If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 7 of 7
  1. #1
    zud00's Avatar
    Join Date
    Jan 2007
    Warren, IN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Carb/brakes question
    On my GTX (i am still breaking it in) i pulled the air filter off to check the gap for idle and whatnot. it seems fine, but when i apply the brakes, the carb closes. Sure enough, when I tried to apply the breaks while it was running, it proceeded to stall.
    My question is...is there a proper way to set up the linkage so that the carb does not close when I brake? I wouldn't think it should move when I apply the brakes, it should only go back to the idle setting, but that's just my thought of how it should be.
    Savage X w/LRP z28 spec 3
    Bash Big or Go Home!!!
  2. #2
    MORE SPEED's Avatar
    Join Date
    Sep 2007
    Kingsbridge, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Carb/brakes question
    On the carb, turn up the idle screw until that when you brake, it doesn't dip the revs and/or stall.
    MORE SPEED
    If you aren\'\'t driving on the edge, your taking up too much room!!
  3. #3
    zud00's Avatar
    Join Date
    Jan 2007
    Warren, IN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I adjusted the idle needle and now the carb stays open when i brake. Thanks for the tip. NOw i just need to figure out how to get the brakes to work.
    I'm guessing I need to mess with the linkage. Anyoine have a tip on how to get the linkage set up for good braking power?
  4. #4
    DaveG55's Avatar
    Join Date
    Jan 2005
    Stockbridge, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I don't know about the MGT speciffically but I can tell you generally how I set up all my nitro vehicles.
    First, take the linkage off the carb.
    While holding the carb lightly closed with one hand screw the idle screw in (to increase the gap) or out (to decrease the gap) until the idle gap is between 1mm & 2mm wide.
    Now set the throttle trim knob on the transmitter. I prefer to set it in the middle so I can bump up the idle or add a bit of brakes with the trim. Others prefer it set it all the way left to give them more idle adjstment.
    Turn on the radio in the truck and at the transmitter.
    Now reconnect the linkage to the carb.
    Adjust it so that the part that activates the throttle is barely touching what it pulls/pushes against w/o touchng the throttle.
    Now adjust the part of the linkage that activates the brake so that w/o touching the throttle there is no brake applied but so that when you fully apply the brake you get maximum preasure applied. The brake adjustment can be the tricky part as sometimes you need to change the spring (or fuel tubing) to get it to perform the way you want.
    Any technology, sufficiently advanced, will appear as magic
  5. #5
    zud00's Avatar
    Join Date
    Jan 2007
    Warren, IN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I think I have it set up right because now when I brake, the carb doesn't close, infact it doesn't even close a bit. When I had it runnning and then braked, the revs didn't dip any either, so I guess that is good. However, these brakes really suck. I guess I just need to make some adjustments to the linkage.
  6. #6
    Join Date
    Jun 2007
    Chinnor, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I dont know the GTX either, but you might need to tighten up the brake plates/shoes.
    I had to this on my Firestorm. Its a very fine adjustment to get them biting when you want with no drag.
    Hyper St PRO - Go .25, Dynamite Linkages, Craddock Anti-Lock, DS1010 (Str) Spektrum DX3
    Firestorm - Stock, Spektrum DX3
  7. #7
    Join Date
    Sep 2004
    Marseilles, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I`ve had a few GTX`s back when they came out . On the rod going to the brake arm , there will be two collers with set screws in them . The one closest to the shock tower is the one that will give you more brake . Move the coller forward a bit and then try your brakes and go from there and so on . Depending on where you set the other coller[the one closest to the engine] , you might need to move it forward a bit to have the room to move the rear one . This should get you in the right place and adjust to your liking .
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
