*~ Official RC10GT2 Thread ~*
#251
RE: *~ Official RC10GT2 Thread ~*
This is the 6508 it is a direct bolt in the GT2, no citting on the threads. the TC3 nut goes right on use lock tite and the shim that comes in the GT2 kit and 1 thin shim and your set.
#252
AZ
i dont know if it would be possible to use a slide carb on the gt2. i havent seen an engine yet that has a rotary carb and an sg crank, so thats why i went with the TZ version i got. it has the rotary carb, and the short crank simulates an sg crank when you have the NTC3 clutch nut on it.
#253
i don't know why but a racer at my track bought a on road LRP .12 with a slide and it will go in it looks funky you just have to play with the linkege, it was redicaulas the power he was trying to play with, LOL
#254
WA
ORIGINAL: Pro Twister Mods
So I should be good if I get this engine and the NTC3 clutch nut.
[link]http://www.horizonhobby.com/Products/Default.aspx?ProdID=DYN6507[/link]
#255
AZ
hmm, i dont know why they said it would work. i had an engine with a standard crank and it was way too long for the clutch nut. if you do get a standard crank engine you need to remove the drive hub in front of the front bearing and cut the crankshaft down. the short cranks dont come with the drive hub and the crank is already short enough. (finding engines for the gt2 can be hard)
#256
WA
I guess I will figure it out eventually. I don't plan on getting the truck for a couple of months anyway, I just wanted to have a plan of everything I needed to get. Thanks for your guys's help.
#257
AZ
well, it seems my OS .12 is finally waking up. to get full throttle i have to have the end point on the transmitter set to 120%, and i have it set to 90%... and its still insane. i was pulling wheelies like mad off the line, but now the back of my battery box is all scratched up from all four wheels lifting off the ground. time to loosen that slipper clutch!
#260
wide open ya have the diff out, it will make more sence, i will call friday afternoon, i am in Knoxville Tn right know i will call you during my drive back home OK. cool
#262
#264
AZ
#267
AZ
hmm, maybe there is a problem with the springs on the first couple runs of these. when i bought a new set of the same clutch springs i noticed the color was slightly different. maybe they used a different way of making it on the new runs of the springs?[&:]
#268
How much of the kits Associated has and has Thunder Tiger making parts? Is it me or has Associated gone down hill since TT has been involved?
#269
AZ
AE will be hurt by the deal at first from what ive heard, but it should eventually work to both companies benefit.
i finally got my gt2 off road for a tank today and it did well. the handling is great[8D]
#271
AZ
my diff is working fine. i took the tranny apart this weekend and there are no signs of anything wrong with it. thanks anyway, though
this is proving to be a fun car, i just dont like starter boxes. having to have that extra battery charged and everything can get in the way sometimes, but once the car does start, its awesome!
#273
AZ
so, how many of you guys are racing yours? once i get the engine running really well im going to take it to the track and try my hand at it. it really seems to be a point and shoot car. it doesnt get off course easily or get messed up by roughness in the way.
#275
AZ
ORIGINAL: ImGoinRCn
Waiting for the weather to get warmer...
