If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 1 of 2 12 LastLast
Results 1 to 25 of 27
  1. #1
    Join Date
    Apr 2008
    NAPERVILLE, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Jato 3.3: Engine Tune
    When I aply brakes my car ussualy stals, or when i let go of the throttle and car is about to stop it stalls too.
    What should i do ???
    GO JATO OR GET LEFT BEHIND
  2. #2
    Join Date
    Mar 2007
    biddeford, ME
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Jato 3.3: Engine Tune
    your tank dry?too lean?bogs because it's to rich?....be more specific when you apply the brakes and stuff.there are multiple possibilities with that sort of problem
    traxxas nitro sport 2.5R
  3. #3
    Join Date
    Apr 2008
    NAPERVILLE, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    so ok iam ridding my car in da street or what ever, now i can go full throttle but the thing is when i try to totaly to stop my car stalls so in order for me to stop i have to apply the brakes 4 a little and the let go and do that couple time to stop when my car is going like 5 mph i try to turn 180 degreese i have to let go off the throttle thats when my car stalls, the fuel tank is full and it might be too rich or lean cuzz Im still learning how to tune cars
  4. #4
    avg_joe's Avatar
    Join Date
    May 2004
    Pennock, MN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Sounds like your idle is too low.
    If it just slows down too much and shuts off, it's probably the idle.
    If it blubbers, 4-strokes, and sounds wet, then it's probably a slightly rich lsn.
    I always knew it was a good idea to keep all this junk...If only I could find that part in all this junk...q;\\
  5. #5
    Join Date
    Apr 2008
    NAPERVILLE, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    yeah it does sound like a rich engine too me too, but which screw should i turn the high speed or the low ???
  6. #6
    Join Date
    Feb 2007
    , VA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    LSN controls your fuel delievery at idle, turn it in a tiny bit at a time to see if it gets better(lean it out). Watch for smoke on acceleration, too much means your needs are rich. I would suggest a temp guage if your need to tuning, it could save you a motor and help you understand how to tune.
    75% driver/50% set up/-25% vehicle=My kind of race.
    Knowledge is power/knowing what to do with it=win
  7. #7
    Join Date
    Mar 2008
    newfane, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Just remember lean is mean
  8. #8
    Join Date
    Apr 2008
    NAPERVILLE, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    So if i get the temp guage how would it help me ??? Is there like a tuning by temp ??
  9. #9
    Join Date
    Feb 2007
    , VA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    A temp gauge will help you if your new to tuning by giving you another way of seeing if your too lean or rich other than by smoke sound or performance. Generally a temp gauge is not the most accurate way to get a good tune, but it is a good guideline. Most engines run good anywere between 220 and 270 degrees give or take some. Too low of a temp usually means your too rich and too high of a temp generally means too lean.
  10. #10
    Join Date
    Apr 2008
    NAPERVILLE, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thank you i will consider buying it
    2day i was tryin to tune my engine every thing seems good for beginner me but my car starded to creep forwardwhich screw should i turn or not turn
    And right now if iam going like half throttle there are no blue smoke but if i push it fas to the end the smoke is comin out like for 2 sc. is it good ?? or no ??
  11. #11
    Join Date
    Feb 2007
    , VA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Does it have a high rpm at idle? If so you might have it set too lean on the LSN or your idle screw is set too far in not allowing the throttle to close enough to let it idle down. I would richen the LSN a bit and see if it idles down. If not then probably have to adjust the idle stop screw some to get it to idle down. Blue smoke is good on full throttle take off. You want to see some so you know your not going to lean.
  12. #12
    Join Date
    Apr 2008
    NAPERVILLE, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    where can i find the idle stop screw ???
    Would the car stop if i try to turn the throttle adjustment screw on my controler??
  13. #13
    scottywilkes's Avatar
    Join Date
    Oct 2005
    launceston, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    its either a high idle, or you have snapped a clutch spring as u said it creeps forward, can u hold it on the ground still while its idling?
    8ightT:Go21, MBX5R:RBC6, FT NTC3:RBC12, 8000kv RC18T, MGT:M427, F103, NEVST, FASST 2.4, Spek 2.4
  14. #14
    Join Date
    Apr 2008
    NAPERVILLE, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    well like i said its creeping foarward so no and when i press barkes it stalls...
    but when i pick the car off the ground it can run for like 3 minutes
  15. #15
    avg_joe's Avatar
    Join Date
    May 2004
    Pennock, MN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    You need to look at the manual...I'm sure it has a diagram or picture illustrating which screw performs what function.
  16. #16
    Join Date
    Apr 2008
    NAPERVILLE, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    i tryed and found but the word the mension i have no clue what they mean (
  17. #17
    Nick2618's Avatar
    Join Date
    Mar 2007
    Sarasota, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: FastestJato
    Turn the throttle screw out to lower the idle...
    If you adjust the transmitter too much you may be applying the brakes then they will always be dragging when you are not on the throttle...
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	924800   Click image for larger version.
    Florida Gods Waiting RoomCheck Gallery for Pictures
    Jato 3.3 |Cen Nemesis (broken...) |Lunchbox |ST-15 |Mario Kart DK
  18. #18
    Join Date
    Apr 2008
    NAPERVILLE, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    thank you nick this helped me a lot
    did u took out ur whole engine cuz of me ??? LOL
  19. #19
    Join Date
    Nov 2007
    California, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    lol just let me know if you want a picture of a 3.3, I have mine out because.... whell.... how do I put this nicely, the 3.3 isn't the best engine I have owned, and I have had 2 of them and they both ran into problims after the 1st gallon so I ended up replaceing the first one right before I finished the first gallon and the 2nd one I got about 1.5 gallons and it has problims. So I have a 18tm in it now and it out performs the 3.3
    Jato 3.3 with spektrum dx3, JD carbon turnbuckles, all rpm, trx cdv\'s, chrome low-mid resonator, aluminum shockbodys, + more
  20. #20
    Nick2618's Avatar
    Join Date
    Mar 2007
    Sarasota, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    No lol. I just went on ebay and found a couple good pics for you.
    Also this is a good article to help you learn to tune if you need help with that.
    http://www.rcuniverse.com/forum/m_5517128/tm.htm
  21. #21
    Join Date
    Apr 2008
    NAPERVILLE, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    when i get my engine tuned perfectly if i ever will and i glue the srew so they wouldnt be able to move would that work so i wouldnt have to retune my engine ever again ??
    I KNOW STUPID QUESTION BUT MABY IT WILL WORK ??
  22. #22
    Join Date
    Nov 2007
    California, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Lol I wish it worked that way. Your tuneing will change with the amount of water in the air (forgot what it is called) and the tempachure out side
  23. #23
    Nick2618's Avatar
    Join Date
    Mar 2007
    Sarasota, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Source: http://www.rcuniverse.com/forum/m_5517128/tm.htm
    Keep in mind that an engines tune changes day by day, every time you get our your engine and run it, you should tweak the needles a little bit (typically). One day your engine can run fine, the next day it can be running extremely lean.
    NOTE: Tune the HSN first because it controls the full amount of fuel entering the carburetor, and then tune the LSN because it is a fine adjustment screw.
    As a side note, if you do a lot of wide open running at WOT (Wide Open Throttle, a.k.a. full throttle) your engine will need extra lubrication and it could need to be set 1/4th turn rich to ensure proper lubrication to your engine at high RPM’s.
    Here is a good little graphic that for the record I did not make, I simply found it very helpful.
  24. #24
    Join Date
    Apr 2008
    NAPERVILLE, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    but how about the real cars the concep is pretty much the same, so why dont we gave to tune the real cars ??
  25. #25
    avg_joe's Avatar
    Join Date
    May 2004
    Pennock, MN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Computer control changes the tune for us on 1:1 cars. Before that there was elaborate carburetor configurations with accelerator pump, secondary butterfly valves, little passages, and float systems, etc...
    Plus, just due to the sheer volume of fuel and air in 1:1 engines makes it easier to stay within the required parameters.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
