-=OFFICIAL HPI FIRESTORM THREAD=-
#1501
MO
RE: -=OFFICIAL HPI FIRESTORM THREAD=-
has anyone driven an rc10gt2 and a firestorm? i know one is for bashing and one is a racer. but i just want one final say in my choice with the firestorm.
#1504
PA
After running my Firestorm for about 3 tanks after break-in, I decided it might benefit from better weight distribution since the rear tended to carry a spin like a Porsche. I moved the battery pack to where the receiver was. Next I'll protect the reciever.
What I'd like for the the car is a step-up in wheel and tire size and a diff fluid that would give it more limited slip properties. Anyone help?
#1507
Very nice.
My clutch bell and wheels came in today.
Can't wait to get home and run it some.
Too bad i only got like 1 tank of fuel left..
#1508
Whenever i wasp utting on my new clutch bell, i noticed the stock one had turned purplish, like it turns form extreme heat.
Is this normal?
Is this normal?
#1512
PA
Check it out!I beat my own record of ten ft. of air to 15 ft.!This thing handles great in the air with the moabs! http://s258.photobucket.com/albums/h...estormBash.flv
#1513
Hey what temps are you dude's getting? Mine wants to run 250 or 260 especially in grass and I haven't even really dropped the needles much at all from stock locations, and it's not even hot outside.
#1515
IL
the battery compartment on my car was pinching the wires from the battery holder, and ended up severing the red wire. Is there an easy way to rejoin the two halves, or do I have to buy a new pack?
#1518
So, driving around today, and after like 5 mins(just was enjoying the new 2t clutch bell effects), i flipped, and hit the right rear wheel wrong, and it broke one of the pieces that holds the arm to the pin.
Also cracked the front bulkhead (both pieces).
Are these parts that would be good to upgrade to aluminum? as i know aluminum can sometimes to more bad than good.
#1519
PA
The bulkhead should be aluminum and after you have an aluminum bulkhead,then you can get aluminum a-arms.I would rather recommend rpm a-arms(once they are in stock),but the bulkhead should definitly be aluminum.
#1521
PA
Sorry,I forgot to mention www.neweramodels.com .This is somthing you might want from them: http://www.neweramodels.com/item.cgi...=&part_id=8908
#1522
Thanks a bunch for that link nate.
Question though, that is jsut the support piece right? What about the actual bulkhead?
Is this a replacement for the actual bulkhead http://www.apexmodels.com/product-se...ries&id=13130?
Actually, i think i'll jsut get the stock bulkhead set, and than that brace peice. Should be good after that.
#1523
PA
This: http://www3.towerhobbies.com/cgi-bin...&I=LXPZE1&P=OW and this: http://www.neweramodels.com/item.cgi...=&part_id=8908 will give you a very strong front end.After you have all that,you should get the alloy a-arms from neweramodels.
I'm not sure that an aluminum bulkhead is made yet,but I'm keeping my eye on new era.
#1525
In my opinion... If you install a Front Chassis Reinforcing Plate for bashing and then hit something "again", You will damage some other parts, maybe more expensive than a factory bulkhead set or even the engine. I'm sure there's a reason for the "flexible" front chassis installed by HPI...
But!! it is a good upgrade for racing, beacuse it reinforces the front-end for more accurate suspension/steering tuning on the track.
mig
mig
