Futaba to JR connectors?
OK
Does anyone know if the Futaba J connector can modified to fit a JR R310 receiver? If the plug can be modified, when where can I find an adapter?
RE: Futaba to JR connectors?
can you post a pic of the current connector. most will fit if there a tab on the side of the connector and no slot for the tab in the rx i trim the tab off but i make sure that the servo is wired the same ie black to blac red to red white to white as some are red to red black to black white to white
UT
ORIGINAL: Snipin_Willy
You can cut the tab off carefully or buy one of [link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXL302&P=0]these[/link], your LHS should have them in stock also.
