rush evo keeps choking not running well
hi there
just wondering if anyone can help my rush evo is being a pain in the butt . after ive started the truck after about 2 mins it starts to choke as if it too rich . but ive reseted back to factory settings and started again and it still happens. another thing is that when it goes ok not very often lol. the revs seem to high for the speed of the truck as if its slipping but ihave put a new slipper cluch on and it still happens. tightened it up to
hope u can help cheers
RE: rush evo keeps choking not running well
hi fuel is duraglow 16% , and even if i lean it out till sounds like its choking number 3 glowplug
cheers
cheers
20% with a #5 that should fix it.
try patriot, it stinks like old lady perfume and hot canola oil when its tuned OK,and if its rich your eyes will burn..lol
tighten up your slipper. check out the rush evo thread for more tips. Many pages of useful info and other folks with their troubles and tuning tips.
CA
When you change back to factory settings, you're basically making it run rich. Factory settings are what you're supposed to start tuning from.
hi there just come back now and the car seems to be going fine until the slipper started slipping again . so i changed the slipper pad for a new one still happens tightned it right the way up still happens, not sure what to do. . i changed my glo plug for an old one i have doesnt seem to be as bad with the old one in . so i will need to find out what make it is and number. . what should i do with this slipper the parts are new so shouldnt really be slipping .
many thanks twin-dragons
try puting a piece of 1000grit water paper in between the pad and hub.... that fix worked wonders for me, i'm still running my rush like that even after i bought a new spur and hd hub...
