If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 5 of 90 FirstFirst ... 345671555 ... LastLast
Results 101 to 125 of 2242
  1. #101
    RE: Official XTM X-Cellerator thread!!
    There are more parts that will fit. Evader parts will, they are the same as the XX series trucks/buggies. You can drop on the graphite front AND rear hubs, steering knuckles, and front suspension arms from the evader. That makes going graphite cheaper too, i hear the Duratrax graphite is pretty tough.
  2. #102
    ThunderbirdJunkie's Avatar
    Join Date
    Jul 2004
    Norwood, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    SERIOUSLY?
    *rolls dice* CMOOOOOOOOON next paycheck! two boxes are on their way!
    \"Some people can mess up an anvil with a rubber hammer\" -46u
    If you don\'\'t allow yourself to fail, you\'\'ll never allow yourself to succeed-ThunderbirdJunkie
  3. #103
    Join Date
    Feb 2006
    , ID
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The b4/t4/gt diff gear is right but the outdrives are just a hair too wide, the case wont screw together without pinching the diff. So the stock outdrives it is. I used a asc diff rebuild kit and resurfaced the stock rings; the diff is almost smooth now. The xxxnt rear arms and rear pivot block and body are all almost direct fits. Do you just place the losi 51t xxxnt spur in the slipper with the stock xtm slipper pads? The index tabs on the xtm are along the outer edge while the losi tabs are on the inner edge, with it all assembled it looks like it'll stay together is that right?
  4. #104
    ORIGINAL: ThunderbirdJunkie
    SERIOUSLY?
    The xcellerator is a gem once it gets done up well. Plenty of parts fit, just gotta know where to look
    I'm gonna stock up on duratrax's graphite stuff for it (rear arms are a negative... just get XTM aluminum arms and aluminum hubs to fix the problem). Other than that, you balance the truck out pretty well and beef it up pretty nice by doing that. Use captured ends on the turnbuckles, it'll prevent many of dnf's. I hear XTM's ball cups are weak and even the turnbuckle it self is... but I HEARD that. I am still going to upgrade it [>:]
  5. #105
    Join Date
    Feb 2005
    dana point, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    things i have done to mine and i know will fit..
    losi springs.. a better fit thaN team assoc. losi spring fit perfect without binding
    assoc diff gear.. and carbide balls.. must use assoc. diff ring... the diff gear ball holes are a different size and the stock bearings wont work.. and the stock ring wont work on the assoc gear..
    assoc. idler gear..
    also to fix the ball cups from coming off the rear chassis brace.. most common place for disconnection,, im using dubro capture links,, and since i have been using them i have noticed my speeds at the track to go way up.. not having to worry so much about landing PERFECTLY and im not wasting time fixing it.. another place to put the capture links are on the steering knuckle but that is an easy fix and those only come off when i hit a wall head on ...
    but i would like to find a cvd that would fit besides xtm.. and to protect the diff outdrive tamiya makes this blade thing that fits on the end of the dogbone and uses the pins to allow swivel action while the bone spins and shocks are in action. it is just a small piece of plastic that fits over and onto the pins and slides into the outdrive for a perfect fit,,, reducing wear of the outdrive.. and only the "blade" gets damaged
    motor review http://www.rcuniverse.com/forum/fb.asp?m=7472571
    tire review www.rcuniverse.com/forum/m_6000527/tm.htm
  6. #106
    Well, I am guessing the Evader NT cvd's would fit it, or losi's xxxnt's. most of the truck is losi oriented
  7. #107
    Join Date
    Jul 2004
    Norwood, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Kemo
    my LHS has more parts for the X-C than all the other ST's on the market...It's the LHS I like too, which always made me feel bad for goin to my other LHS for GT and Losi parts[:@]
    aside from the Jato. They have stacks upon stacks upon stacks of Jato arms and bulkheads[&:]
  8. #108
    traxxas seems to make 1/10th ****ty and then hundreds of companies make new products to make it better. The Xtm Xcell is strong as it is, but it has very few major areas to be worked on. I hear the diff doesn't hold up very long.
    Ok guys with Rc10GT diffs, please provide the part name and associated part numbers for what parts we'll need to drop in a RC10GT diff.
    Copy and paste this
    |<>| RC10GT Diff conversion for X-Cellerator |<>|
    1: (list parts here)
    2: (list parts here)
  9. #109
    Join Date
    Jul 2004
    Norwood, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    click here for a complete differential
  10. #110
    Looks like the next part is an idler gear
  11. #111
    Join Date
    Jul 2004
    Norwood, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
  12. #112
    so thats it huh? Well diff problems are solved now. What type of balls are in that diff kit? I like mine to last long... might be going ceramic nitride.
  13. #113
    Well my engine is on its way, got it from my sponsor. STS .12R. STS made engines for HPI a while back, but the best example i can use is the .12r xs from HPI which is basically the sts D12E. The .12 r has more power and a bit more speed. Will take pics when i get it.
  14. #114
    iceyflyer's Avatar
    Join Date
    Nov 2004
    Gilbertsville, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    anybody know if there is a spur gear out there that is not made of plastic that i can use on my X-C
    The bigger the better.
  15. #115
    if you can find one made for losi's xxxnt... it'll probably work. Kevlar is the best way to go IMHO.
  16. #116
    tbird... when you gonna tell me what you got?
  17. #117
    Join Date
    Feb 2006
    coventry, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    anyone know where you can order x-cell hopups from online ?!
  18. #118
    Join Date
    Jul 2004
    Norwood, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Kemo
    Haven't gotten it yet:| Got shorted on my last paycheck BADLY...so I couldn't get a used tamiya rolling chassis, let alone 3 new cars
    the third car is an Ofna LD3 Pro RTR.
  19. #119
    wyd's Avatar
    Join Date
    Feb 2003
    PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Well I went ahead ond ordered a Racer kit. I decided to run nitro truck oval racing in are area again this year and decided to go back to the XTM X-Cellerator. I ran a Jato last year but I like the ease of working on the X-Cellerator better and 3 local shops carry all the parts and the one shop is at the track I race at. Plus I like the fact that I had one before and what I need to change on the truck once it comes in. Another nice feature is they sell it without motor and radio gear. Huge plus for me since I'm going to use my own radio equipment and motor combination. Can't wait to get one of these trucks again. My last one worked great for me.
    The Hidden Hangar
    Castle Creations
    Team Schumacher
    D&K Air Designs
  20. #120
    Join Date
    Feb 2006
    , ID
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The ass diff gear is the right size but the assembly with the ass outdrives is too wide. I ended up using ass balls, thrust balls/rings and nut, with with the XTM rings and outdrives.
  21. #121
    Join Date
    Jan 2002
    Tulsa, OK
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Where can I find an exploded parts diagram of the differential and the transmission for the nitro x-cellerator? Their is nothing on hobby people or globals website.
    Thanks.
    Scott
  22. #122
    wyd's Avatar
    Join Date
    Feb 2003
    PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: gacjr0
    That is kinda what I thought that the Associated diff wouldn't fit. I have almost never seen diffs fit in too many other cars other than what they are designed for.
    I plan on doing the exact same setup you went with. The only week link will be the XTM diff rings then. Everything else will be fine. I only ever had problems with the diff rings and the diff balls/thrust balls on my 1st XTM. THe tranny itself was never a problem.
    The Hidden Hangar
    Castle Creations
    Team Schumacher
    D&K Air Designs
  23. #123
    Very valuable info though. It'll save a LOT of stress with people blowing their diffs. Supposedly, stock diff is weak in the Xcell, I'll find out with my STS .12 engine.
  24. #124
    wyd's Avatar
    Join Date
    Feb 2003
    PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Here are some pics of my first X-Cellerator. Should of kept this truck but I didn't. I did learn alot from my first racer so I will know what to change before the truck ever hits the track. Differance this time is this truck will be setup for oval racing and not offroad. Most of the stuff I did though will still be used on my oval truck setup. I do have some after market stuff on the truck as it is I guess far from stock but then again almost no one keeps their trucks stock anyways. Most of the stuff I did was to make it more reliable overall. Some was just for the truck to look good as well.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	414673   Click image for larger version.
ID:	414674   Click image for larger version.
    The Hidden Hangar
    Castle Creations
    Team Schumacher
    D&K Air Designs
  25. #125
    the blue accent does a lot to the looks... pretty nice lookin truck you had there.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
