If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 378 of 406 FirstFirst ... 278328368376377378379380388 ... LastLast
Results 9,426 to 9,450 of 10132
  1. #9426
    Join Date
    Feb 2007
    shipman, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Official Nitro Evader ST Thread v2.0
    Yeah id just skipped back a couple pages and started reading it over again, i was considering it after you had posted it, and since i melt a diff about once every two or three months might as well give it a try.
  2. #9427
    Join Date
    Mar 2008
    bardstown, KY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    yea man.. give it a try.. you may never look back again.. then you mite not like it.. for durability??? its tuff.. in my opinion it takes care of the biggest weakness these trucks have... expect to upgrade the wheel pins also... but you are getting more power to the ground... after doing the diff mod and using the better wheel pins(drill bits, blunt ends) it sems tuff... i bashed all summer and finally had to replace a set of rear wheels ( the plastic cracked).. but i believe that the broken pins contributed to the wheels getting cracked.. i think evader512 upgraded to hex style wheels and no problems... i ported the motor on my evader, and it really woke up.. its ballistic fast.. i also used a better piston/sleeve combo in the motor.. it now has a chrome sleeve... i used the piston/sleeve from a aquacraft miss vegas boat.. same exact motors made by duratrax, but they chrome plated the sleeves for the boat motors..(last longer) its a direct drop in, and for only about 30 bucks... the stock sleeve in the evader is nickel coated.. which tends to wear out very fast.. just a few tricks i have learned along the way..
  3. #9428
    Join Date
    Feb 2007
    shipman, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Well either way it should be fun, atleast i dont worry much about breaking my rc's the lhs went out of buisness and i bought all their evader parts like 400$ worth for about 50$.
  4. #9429
    Join Date
    Mar 2008
    bardstown, KY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    holy cow!! wanna sell me some parts??? lol.. i need a few things.. some a arms, and the c clip that holds the clutchbell on.. lol.. if not i understand..i like to hang on to all my extra parts.. another tip for you.. ditch the junky stock clutch that always fails... install a traxxas tmaxx clutch.. get the one for the 2.5 tmaxx.. direct drop in.. grabs great, lasts great.. it gives the truck a little more stall.. so when its idling it doesn't wanna walk away from you..
  5. #9430
    Join Date
    Feb 2007
    shipman, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
  6. #9431
    Join Date
    Mar 2008
    bardstown, KY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
  7. #9432
    Join Date
    Feb 2007
    shipman, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Im guessing since they are a carbon composite they hold up longer than the nylon?
  8. #9433
    Join Date
    Mar 2008
    bardstown, KY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    yep.. they are a lot tuffer.. the nylons where fast, the the clutch spring starts to wear, then it breaks.. the tmaxx clutch is a winner in my book.. i am very happy with my evader since i have done all the mods to it.. its dependable....
  9. #9434
    Join Date
    Sep 2008
    the bluegrass state, KY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    im happy with my tmax cluch and when you do so the dif mod follow sheeriderss directions on the other page they work good rember to grind the washers down big mistake forgettin that i post some pics of what i did to mine when i figure out how
    Nitro evader st, maximum mt stretch and yes i did make a limo out of a nitro car, about to put a .15 in it. it needs a body
  10. #9435
    Join Date
    Feb 2007
    shipman, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    When you click the post reply button at the bottom left hand of the box there is a paperclip that says file next to it and then it says lick here to upload images and files.
  11. #9436
    Join Date
    Feb 2007
    shipman, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    This should help
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1158108   Click image for larger version.
  12. #9437
    Join Date
    Mar 2008
    bardstown, KY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    i posted pictures of the mod.. are they gone??
  13. #9438
    Join Date
    Sep 2008
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    NO IM JUST GOING TO POST WHAT WHEEL SET UP IM RUNNIN WITH THE DIFF MOD BECAUSE ITS STRONGER THAN DRILL BITS SORRY CAP LOCK WAS ON
  14. #9439
    Join Date
    Mar 2008
    bardstown, KY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    kool.. lets see the wheel mod you came up with.. i may change mine.. i do like the locked diff on the truck.. it definaely hauls a*s ..
  15. #9440
    Join Date
    Feb 2007
    shipman, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Well after spending hours trying to root out the problem with my os powered evader, i finnaly figured it out, melted diff, and my slipper pad had somehow managed to attach itself to both parts of the slipper and lock them together. Replaced both parts and the pad and good to go. Just spent the past hour blasting arround the neighborhood with it and no problems. Hope it solves all my issues with that car.
  16. #9441
    Join Date
    Sep 2008
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    sorry i did nt get the chance to take the pic its to late now
  17. #9442
    Join Date
    Mar 2008
    bardstown, KY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    did you do the diff mod??? was just curious..
  18. #9443
    Join Date
    Jul 2007
    Lexington, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    My buddy has a nitro evader ST and we ate up the diff with his new motor installed the other day. At first we thought it was the diff gear teeth that were ate up but after taking it apart the diff gear teeth seemed ok. After inspection we noticed that if you held a dogbone tight and then turned the diff gear manually it turned freely. This didn't seem right so we bought DuraTrax Differential Rebuild Kit Evader ST and DuraTrax Differential Gear Nitro Evader ST. We werent exactly sure this was the right stuff to buy but we did anyway because it was cheap. I did a search before posting and didn't find any specific information so if you know of a post that already talks about this please point me in that direction. We are both new to the nitro evader and don't know much about it so any help is greatly appriciated.
    Defm
  19. #9444
    Join Date
    Mar 2009
    , AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    hi im new here uhm is there an offical nitro evader pic thred j.w cuz i have an evader and like 2 look at other ppls creations
    sry 4 spelling not a good speller
  20. #9445
    venom69_420's Avatar
    Join Date
    Dec 2007
    camrose, AB, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    2 micro t\'\'s , rs4 evo 3 , evader st , revo 3.3
  21. #9446
    Join Date
    Feb 2007
    shipman, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hey venom how long can you run with both tanks on that thing filled?
  22. #9447
    Join Date
    Feb 2007
    shipman, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Oh and bam you know you can click our names and look at the photos in our gallerys, some of us have them some dont, and if you look back through the entire thread there's a fair number of photos posted.
  23. #9448
    Join Date
    Dec 2007
    camrose, AB, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    it lasts for about a half hour, 35 min was the longest i timed it for. the tank i used was from an mgt i think
  24. #9449
    Join Date
    Feb 2007
    shipman, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thats cool, ive got a spare tank i had tried to fit on to mine but it was too tall it was off a smartech rc, if i could have made it fit under the body without too much modding i would have tried using it.
  25. #9450
    docphysics's Avatar
    Join Date
    Feb 2006
    Poughkeepsie, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I'm selling my evader in case in anyone is interested.
    http://cgi.ebay.com/NITRO-EVADER-ST-...3A1%7C294%3A50
    Brakes are an unnecessary option!
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
