Official XTM X-Cellerator thread!!
#1452
RE: Official XTM X-Cellerator thread!!
The engine if broken in and tuned properly should last between 10-15 gallons. Atleast mine did. About 14. Then a new piston and sleeve i am yet to install.
#1453
CA
Range is never a consistent thing because of terrain and lots of other factors. The best thing to do to prevent loss of control is to just turn on the electronics and set the car down. Then slowly walk away while turning the wheels. How far do you really want to drive it though. It will go pretty much as far as you can see it, and by then what fun is it anyway. So range in my opinion is not a problem. If you wanted more you could get a FM or 2.4gh radio for pretty cheap and not ever have to worry. And about frying the engine. It is ALL the users fault if you fry an engine. If you treat it nicely it will treat you nicely in return. There are a few cases in where something can happen but most of the time it is the user.[sm=redface.gif]
#1454
you know what would be a good idea? ( ok,maybe not so good )
on the flywheel or some moving engine part install small auxiliary generator that will provide emergency power to the reciver.
when the battery goes under operating minimum the reciver is taking power from the generator.
generator shoud be operating in middle engine rpm.
generator operating rpm could be adjusted to your taste with resistors.
when the generator is operating on the engine high rpm admeasure the voltage an then with the resistors adjust voltage to your reciver voltage requirements.
for generator could be used small 3V DC engine or something stronger.
there is more details about this idea but this in never been tested by me and im not so sure that this will work.
#1455
CA
That is a good idea but its not feezable because of the electronics involved in makeing something that would charge and withstand the beating one of those trucks takes. Also in the size factor it would be hard to get amps to put a charge on a battery...........they have generating systems for planes that will sustain a charge or prolong it but not really charge it. Coming up with a 5000 maH battery would be more like it.....................take 2 or 3 months to run down that battery.......lol
#1456
would it be a smart move to buy direct port nitrous injection system.
price is 250-300$ with full equipment for installing (good air filter,30 NOS refillings bottles and injection system)
that is lot of money so i want to be fully informed from someone who have this system or at least saw it in action.
what are improvements to the engine preformance?
#1459
CA
Only thing thats really got more power and isn't all that much better in a OS .18tz for that particular group of engines but now you get into some of those sweet .12's you have a wide open field[:-]
#1460
ORIGINAL: Black Angel
#1463
can i do brake-in proces without wearing my tires out?
i thought that i can put the car on some big block of wood or something like that but the wheels wont be wasteing beacuse they are above the ground and they are not touching anything.
#1464
and why would you do that ?
its also important to run the car during the break-in just read some instructions.
Guys some please help me out with the suspension(springs+fluid).
#1465
CA
what kind of fluid and springs u guys running on the suspension
#1468
well i need a fluid/spring setup for offroad... im not racing it on asphalt
i thought about medium springs(stock) and 30wt in the back 35wt in the front
#1469
I am running the stock springs front and rear along with 40wt front and rear. works well. I have a 3/4 full bottle of 80wt.........wonder how that would do?[&:] Thats what i run in my revo, so why not my x-c?[&:]
#1471
CA
#1472
well im also jumping... and racing with friends...
have u tested the setup ? i think i'll try 25 in the front and 45 in the back
#1473
CA
Thats what I run in with my ST's is hard pan with powder on top and yes I've tested it for a couple of years now.....still learning[&o] go a little higher in the front or go to a medium spring.........one or the other........stock springs and 20wt will make the front end drag a bit hard[:-]
#1474
well then ill go with 35in the front and 45in the back, the reason why i want to change the shockoil is cause i think that the stock stuff sucks... if i compare it to associated or losi it reacts kinda different - unnormal
are you using the stock springs ?
#1475
ORIGINAL: RCUSEE
