If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 18 of 265 FirstFirst ... 816171819202868118 ... LastLast
Results 426 to 450 of 6605
  1. #426
    Join Date
    Mar 2006
    edgewater, MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: -=OFFICIAL HPI FIRESTORM THREAD=-
    alright, thanks. One last thing though, ow is the stock steering servo? Its only 40 oz and that doesnt seem like enough to me..
    hey baby
  2. #427
    dapro's Avatar
    Join Date
    Feb 2006
    Seligman, MO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    junk, I have a 645mg on mine and its awesome, the stock servo seems ok for the throttle, throw the steering servo in your box as a backup
    Unless your post is tried, tested, and true personally, don\'\'\'\'\'\'\'\'t post your \"Well this guy told me\" crap.
  3. #428
    Join Date
    Feb 2007
    Whatever
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Finally a review of the firestorm
    Firestorm review
  4. #429
    keepontruckin's Avatar
    Join Date
    Feb 2007
    East Hanover, NJ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    i just ordered one of these on Sunday, it should be in by tommorrow!!!!!!!!!!!!
    what break-in procedure should i use, i have used the traxxas procedure on every other nitro engine i have had, however they have all been traxxas engines.
    -first tank (idle/or no idle) i have heard both sides of this many times (so yes/or no)
    -Traxxas Stampede XL-5-T-MAXX w2.5r-Traxxas Nitro 4-Tec 3.3-HPI Firestorm 10T - TT-01 Nismo Coppermix Silvia-Losi Micro
  5. #430
    Join Date
    Feb 2007
    Whatever
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    it will explain how to break it in, in the manual
  6. #431
    dapro's Avatar
    Join Date
    Feb 2006
    Seligman, MO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: keepontruckin
    take your pick, everyone does different, I personally heat cycle 4 tanks thru then start running the motor, I am easy for a few tanks then its ready...I'm pushing 9 gallons on a picco 27 and its still a beast, you can tell a difference in another picco 27 I have with only 4 gallons on it, but it still hauls, and has awesome power....I have all new parts and bearing to restore its youthful self when the time comes
    if you have had good luck with the traxxas method then use it...if you have to replace the piston and sleeve in a couple gallons then I wouldn't use that method anymore
    ALSO congrates on the purchase, great truck
  7. #432
    dapro's Avatar
    Join Date
    Feb 2006
    Seligman, MO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Anyone else racing EDM Dirt OVAL with this truck???
  8. #433
    Join Date
    Feb 2007
    Whatever
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    would someone explain the heat cycle method to me please
  9. #434
    rclynx's Avatar
    Join Date
    Sep 2006
    Modesto, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    use the break in that is described in your manuel man, Heat cycling is used more in air plane engines than the cars and thats only because there was no way to put a load on the engine[:'(]
    Custom Cars bring out the stars / Home of the RCLYNX, RC IMPROVEMENT, MOD, SALES & SERVICE Dealer;XTM, CEN, HPI & much more
  10. #435
    Join Date
    Feb 2007
    Whatever
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    i did, but i am curious as to what it is
  11. #436
    rdt45's Avatar
    Join Date
    Nov 2003
    Valparaiso, IN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Here's a copy of the heat cycle method........
    Engine Tempering & Engine Breakin
    Reprinted From S-Grid with Stephen Bess's permission
    If you are still idling at least a tank through during break-in, you're using the old-school accepted method (still works well for some!) but it's not the method that the top engine guys (Ron Paris, Dennis Richey, Rody Roem, Michael Salven are just a few I've spoken personally with about this) recommend anymore.
    From the very 1st time you start your engine, plop the car on the ground & begin running it in a parking lot in 2-3 minute intervals, tuned only *slightly rich* getting the temps up in the 200F range on a normal day. Every 2-3 minutes, shut the engine down & let it cool completely with the piston at BDC, and then fire it back up; continue this cycle until you've run 15 min or so, and then bump up to 3-4 minute intervals. Vary the RPM and don't be afraid to get the temps in the 200's. What you want is heat cycling of the components without the incredible stress that comes with breaking an engine in when it's overly rich & cold. After cycling the engine in this manner for about 20-25 total minutes, it'll be ready for the track and race tuning. I realize this method goes against the old-school "idle on the box" routine, but you'll be amazed once you've completed this break-in routine, your engine will still have amazing pinch w/out sticking at the top AND your engine's compression will last far longer than it will with the "old school" method.
    You say you run the engine at "factory settings" for the first FIVE tanks? That alone causes lots of stress, as the factory engine settings are very rich on every engine I've ever owned or tuned. The piston & sleeve haven't expanded to operating temps, and every time the engine turns over, the piston slams into the pinch zone at TDC. The not-so-surprising result can be a cracked con-rod at the crank pin--that's where the majority of the stresses occur as the engine turns over. I've only heard of about 6-8 engines breaking con-rods, and they're ALWAYS during the first gallon...and almost every time it's because the guys have performed the break-in procedure you described. Doesn't seem like a mystery as to why it's happening. Drawing out the break-in routine really stresses the engine & actually wears away compression along the way. This method I've outlined will feel weird at every step, but after you try it once, you'll notice a big difference in your engine's performance & lifespan.
    Rick Brake RB Mods
    Hope this helps; give this break-in method a shot--you have nothing to gain except longer life & more power
    Savage X STS D30M A.I., Nova shock towers, Hardened clutch/spur, Alu. shocks
    Firestorm
  12. #437
    Join Date
    Apr 2007
    bremerton, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    what is the first upgrade that i should get for my firestorm that would help get better performance
  13. #438
    Join Date
    Feb 2007
    Whatever
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    clutch bells
    the 21 tooth rocks in my opinion, you still get wheelies and it is stupid fast
  14. #439
    Join Date
    Jan 2005
    San Antonio, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Me and my brother's firestorms at a local park, taller grass slowed cars a bit in spots, video is just over eighteen min. http://www.rcuvideos.com/item/6CNVKV1HG6TZLWB4
  15. #440
    Join Date
    Jan 2005
    San Antonio, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Here is another video it's a lot shorter and has music. http://media.putfile.com/two-firestorms-in-the-park
  16. #441
    Join Date
    Apr 2005
    Corning, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Looks like tons of fun!
    I want one!
  17. #442
    Join Date
    Mar 2007
    paramus, NJ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I'm new to the hobby and had only had my firestorm for a week when it ran out of range and right in to a car tire. the truck fell in 2 pieces. not as bad as i thought, but one of the 4 parts ordered is taking 2 weeks to be in stock. it was running great can't wait to get back out
  18. #443
    aaront's Avatar
    Join Date
    Apr 2007
    Eugene, OR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Has anybody done anything to improve their suspension? Different shocks, oil, etc. How about swaybars?
  19. #444
    Join Date
    Jun 2005
    va beach, VA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Mrballzy I haven't broken anything but the front bulkhead on mine but I have broken several parts on my new turmoil so I know how it goes. The turmoil has just had allot of weird landings. aaront I put 30 wt oil in my shocks and it seems to have helped but I haven't ran it at the track yet.
  20. #445
    Join Date
    Feb 2007
    Whatever
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    different oil for the shocks, thats about it
  21. #446
    rclynx's Avatar
    Join Date
    Sep 2006
    Modesto, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Its a good little truck and its all about set up for the track your on rather than hop ups. But its always nice to add a little personal BLING to it
  22. #447
    Rallye_10t's Avatar
    Join Date
    Mar 2007
    Amlwch, North Wales, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Here are some photos of my Firestorm with a twist
  23. #448
    aaront's Avatar
    Join Date
    Apr 2007
    Eugene, OR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I'm a big fan of rally racing. That is definitely a twist. I like it!
  24. #449
    Join Date
    Jan 2007
    wichita, KS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    i am thinking about buying one i herd ppl every were saying they are a peicce of **** but after talking to my friends i am going to buy one in a few days ,,yeaaa
    aint racing unless you break something ,
  25. #450
    Join Date
    Jan 2007
    wichita, KS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    were is the chepest place to get an firestorm 10t
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
