have a brand new os18tm with resinator pipe that i have fitted and Talon 2.8 tyres.My question as about gearing.The most common opinion seems to be 20/54 on another forum but i was wandering what you guys think?Thanks for any info.
martin34 is offline
Old 11-24-2010, 10:11 PM
  #3525
MPevine11
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
is the exocarbon kit for the jato good? does it reduce weight? are the supension arms durable?
MPevine11 is offline
Reply
Display Modes
