Engines for the GT2
TN
Engines for the GT2
I am looking a good engine (cheap too) to drop into the Factory Team GT2. I am not real sure what will fit too. Will a Traxxas 2.5R fit? (I found one new real cheap) But it calls for a rotary carb and the 2.5R has a slide. It also calls for an SG shaft. So what do I do?
MN
RE: Engines for the GT2
I think the rotary/slide issue could be worked out with some linkage, but the traxxas engines have their own shaft length, if I'm not mistaken.
TN
Are those engines ROAR Legal? I have not raced yet, but I would really like to get into it, so I would like to get an engine that I could use.
OH
Baker, go to www.topspeedtoys.com and check out the ST12R. I'm running one in my XXXNT AD2, and it's easily the meanest engine I've ever run in a stadium truck...and it's dirt cheap too. it's a pain in the butt during breakin, but once you're past that, it's a nice solid reliable mill.
what track are you gonna be racing at? the one in Jackson?
GA
If you are going to race sanction racing do as TBJ said and get the STS and a starter box. No if I am not mistaken you cannot run anything over a .12 in Roar. You can go to there web site and check the rules out.
IL
ORIGINAL: ThunderbirdJunkie
GA
ORIGINAL: Valve
That's how all STS engines are, but after a couple gallons of fuel they REALLY wake up. Some of the best engines for the price in my opinion. Nova Rossis, Collaris, OS', Piccos... they are are great engines but their prices can be insane.
TN
Thanks for the STS tip. I had never heard of those, but I really like the price! That looks like what I'll go with.
Thunder, as far as a track, I am not sure...there was a track on Hwy 70 in Memphis, but it ran into zoning issues. Supposedly another track is being built in Memphis. I also know a guy that has a real nice dirt oval.
TN
I was reading about the GT2 and the STS ST12R. From what I have found, the GT2 requires a rotary carb and the ST12R has a slide carb. Does STS offer a rotary card for the ST12R or can another carb fit? According to the review in the Dec issue of XRCC, the GT2 has a kinda specific carb need.
From slide to rotary car is a matter of turning the servo 180 degrees. The traxxas rustler runs both types of carbs. I used the linkage kit from the rustler to mount a slide carb into my rush evo. I would think the same deal could be done for the sts in a rc10gt2.
The sts I had wasnt worth the packing it was shipped in, mine was a .28 for my truggy. Might look into a RB v12 or the OS .12tz engines. I own one of each and the perform very well every weekend.
CA
From what ive seen and been told.The stock manifold is for rear exaust engines.Also rotary is what you want to go on off-road.Im pretty sure the stock setup is with SG shaft??
OH
ORIGINAL: baker0408
Sorry I didn't get on here to answer your question for ya, but there are no rotary carb STS motors, but if you snag a Losi linkage kit that'll keep your headaches down. My XXXNT AD2's linkages had the option of slide or rotary carb out of the box, but since I don't have a GT2 I can't speak for GT2 owners (although within the next year, I'm planning on adding one to my stable)
also, ca$h, IIRC the GT2 is compatible with SG, standard or a cut crank. I know the old RC10GT could run an SG OR a cut crank, but the standard crank makes me assume they went to a Losi-style clutch nut, since if you run a GT style clutch setup on the XXXNT you can run a cut crank.
I would like to have a rotary carb, personally, but I've only run slide in my AD2 and it's perfectly fine...a bit snappy for a 2wd off road truck, but you get used to it and you can also tone it down with transmitter adjustments.
