New Kyosho 1/10 4WD DST/DBX
#51
PA
RE: Kyosho 1/10 4WD Truggy ' DST '
Just got my DST today looks great seems real solid. It's only 18 degrees here so it will be a little while before break in. I'll post another opinion after break in.
#52
Hi TheKaiman,
u mean 18°F ? it seems not ... I did mine when the temp was approx 2 or 3°C (+/- 38°F)... and no probs ..?!
is it a real prob ?
later
is it a real prob ?
later
#54
PA
I've done cold weather break in before. It's just I don't want to stand outside and freeze. Mama didn't raise no fool. lol. Supposed to get into the mid forties this weekend so I will try then.
#56
Hi there,
What kind of tires could I put on the DBX ? except the original one of course...(which are really hard to find!)
Mines are in good condition, but I plan to use the car on asphalt road.
Thanks for ur help !
bye
bye
#57
CO
any 2.2 tires should work, just find what you like. if i was going to buy tires for asphault and concrete i would pick the pro line road rages.
#58
here you go :
http://www.hpieurope.com/piw.php?lang=en&partNo=4450
http://www.pro-lineracing.com/produc...wproduct&id=10
http://www.pro-lineracing.com/produc...wproduct&id=16
#59
Any idea of what kind of stronger strings could I mount on original shocks absorber ?
I just change the oil, and now stronger string would be welcome.
#60
My DBX stock throttle servo just suddenly death after play 2 tanks in this morning.
I notice that to all DBX/DST owners better change the servos b4 play.
#63
This looks interesting... Have a few questions for you owners.
Were do you get parts (in U.S)?
How does the engine run?
I am looking at the Kyosho DST by the way. Thanks for any info
#64
ORIGINAL: Dokioto
The parts on the DBX will fit on the SX?
#71
OH
This has 3 diffs, so gettin power to the ground is improved dramaticly. Compared more to an 1/8 buggy, and once suspension is tuned should run with an 1/8 scale buggy. My CRT.5 does, well not exactly same speed no more than a second in 20-21 second laps. I expect good performance from this and looking at it closely.
Just kinda curious how much of some aftermarket products will fit, does proline make a rim for it, will it take a rear exhaust engine since more of those are being built than side exhaust, can manifold be changed to a better design, things like that.
#72
Someone have tested different shock absorber on the dbx/dst ? or maybe only the springs ? a little bit too soft on the stock one...
Thanks!
Thanks!
#75
RE: New Kyosho 1/10 4WD DST/DBX
ORIGINAL: helium66
Hello when I am french regrettable for the spelling I would like to know you were on this filter please
http://www3.towerhobbies.com/cgi-bin...FVSEARCH=87207
