Custom HPI Rush Evo with TRX 3.3 out of JATO
HPI Rush Evo with TRX 3.3 out of JATO let me know what you think?? Any improvements suggestions welcome. The car already accelerates quicker than my JATO 3.3 with upgraded exhaust. This car is very custom i made it from a rolling chassis of a RUSH EVO and whacked a spare TRX 3.3 engine in it. Baring in mind im only 16 i think this is pretty good for a first time custom build. I only realy posted to share my creation and to see what you think?
Here are a few pictures enjoy:
RE: Custom HPI Rush Evo with TRX 3.3 out of JATO
nice build
but i think you wil get problems with the transmission, and with flexing in the chassy because you have removed some important stuff:/
Thanks xhaliex for the feedback
Your absolutely right it tends 2 flex a lot, needs 2 be braced properly, workin on the desgins at the moment. Any suggestions?
The first time i took it out i floored the throttle and it sat still and whizzed. I thought the gear box had dropped out of the bottom, but gears were fine! surprisingly the clutch needed a tighten! iv had 4 tanks through the car and the gear box is still fine thanks to the metal gears and a bit of give in the clutch, although i don't expect it to last long!
Banned
My Feedback: (-3)
I give you mad props for being 16 and doing coming up with that.Most 40 year old couldnt do that.If i was you,i would find a Machine Shop close to your house.Have them take the measurements from the stock frame and make one,drill all the stock holes and etc...Then you would be set.But then have to beef up the tranny/clutch etc....Thats awesome man!!!
