-Official Traxxas JATO Thread-
#1551
My Feedback: (14)
TX
RE: -Official Traxxas JATO Thread-
As for the single or dual chamber being better ... well it is up to you. where do you want the power added? single chamber is best for low end. dual chamber adds in the mid to high RPM. I prefer the dual since the jato is so much over powered on the low end anyway.
I use a pull start on my basher with the 3.3
my other jato uses a RB V.12 - it is bump start only.
personaly I dont like the EZ start or any of that stuff. just one more battery to charge... IMO...
#1554
IL
So anyways if you know how to convert any hpi or proline dish wheels for the jato, it would be greatly appereaciated!!!
You cannot do this because the JATO's wheel bearings are in the wheel not the steering knuckle , they will work on the back with the 12mm hex . As far as I know nobody makes an adapter kit to use them on the front ....
#1555
WA
dish wheels are lighter, and not sure but stronger? I still use the ez start. have had no problems, only replaced oneway baering once, and it was because when I cleaned it up, and used too high pressure from compressor and blew out a couple of needle bearrings!! for got to turn down the regulator! I had it high so I could use air tools on my real car. (120psi) I dont mind the extra wheight. but I do use glow stick, instead of blue wire. wand battery last lot longer, and the motor turns over faster.
DAN DAN yeah, dont know about the hpi wheels, but i'm right there with ya about the breaking servo ears! I took a small thin peice of steel, bout 1/2" by 1/4", drilled two holes for the screws, and no more broken cases.
#1556
AZ
[quote]ORIGINAL: KRO
Lossening results in the clutch gripping less. Both top end speed, and wheelies will be reduced because the output shaft will be spinning slower than the input shaft from the spur gear/clutchbell/motor (aka you are reducing the gearing)
EXAMPLE:
Input shaft--->2:1<---ouput shaft
The input shaft from motor: spins twice. The output shaft to transmission: spins only once
If you tighten the clutch, you are going to keep input/output shafts at closer speeds to each other (aka 1:1 ratio)
Input shaft from motor: spins once. Ouput shaft to transmission: spins once
1:1 ratios at low speeds will kill your motor or your clutches, so you have to keep them a little loose. As your car picks up speed, pressure equalizes on both sides and your clutch doesn't slip. (If it's set too light, it will always slip, resulting in lower top speed)
On the other hand, if it's set tight, it will transfer all of the power straight to the pavement giving you a big wheelie (provided your tranny/spur gear/clutch bell gearing isn't too tall!!!)
EXAMPLE:
Ok , some of this is not true ....
You will wheelie less because the slipper clutch will not grab as hard and will slip a little , it DOES NOT continuously slip after the car gets going and the motor winds out . If it did you would probably get 2 or 3 runs on the slipper clutch before having to rebuild it . I have over a gallon on the last rebuild and the pads still look great .
If you tighten the slipper clutch all the way down you will damage your transmisson , I would run at least 1/2 to 3/4 turn from tight . So far I have not burnt up another tranny yet (have done it twice now) .
The slipper clutch is there to take the shock loads that the tranny will see while running . like when jumping , or running on rough ground where the rear end will keep loading and unloading .
Not trying to be a d!ck , I just want to keep my fellow JATO owners from killing their trannies
You do run the risk of it still slipping if it is set too loose, even at high speeds, but this is usually a result of the lock-nut backing off the shaft.
#1557
Ok so i think i will use some sort of wheels in the back,. Mabey I will just have agigator wheels all round, but i dont like the crome because i will imeadeately scrach it when i run in dirt, so dish wheels would not scrach as easy, and if they do they will still look nice. Does anyone know where i could get a 12MM adapteer?
Dan
EDIT: Now i see that proline will sell the 4 set of wabash wheels with adapters for 22 Dollaz, i think i may just get this. Does anyone know how i could paint it black, the new color theme for my truck is only going to be black and red, with only two stickers on it saying JATO. I may if i have the money I would get an extra set of tires that are road rages, but i think that they would not be good in my conditions, as i run on the street, but the street i run on is full of dust from construction. Thanks
Dan
#1558
DYE THEM LIKE THESE http://s149.photobucket.com/albums/s...t=IMGP0031.jpg
#1562
IL
What is the best method of removing the crome paint? Paint Remover? and where can i get wheel dye?
Dan
Dan
Then buy some RIT cloths dye , powdered works the best IMO . Put some water in a pan , enough too cover the wheels , then add the dye and heat it till its about 180-200 deg. Place ALL 4 WHEELS into the dye and let them soak . The longer they sit in the dye the darker the color . Take them out of the dye and rinse them in cold water .
rodney---I notice you have the plate support on your jato. Does it really stop the top plate from breaking?
#1564
IL
May be a stupid question but did you remove the tires or did you strip the paint with it on?
You need to have the tires off the rims to strip and dye them .
#1565
IN
im thinking about taking out my 2.5r because im having so many problems with it. what are some reliable engines for bashing with low-end? i want to get rid of the ez-start, roll bar, etc. to shave so weight. With the engine i would also like it to be drill start capable if possible. any sugguestions?
#1566
WA
when I replaced my 2.5 with a 3.3, I took out the ez and put in the pull. but since the motor wasnt broke in yet, it was a pain in the *****. so I put the ez back on. I only bash with buddies, and not looking for high speed, in fact, my tranny stopped shifting about a 1/2 gallon ago. needless to say, if your ez start is maintained and works good, I kept mine, but I use a glow stick instead of the blue wire.
As for todays carnage, I spent 3 hrs hunting down bulkheads and front shock towers, struggled with sripped allen heads, and stipped plastic holes, only to have a set of concrete stairs jump out infront of my jato at 40mph, five minutes into the fun. broke both bulkheads, topplate, front shock tower, bumper. but dang if those rpm arms are strong! I hit the stairs at an angle, about 35-40mph, and still good!!
Does any one have any ideas how to thread the holes before useing screwws? I thought about using a tap set, but am unsure what thread pitch to get. Oh, btw, those stainless steel screw kits suk. the biggest waste of money ever! I always strip 'em, does any one sell the regular steel screw kits?
Today I ordered a E-savage bug body, my lhs had one sitting out, so I eyeballed it to another jato. looks dang close. Looks like I just need some trimming on the nose. I think crazyotto had a bug boddy, but his looked kinda big. the savaage bug looks dead on. has any one put this body on their jato? Is it as close as it seems to fittng right, and without much effort? thx 134
#1568
I have a pull starter on my jato 3.3 and it starts really easy. You can probaly put the pull start back on and have no problem now that its broken in.
#1569
I have done a couple of searches and read around a quater of this thread and can not find how to change the diff oil. If i change the oil to something thick would it prevent one wheel spinning really fast and blooning up? If some one could tell me how and why to change the diff oil to something thicker it would help. Thanks
#1570
AZ
ORIGINAL: angus67
nick2618 Replacing the oil will help a LOT!!! I put 50,000wt in mine and it made a tremendous difference. I would recommend going to 70K or 100Kwt to lock the wheels in even better. Also go up to 50wt oil for your shocks and crank down the springs (or get stiffer springs) and it will keep it planted on it's feet even in dirt. (super drifting abilities if you get it dialed in right!!!)
To replace the oil;
1. Remove the diff, take out the 4 screws on the one side, then take off the plate and remove the seal on the edge. ***REPLACE the seal!!!*** do NOT re-use no matter how good it looks! Besides the seal kit is only 3-5 bucks anyways.
2. take out the spider gears and spray them with nitro-solve or Simple Green to get ALL the oil/grease out, then dry.
3. Put the gears back into the diff case.
4. Pour a little oil at a time into the case (it pours like cold syrup, so have patience!). When you get about halfway full, spin the gears SLOWLY to get the oil in between the gears. (Make sure you don't get any bubbles in the oil) Once the oil settles fill the rest up to about 1/8" below the lip of the case.
5. Put the other side of the case back on (make sure you have the seal on) and cross-tighten the screws down a little at a time (like tightening lug nuts on a real car) And you're done!
***There might be a little oil that squeezes by the seal or the screw holes, just use a paper towel to wipe up the excess. Once it sits for a while, it shouldn't bleed anymore and you can put your tranny back together. If some oil gets into the gears it won't hurt them so you don't have to get it entirely perfect.
(FYI: XTM diff oil and Associated shock oil)
#1571
HEY ANGUS67, IT DOES HELP FROM BREAKING TOP PLATES PLUS IT HELPS COMBINED WITH THE FLAT PACK IN CTR TO MIN. WHEELIES!!
#1572
Well i am going to go done to my lhs today adn just ask for something around 75k and see what brands he has. But i gotta wash me real car fist. lol I will let you all know how it went.
Thanks for the info
Nick
Thanks for the info
Nick
#1573
Well I went to my lhs and got 100k diff thats what they had. Now when i run it and it starts to do a donut both wheels seem to spin equal instead of one blooning way up. Also i put a new set of tires on it road rages. They actually turn the truck unlike the ones i was running. lol.
My heart did stop twice thou while i was running my truck. I jumped one of the speed bumps where i live and got about 7 ft off the ground. It did a flip and then landed on all fours with no throttle adjustment from me. I was not excepting the jump trying to go in middle of the bumps. I just froze while it was in the air dreading the landing. Then after that i was running and a car came around a corner and almost flattened my truck. After that i put it away not a good day for me.
Also on the back of the trans case above the bumped there seems to be 2 screw holes with a label in the middle that says "Max" then under it an arrow pointing two ways."<->" Whats that for?
#1574
IN
has anyone else been having consistant problems of there 2.5r not holding a tune? because everytime i got to take it out for a run i have to change the tuning for it to start-up and sometimes ill go through a glow plug just trying to get it started.
#1575
OH
hey nick the rubber plug is where you adjust the timeing for second gear... if you dont want your tires balooning, use duct tape to line the inside of your tire
ORIGINAL: nick2618
