factory settings for the dtx 18 nedles
can some one plz tell me what the factory setting nedels are for the dtx 18 the one that some factory with the nitro evader st
thanks heps
thanks heps
RE: factory settings for the dtx 18 nedles
HSN is 2 turns out. I think LSN is either flush with brass housing or 1/4 turn in from flush.
Idle stop should be adjusted so that there is a 1.5mm gap in the carb at idle.
FL
Hey gerwen, is that how the engine should be tuned after break in and normal run?
How can i tell if my engine is tuned correctly, like if its to rich or to lean or not, without a temp gauge?
