Offical Schumacher Menace .21 Thread v1.0
#154
RE: Offical Schumacher Menace .21 Thread v1.0
sumacher menace keep overheating on the gears causing my gears not to spin which is a part in between the brakes at the back of the gears can you not get metal part for this bechause i think i had the brakes to tight but can you get it in aluminium because it melts and i need it in aluminium please can you get aluminium because its stupid and it melts when the brakes are on i little bit a start.[:@][:@]its proper anoying im sure someone can help me please please help thanks mike
#155
FL
Has anyone successfully changed motors in their menace? It looks like I am going to have to get some motor mounts custom made since no one seems to make any that will work...
#157
VA
I have this truck on the way.
www.schumacher-rc.com they sell a .28 conversion kit for it, comes with mounts, .28, and a few other small things. Or you could get some custom adjustable mounts from www.wolfpackradicals.com for $40 i think.After you get some mounts, any roto/pull .21-28 will fit right in.
#160
is everyone using original radio euipmentor have u upgraded as mine does not want to seem to work so well thinking of changing it to digital stuff
#161
I've used the wplfpack mounts to fit the tt.28 in my menace. They work a treat and he sent the mounts to me within a week! I'm in the UK. The menace4x4x28 pops high speed wheelies now which is fun, but can get a bit annoying when trying to drag race. I ripped my new shell in half due to too many wheelies
#164
Yeup it fits fine, I have one in mine. Makes a whole world of a difference to the brake performance! With a hump pack you can upgrade the servos too.
#165
OR
Nice, I'm looking at gettting one. Have you tried a port and polish job on the Thunder Tiger Pro .21? I'll drive the stocker silly - gotta spin to win, right? I would stick with a .21 afterwards, prob an OS.
#166
is there eny aluminium clutches that would fit the menace as myn as over heated and melted i might as well get one if there is one
#167
That happened to my first clutch aswell, not sure if there are any aluminium ones by i dont think there are, but iv had my second clutch for a while now and i seems 2 still be ok, iv had bearing failures in the pinion/on the engine shaft twice tho.
Does anyone know if there are metal gears? im fed up of strippin mine
#169
i own a sumacher menace n i have had quite a bit of experence with nitro cars now well i mean im pritty good at handling them eny way i was wondering there must be a diffrent shell that fit the schumacher menace out there that is stronger n harder than the stock one as well its a bit naf mine nah. thank you,mike
#170
VA
Any tmaxx body will fit. I have another kind of body on mines, its a body off the Thunder Tiger ST1 truggy.
thats the only other body i know that fits nicely on the menaces.
#171
AZ
Hi
I just got a menace 21 last Friday and have a few questions. How do you tell if the truck is hitting all 3 speeds? And is there a way to adjust shift points within the set-up? Is there different gears and pinion kits for these trucks? And where is everyone finding parts? I have been to the Schumacher site directly and the only other place i found was the Schumacher R/C Superstore Support here on rcu which i have already ordered a new set of rims and now 1 aluminum suspension mount for the front. Just wondering if these have been out that long that there is not many part houses for them like for the savage. And i am open to all the little secrets that i should know about this truck. Thanks for the help
#172
easiest way of knowing when it changes gear is u will hear it secndly u can make it change a bit quicker by drilling tiny holes in the pawls this will make them lighter therfore changin quicker
#173
AZ
Thanks for the help. I do listen for it like i do on my savage i hear it hit 2nd i might just be running out of room before it can hit 3rd. And i know its a matter of preference but what is the usual number of holes and what size drill bit? My plan is to make it a street racing menace and being this is my first Schumacher and noticing that there is no screws to adjust stuff other than the carb i'm just wanting to know before i jack it up.lol I just got my road hawgs 2 and 142oz steering servo in today (yahoo) next will be my rims and that darn aluminum mount piece for the suspension up front. This seems to be a wicked and fun little truck can't wait till i get it set-up.lol Thanks again
#174
can u help me stop my schumacher menace eatting its 1st gear it is eatting three sets of gears so far. i am f**k piss off [sm=angry_smile.gif] help me soon .
