*~ Official RC10GT2 Thread ~*
#376
CA
RE: *~ Official RC10GT2 Thread ~*
ORIGINAL: Wide Open
im using a starter box on an OS .12 TZ. the problem is that it has so much compression that the starter box doesnt want to turn it over without first heating up the engine block with a hair dryer. yesterday was the first time i managed to get it going without heating the block so thats a good sign. (it ran really well, too)
ORIGINAL: AE Pilot
You generally have starting problems? What are you using, a PS, box or roto?
I wonder what the compression ratio is? Is the combustion chamber smaller in diameter and deeper in depth compared to "normal" engines?
Yeah, I'm jealous.
#377
CA
Thanks for the description. By nature, I like to tinker with things too, so I'm perfectly content fabricating, building, tinkering and tuning as opposed to actually driving. We've been dealing wih 2-stroke race engines for years (dirt and road race bikes), so tuning is definitely my thing.
Looking forward to the pictures. [sm=wink_smile.gif]
[quote]ORIGINAL: Xyzzy
PS - One nice thing about the AMBrc is the light lets you know the whole system is on.
PPS - I sure wish there was a job that involved building this stuff. I don't want to drive, I just want to build and tune. Hopefully my son will take tothe driving part.
PPPS - I could have gotten much fancier with the shelf, but I decided to use parts I have on hand. Still, I think it looks pretty trick.
#378
AZ
ORIGINAL: AE Pilot
OS .12 TZ? Sheesh, that engine friggin' rips! [X(]
Yeah, I'm jealous.
Yeah, I'm jealous.
i can definatly say that the compression ratio is quite high because when it was new my starter box couldnt even turn it over with the glow plug out. i had to put after run oil in it, heat up the engine block, and turn it over with a drill connnected to the crankshaft to loosen it up enough to start the first time. once you do get it started, though, its awesome!
#379
Ok, my GT2 RS came last week, I spent the weekend breaking the engine in. Now I am going to break it down and clean it and check all screws. Any suggestions on what would need adjusting since it is still 'out of the box'. Going to try and race it this summer, so any suggestions would be appreciated.
#380
TZ:
bore = 13.8mm
stroke = 14mm
Some people might say that is a long stroke engine but I'd call it square. The TG uses the itentical dimensions.
I had TZ initially, but since we are newbies to stadium trucks we sent it back for the TG. I could only get the TZ to turn over after hitting the heatsink with a heat gun to 180F. The pinch was very tight. The TG uses a different (cheaper, but more newbie friendly) construction (ABL versus ABC) and has less pinch. And, the TG has a warranty. The TZ doesn't.
Supposedly, the hot trick is to put the 5 port TZ crank in the ROAR-legal 3 port TZ. There isn't anything in the ROAR rules that says you can't do this, but they do specifically prohibit 5 port engines.
bore = 13.8mm
stroke = 14mm
#381
Our goal is to actually race this GT2 on-road. My son is only 6 so we have a year or two of basic learning to do. There is a real nice on-road track nearby we can practice at. We wouldn't be remotely competitive with a 2wd truck, but we'll have fun practicing. I was going to get a NTC3, but the 4wd made it much more complicated, plus the ride height is so low we'd never be able to drive it in the huge parking lot behind our house. Unlike 15-20 years ago when I raced buggies, there are no off-road tracks close by.
Obviously, there are a few modifications I need to make to get this ready for on-road use. We are looking at some road tires and some geometry changes. Like, for example, the toe-in (?) on the rear wheels scrubs a lot of speed off to get stability. That's fine in the dirt but on pavement it will be a problem (I think). We also need to stiffen up the shocks a bit and lower the ride height a bit
WRT the wire routing: If it did become a problem I could just drill a small hole in the side and secure the wire with a bit of a rubber band or something, but as it is now, it is no issue. I've also included the preliminary wire routing for the rear battery. I'm not sure it is the cleanest way to do it. I'm open to suggestions.
The only mods we have made so far are Lunsford turnbuckles, hinge pins and front axles. The servos hopefully will last for life. We run them in "HRS" mode and they are scary fast. We bought a synthesized Tx/Rx combo. The last radio I owned was made in the early 90s. Things sure have changed. We also bought the FT starter box and a pile of rechargeable batteries. I feel like I have more batteries now than when I ran electric!
To tame the engine for my son we are running a low power engine (0.7HP), the tallest gearing available, 0.8mm clutch springs, a rotarty carb (We have a slide carb, by accident, sitting here) and we have a "smoothy" pipe on perpetual back order. I figure the above combo will give it a soft takeoff. The neighbor kids all have Revos and stuff like that but all they do is go 50mph and hit stuff. Our goal is to not crash.
I apologize for the crappy quality of the pictures. My camera has very poor macro capabilities.
PS - Just to give you an idea of how old school I am, I sure miss the beadlock tires on the original RC10! Too bad they don't make beadlock tires for the GT2. Gluing tires is something I have always hated.
#384
CA
Personally, I think the TG's are great and with the price of nitro fuel, the fuel economy is great. I run a tank out in about 6 minutes flat, but the TG's are supposed to run a tank out in about 15 minutes or so.
I would think that the GT2 would do ok in the corners against a TC, but if you're racing on a circuit with a long straights, forget about it.
Thanks for the pictures. The Macro was fine.
#385
What engine are you using?
http://www.osengines.com/engines/osmg1986.html
(Anyone need a 12D slide carb?)
#387
http://www.thercspeedway.com/
#388
CA
I think you'd be ok. The only other general problem I see are the lane barriers. Since the wheels / tires are tucked into the fenders on TC's, they could come in contact with and/or rub against a barrier without really impacting the speed or momentum.
With an ST, since the wheel would be in direct contact with the barrier, the decrease in speed would be substantial, not to mention the possibility of rolling the truck over, spinning out of control or simply going right over the barrier.
#389
http://www.prolineracing.com/product...wproduct&id=16
http://www.prolineracing.com/product...product&id=186
(Ultra firm foam would be less squirmy, right? And we don't need the impact cushioning of a soft foam?)
I haven't been able to find any "set up yer GT like a TC" web sites yet so any tips are appreciated.
I know less than zero at this point.
#390
The ultra firm foam is a good idea. Most on-road cars have low profile tires so they are naturally sturdy but with the high profile on most 2.2 ST tires you may need the firm foam to help hold it up when you are gripping through turns.
Cleaned my truck today just to drive it and get it dirty a few minutes later.
Anyone else familiar with denatured alcohol? From what I read it did not affect plastic parts but it seemed to give some of my plastic parts a cloudy shine to them till I wiped them down with a dry shop towel...
#391
CA
ORIGINAL: Xyzzy
Any tips on how to set it up for pavement? I'm thinking, for starters:
The Speed Hawgs are absolute jokes, so get the Road Rage tires. They will probably be closest to what's being used on TC's. The tires on the TC's are far stickier than the Proline tire compounds, which is probably why Proline doesn't produce a TC tire.
We use the dual-stage foam, but for an entirely different reason. Since we use the low profile Road Rage tires, we use the firmer foam inserts to prevent the tires from bottoming-out or compressing against the wheels from hard landings to prevent shock transfer into the chassis, but moreso to protect our investment in aluminum wheels.
The dual-stage or ultra-firm foam would work great for what you described too.
#392
I'm curious why the Speed Hawg tires suck so much. They look a lot more aggressive and they use the same M2 compound. Is it the tread pattern?
Should I be looking at aluminum wheels? Are there Posi-Lock aluminum wheels?
I'll probably order the tires and foams and some wheels (plastic or aluminum I don't know) this weekend. I have a bit more building to do but I hope to get this thing operational soon.
If I ran *strictly* on-road, and in clean parking lots, would this air cleaner be adequate?
http://www2.towerhobbies.com/cgi-bin...I=OSMG2384&P=K
(The kit air cleaner doesn't fit.)
#393
CA
Yes, front and rear RR's and no changes to the gearing ratio are needed.
In regard to the Speed Hawgs, that's just my opinion, but just looking at them, I originally thought exactly what you thought, but that was definitely a mistake. We went to several parking lots to try different surfaces and couldn't get any traction. Between the RR's and SH's, I had better traction with the RR's, but that was just my experience.
If you're racing, stick with dish / plastic wheels. I use aluminum wheels just to zip around in parking lots when we're not at the track practicing. If you're looking for something other than dish, but just as durable for racing, RPM makes a wheel called the "Bully" and a few others that look decent.
That filter looks fine, but what's goal, more air flow or keeping the motor tame for your son? In general, if you're driving in a relatively clean and debris free enironment, you can use a single-element filter to promote better air flow into the carburetor. If you're trying to keep the motor tame, use a dual-element filter.
#394
CA
ORIGINAL: driven_by_demons
#395
^^^ The only thing I adjusted after break-in and my first quart was tightening up my differential a quarter turn.
Other than that, be sure to pop the white plastic restrictor out of the carb if you haven't already...
#397
IL
A good on-road setup back when I was racing, was stiffer springs, higher weight shock oil, and limiters inside the shock bodies, some people ran sway bars as well.
I used to run indoor carpet gearbox class and did pretty well with a FTt3 by setting it up this way. We also ran foam tires, but when we did parking lot races, we didn't change a whole lot, other than gearing.
I just fired my FTGT2 off last night with a fairly new tz 5 port.... This thing is soooo sick! Wheelies on ashpalt? Wow, and only half throttle! Speed hawgs hook good on warm ashpalt!
#398
Xyzzy- Check my thread here, you will want to go with less rear toe and front toe out.
Lay the shocks down and go with much smaller shock pistons and much thicker oil.
read this perhaps.
http://www.rcuniverse.com/forum/m_5521163/tm.htm
Dann
read this perhaps.
Dann
#399
Xyzzy - I was looking around on the site and saw someone with an old GT that used NTC3 shocks in it to lower their ride height for on road.
Dont know if they would still work with the GT2 but its something to think about.
Maybe some anti-roll bars even?
#400
By the way, why aren't you using the slide carburetor?
