-=OFFICIAL HPI FIRESTORM THREAD=-
#4651
RE: -=OFFICIAL HPI FIRESTORM THREAD=-
hey guys, just wondering what a good set of street tires would be for this thing. im gonna use the stock tire/wheel setup for off-road, but would like a set of on-road tires to go with it as well
#4653
XJWELL, he's speaking of the clutch-shoe holder spring. Its inside of the clutch bel and surrounds your clutch shoes allowing them to open and close when on or off the power.
#4654
ON, CANADA
ORIGINAL: hollow_point
#4655
i was looking at a new engine for my firestorm and i picked the O.S. 21VG(P) ABL 21F Slide Carburetor what elce will i need for my big block convrsion? is this a good engine? and many people said i will need to shim my diffs where do i get these shims whats the part number. also how fast do you think my car will go wit hthis engien and stock gearing.
#4656
ORIGINAL: nitro-rob
Proline Road Rage II tires are pretty good. Remember that street tires usually have a lower profile so you will lose some speed and gain acceleration.
#4657
Hey guys, how well does this radio system work in the firestorm. Thanks [link]http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXWPW0&P=0[/link]
#4658
ON, CANADA
ORIGINAL: manuel frias
I just put that engine in my firestorm. Read the past twenty pages or so, there has been a lot of discussion about big block conversions including gearing and differentials.
#4659
ON, CANADA
ORIGINAL: tomtom9649
#4660
Seems like this shouldnt be the official Firestorm thread, maybe the official BIGBLOCK Firestorm thread! I love it, everyones gettin into the BB game. TOMTOM, I was looking at that system myself. Should work fine, if you get one let us know how you like it.
#4661
ON, CANADA
ORIGINAL: wileecoyote
#4662
ORIGINAL: HPIguy597
I'm using the Proline Speed Hawgs. They dont get much traction, but aregreat for slides and drifts!
ORIGINAL: nitro-rob
#4663
NITROROB, That is a great idea. I know its alot of work and since your looking for time to drive it would be last up. I thought of creating a file with all the little tricks Ive learned as well as settings, ideas and so forth. Then I could link it so others could see it. Im not so sure I know how to do it all but maybe you do? Just a thought. I really have been taught quite a bit here on the forum and think it has made me a better RC'er all the way around. So with that in mind, THANKYOU ALL! Pretty cool. Iam real close to being able to break in the new motor. Had to mount the exhaust in an unorthodox way, (well not really) it keeps the stock body from fitting. Im going to try my hand at making a roll cage. Then probably just run the truck like that. How has yours progressed? You had mentioned having power to spare, I am sooo wanting to tap into the top end of the Axial motor! Ill be keeping it on road like the RWARRIOR did. Im trying to convince the locals at the track to allow me to run with them. I would get my ass kicked for awhile at least until I got the handling down. For right now Im reserved to being a speed junkie.
#4664
ON, CANADA
My truck is at the stage where its done and broken in with little more that I will do to it. Complete happiness. I have a few more aluminum parts to come in and want a better header, but other than that I don't foresee any more changes. Its a great basher and all my fears of an unmanageable and unreliable truck have vanished (knock on wood). My next step is to work on my savage which has some aftermarket on in but not nearly enough and just enjoy the storm as it is unless RPM or somebody gets their act together and makes cool shock towers and A-arms. Any other suggestions for mods are welcome, I'm pretty stumped right now.
Its been raining so I didn't get a chance to take the truck out and get some video....this week.
#4665
hey i have a slight problem with my car i went to take off the cooling head to replace it with a nova racing cooling head put my alen key ball end snapped in the bolt and is stuck in there anyone have any ideas how i wud remove it and can any1 tell me how to make it easier in the future i think i might need to drill it out but dont want to make a any big dissisions and end up screwing the engine up many thanks
#4666
just curious as to how long it took you guys to break in your firestorm. i should be getting mine this week sometime and was just looking at what to expect in terms of break in times
#4667
So now I need a new pipe and a egzost header for my o.s 21vg engine do you guys know of the most inaxpensive pipe and header that will fit.
#4668
#4669
ON, CANADA
ORIGINAL: shori1992
I picked up a DX3s today and can't wait to use it.
#4670
ON, CANADA
Regardless of how you break the engine in, it will take half a gallon to be truly freed up. Don't rush it (ask Road Warrior).
#4671
thanks for the info, i may try the break in method you posted. theres a bunch of them out there and i just dont know what is the best. ill take a look at the manual as well when i get it. as for bdc, what is the importance of the piston being at the bottom of the sleeve after you run the engine? the way that it was described in the article helped me to figure out how to get the piston at bdc, but not as to why it must be there after each run
#4672
ON, CANADA
The cylinder is tapered at the top and if the piston is left there when the engine cools it will no be able to contract to its proper size and eventually will be 'stretched'. When a piston and sleeve have too much tolerance its usually because the taper has been widened too far and you can get this pinched back into the ideal size again. The key to a well broken engine is to have the taper expand at operating temperature to produce a good seal with the piston. If the engine is broken in cool it will shave more off the cylinder or piston and then when its run at high temperature the extra expansion will lead to a lower tolerance between them.
#4673
yea i just figured that out after reading on the topic a bit more. makes much more sense now and i can see the physics behind it. im guessing once u make the mark on the flywheel, u just manually turn the wheels after a run and line up the mark on the flywheel to get it to bdc?
#4674
ON, CANADA
You have to turn the flywheel to get to BDC. Its pretty obvious from turning the flywheel where BDC is just by feel. You don't need to be right at the bottom, just not in the taper which can be felt.
#4675
makes sense, thanks a lot. and ive heard it is pretty easy by feel to tell where the piston is in the sleeve so its prob not as difficult as i think it is
