car stalls
AB, CANADA
RE: car stalls
What radio are you using? I know I have problems with my futaba 6ex it's made for aircraft and when I pull back to brake it's almost like it reverses the servo past idle and closes the carb right off like youwish16 had mentioned. If your using a stock radio I'd go with the idle is to low like youwish16 mentioned. Does the car idle when you first stat it.... Or do you need to control the throttle to keep it running...
CA
RE: car stalls
i need to control the throtle. i tuned my idle lots of times. i just got lazy and started using the controler. i guess that would be it.
RE: car stalls
so that just meens put ur radio at zero then tune the idle from there a 1mm -1.5 mm gap is appropiate i believe lol if not just look at ur manuel.
