If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 91 of 265 FirstFirst ... 41818990919293101141191 ... LastLast
Results 2,251 to 2,275 of 6606
  1. #2251
    windowlicker's Avatar
    Join Date
    Feb 2008
    Barton, North Lincolnshire, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: -=OFFICIAL HPI FIRESTORM THREAD=-
    the high and low needles need to be set to flush, the idle doesn't have a setting really. To set the idle needle, pull off the air filter so you can see down the carb, adjust the needle (with the engine off but the electronics on) so that the carb is always open at least 1mm, even when braking.
    Simple as that! Try downloading the Firestorm manual for HPIs website, will save you a lot of time asking around on here. There are many basic setups which are in the manual.
    On a separate note, I was setting up my idle and carb settings yesterday after an engine tear down, and noticed that the linkages on my throttle servo do not pull my carb fully open under WOT. It seems the throttle servo horn is not quite long enough to pull the carb fully open. I only get about 80% open! And yes, I played around with the linkages etc, I know it is just down the to servo arm length.
    I think I might have a go at trying to extend my servo arm so I can get a 100% open carb, hopefully here is some performance I have been missing!
    Anyone else noticed this?
    Hellfire SS - GO .25 - DX3R - 5955TG - 5645MG - Speedtech Carbon
  2. #2252
    Join Date
    Sep 2007
    , MN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    when pick up the back wheels they spin in opp direction fine when i put the truck on the ground and push it forward or back it moves but i have to push really hard put if i pull the pull start out it will roll fine until it goes all the way in then it pushs hard again
  3. #2253
    Join Date
    Feb 2008
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    sounds like the diff is broken, strip it down and see
  4. #2254
    Join Date
    Sep 2007
    , MN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    never done that before d you have any tips
  5. #2255
    maty b's Avatar
    Join Date
    Aug 2007
    ipswich, TOGO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    thanks for the tuning tip, i managed to get my firestorm working again! My situation is that the truck goes really well atm, but it does seem to be using quite alot of fuel and more smoke is coming out of the exhaust than i would have expected when it is tuned, but when i lean it out the engine just cuts off when i accellerate.
    Do u think i shud leave it as it is, or try to improve the fuel comsumption?
    cheers
    92% of teens have switched to rap music if you are part of the other 8% put this in your sig.
  6. #2256
    tcv_racing's Avatar
    Join Date
    Mar 2008
    zama, JAPAN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Father's day gift from my wife... Ain't that sweet?
    -Front and rear composite arms
    -Teflon clutch and spring set
    -Set of drift wheels and tires for my drift car
    HPI Firestorm 10T
    Tamiya TT01 Rally
  7. #2257
    tcv_racing's Avatar
    Join Date
    Mar 2008
    zama, JAPAN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Will this work with the storm? http://www3.towerhobbies.com/cgi-bin...&I=LXFXU7&P=SM
    My LHS didn't have the savage 2pc clutch set that Yakfish suggested on page 88..
    HPI Firestorm 10T
    Tamiya TT01 Rally
  8. #2258
    Join Date
    Feb 2008
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    nope, you need a flywheel with three posts on, the storm has a two post flywheel for a two piece clutch
  9. #2259
    NitroNate's Avatar
    Join Date
    Jul 2007
    Honeybrook, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    TVC,thats SWEET!
    I'm still trying to figure out if those composite a-arms are for racing ONLY.Stiffer nylon tends to snap easier don't they??Obviously not,according to RPM....[sm=confused.gif]Is HPI going to start developing a RPM alternative or what!
    BREWING UP A STORM
    HPI Firestorm W/CV-RX = Tank/Greased Lighting
  10. #2260
    NitroNate's Avatar
    Join Date
    Jul 2007
    Honeybrook, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: windowlicker
    Couldn't he just leave one piece out??
    BREWING UP A STORM
  11. #2261
    Join Date
    Feb 2008
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    could try, but I doubt it will make up a full circle, or the they might not have the right curve (from being a different diameter when put together)
  12. #2262
    Join Date
    Feb 2008
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    So, anyone else noticed they cant get the carb opened fully with the stock linkages? Mine couldnt get 100% open without screwing the idle needle right in. So I added about 4mm to the length of my servo arm and now I get full throttle!
  13. #2263
    tcv_racing's Avatar
    Join Date
    Mar 2008
    zama, JAPAN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Does the 2 piece savage clutch set forms a full circle when installed in a firestorm flywheel??
    I already installed the 2 pieces from the 3pc set and it doesn't form a full circle, Is that bad? should I try running it?
    HPI Firestorm 10T
    Tamiya TT01 Rally
  14. #2264
    tcv_racing's Avatar
    Join Date
    Mar 2008
    zama, JAPAN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Okay I just got back, I tried running the new clutch and here are the results:
    1. Idles perfectly, meaning the clutch shoes does not touch the clutch bell during idle..
    2. The springs that came with the 3pc clutch set are too hard for the storm, the clutch shoe engages the clutch bell softly at LOW rpm resulting to a little bit poor acceleration.. You can hear the sound of the cluth slipping inside the bell (wissing sound)..
    3. At MID and HIGH rpm the clutch shoe engages the clutch bell hard, the diffrence with the stock clutch are now very noticable.. At this point you can really feel all the power from the engine are fully transfered to the transmission.. Wheelies when you floor it after exiting a turn! Damn! these teflon clutch are great!
    This are initial results only, performance may vary after the clutch shoe are fully settled and or sitted.. Will post results again after 2-3 tanks of run..
    HPI Firestorm 10T
    Tamiya TT01 Rally
  15. #2265
    Join Date
    Jun 2008
    Forney, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Anyone know how to get the storm to turn a little better? seems like mine dont have a good turn radius..any idea's or adjustments to make it turn better..thanks!!
  16. #2266
    Join Date
    Jun 2008
    chandler, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    yeah im having trouble with that too.
  17. #2267
    Join Date
    Feb 2008
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    tighten your servo saver, and on your transmitter adjust the d/r knob till you get better response from the steering. Check your batteries or hump pack are full
    If you're still not happy, get a better servo
  18. #2268
    yakfish's Avatar
    Join Date
    Feb 2008
    Fairborn, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Yeah a high torque servo will make a world of difference. try this one here
    http://www3.towerhobbies.com/cgi-bin...&I=LXDWF8&P=SM or this one http://www3.towerhobbies.com/cgi-bin...&I=LXUZ89&P=SM
    the hitech has a bit more power and is a little cheaper too.
  19. #2269
    NitroNate's Avatar
    Join Date
    Jul 2007
    Honeybrook, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    A high torque steering servo won't effect the radius.It will effect Mid and High speed turns.
    BREWING UP A STORM
  20. #2270
    Join Date
    Feb 2005
    Buffalo, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Put some thicker oil in your diff. Turning is greatly improved.
    I'm currently using 10W 40 motor oil in my diff and it turns on a dime. Off-throttle it turns a little bit too hard and is very easy to oversteer, but fun to catch by getting back on the throttle.
    Try it, it's a cheap thing to try.
  21. #2271
    mojavemonster's Avatar
    Join Date
    Feb 2007
    , CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hey Y'all. I'm lookin for a 13t diff pinion with a 6mm shank to match up with my hellfire 43t diff. Its all goin in a Mad Force axle. Everything seems to be 8mm. Need help.
    Creator of......Project Hard-CORR
  22. #2272
    Join Date
    Feb 2008
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    WHAT?
    Is this for a firestorm or hellfire? if hellfire you want the hellfire thread in the truggy forum...
  23. #2273
    Join Date
    Feb 2008
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I know how everyone loves a few photos, I know I do!
    Here are a few I just took of my Firestorm with its road setup, you can see the mod I did to the throttle servo arm to make sure I was getting 100% open carb while full throttle. I found my servo horn wasn't long enough to pull the carb fully open. It flies now, have a 21 tooth clutch bell and it nearly wheelies with the stock engine.
    Got my temps to be around 250, as I know a few people have said that the HPI recommendations are a little conservative, which I suppose is so they don't get loads of returns from people leaning out too much. Anyway, there is plenty of smoke at all rev ranges, no bogging, and the pinch test shows my low speed is about perfect too.
    Finally got my Firestorm running just how I want it!
  24. #2274
    Join Date
    Sep 2007
    , MN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    please help my rear wheels have locked up i did check the diff and found nothing when i pick up the wheels they spin fine but when i put them back on the ground it will not mouve dis connected the brack same thing help???
  25. #2275
    Join Date
    Feb 2005
    Buffalo, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: scobeh
    You need to get better at asking questions. I barely understand you, how do you expect us to help you like that?
    Did you open the transmission case and check the gears? When you say it will not move on the ground... with the engine running? or trying to move it by hand?
    If it's with the engine running and revving without moving, it's your clutch.
    If it's with the engine off and you can't move it, it's the transmission/Driveline/Brakes. Use your manual to help you identify parts and check them.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
