O.S. 15CV-X w/10E Rotary Carb..will it run Rc10GT
RE: O.S. 15CV-X w/10E Rotary Carb..will it run Rc10GT
[img=http://img339.imageshack.us/img339/8659/osmg2034nn8.jpg]
this should be it right here..also i have a clutch bell with two plastic pieces for clutch inside held on by a c clamp. will that stuff fit?
<a href="http://tinypic.com" target="_blank"><img src="http://i12.tinypic.com/7xuavj8.jpg" border="0" alt="Image and video hosting by TinyPic"></a>
ive got one of those that i sometimes run in a losi xxxnt, but its not in the truck now, i have a .18 cvr in it right now.
its a very good little engine, mine even pulls wheelies on pavement,,,,,,,,,,,sometimes.
the pic you posted looks like that might be the standard crank, which means you might have to cut it down a little.
im not sure if that engine is available in the short crank version, and im pretty sure thats what you need.
i probally will end up sending it bakk and fixing my old motor. which is the old asciotiated .15...the problem is that it seizes a lil bit at the top of the engine with the piston..any ideas to help?
CA
Thats the exact motor in my Rc10GT So yes it will run great. You will have to cut the crank down though. Do you stilll have part 2 of the assem. instructions for the truck?? it shows exactly how to do it. Associated also makes a special cut off nut part #asc7620.
Get back to me if you need the manual, maybe i can download it to you.
Do you have the fly wheel yet?? Are you going to use pull-start or box?
Heres just a small list of Associated part numbers you have or may need:
asc7601 clutch shoes
asc7605 15 tooth cluch bell
asc7610 flywheel non-pull start
asc7612 flywheel pull start
These are stock from the catalog, you may aftermarket.
I will be using the pull start. I do have that flywheel and clutch shoes. will that flywheel fit it though?
CA
[quote]ORIGINAL: towtruckmikey
CA
Yea, ASC 7612 is the stock flywheel for this application. However if you can find part ASC 7611 its an even better flywheel used for racing, since it has 4 clutch shoes. Dont forget about your clutch bell and e-clip.
I added some pics to my previous post of my gt10 with the motor in it.
CA
I'm sorry but I dont know what you mean by the flywheel pivot. My motor came installed when I bought the truck used,but I have had my complete engine disassembled and dont recall that part.
I meant the Flywheel agjuster so it stays in place. its off my old GT..Anyways i don't think this O.S engine will fit with my old parts. Thnxx for your help........... HAPPY HOLLIDAYS!
