RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
Official Traxxas Jato 3.3 Thread
Reply
Old 05-10-2009, 02:21 PM
  #601
ajk2649
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Official Traxxas Jato 3.3 Thread
Quote:
ORIGINAL: supastar1568
hey all,
could someone help me out. I went off a pretty high jump yesterday and now it seems as though when i give the jato throttle, the the carb bumps the EZ start motor quite a bit. The contact is in the area of the LSN, and when I give it gas, it pushes against the EZ start motor at least a quarter of an inch.
Also, my EZ start motor no longer spins the engine over, I'm thinking it may have become unseated. Has anyone else had this issue before?
it sounds like u may have knocked some things off line. Everything fits real snug with the motor size and ez start together. U prolly have 2 take the motor off the truck and take the ez start off And check the gears that turn the ex start. Once u have it all off u will prolly find the problem and get everything 2 line back up.
ajk2649 is offline
Old 05-10-2009, 03:00 PM
  #602
supastar1568
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: ajk2649
hey all,
Yup, I just did that and found that the two M2.6 flat head screws that mount the EZ start motor to the plastic had backed out almost the whole length of the screw. Tightened them back down and things are good to go.
supastar1568 is offline
Old 05-10-2009, 07:14 PM
  #603
pimpala50
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: jbrobertsonjr
quietnas 1 how do you remove the battery box so i can put on my rear arms can not figure it out i took out the 2 screws in the battery box still wont come off please help[:@]
Man I had the sae issue when changing my arms, I really pulled,twisted,and everything, got mad, left and came back, did the same thing again, before I finally realized it was alot more I needed to take apart before the box would come off....(laughed at myself)
pimpala50 is offline
Old 05-10-2009, 07:20 PM
  #604
jbrobertsonjr
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i did not see the backward screw but i got it done, waiting on brake leaver and front bumper, fixing to install 3 speed in my schumacher finally got all the parts , the parts for it are very hard to find but it is a rush it should be quick
jbrobertsonjr is offline
Old 05-10-2009, 08:49 PM
  #605
quietnas1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
How are those Schumachers compared to the Jato?
quietnas1 is offline
Old 05-10-2009, 08:54 PM
  #606
jbrobertsonjr
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i have a 21 xtr single speed the jato will suck it up, but the three speed is rated at 70 mph we will see pretty soon i will keep you posted ,they have 1 thing in common they both like to ride on the wheelie bar, i will say the one i have is tuff its been though hell and back still runs real good and holds a tune, but ilove my jato, just hard to get parts
Old 05-10-2009, 09:34 PM
  #607
quietnas1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Wow can you imagine a 3 speed on a Jato? Hey take some pics and post it in the Showoff Your ST thread.
Old 05-10-2009, 09:35 PM
  #608
jbrobertsonjr
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i will post some pictures ,it probaly would run 80 or more with your set up the have, i wonder how hard it would be to use the tt trans in a jato,i have a extra tt trans you have gave me a thought.
Old 05-10-2009, 10:09 PM
  #609
quietnas1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Lol do it! Anything can be done in this hobby. Do it! Just trying to give some motivation.
Old 05-10-2009, 11:01 PM
  #610
kamicowzi
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey ya guys...I just picked up a new Jato 3.3, I was wonderign you guys had any good first time Jato owner tips. I have already broken in the engien and all that jazz, added a fail safe (would've threw in the other reciever for my spektrum radion I have, but I was tooo lazy for that), tossed the wheelie bar and battery box, and stuck a Rx pack in mid mount location. I plan on running it on road, and aside from picking up some foam tires, what is good for on road as far as springs and shock oil and diff fluid goes?
Thanks!
kamicowzi is offline
Old 05-11-2009, 12:16 AM
  #611
quietnas1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: kamicowzi
Thanks!
The stock springs and shock bodies are fine. I run my Jato low when its on road so I use 50wt oil up front and 70wt oil in the back. Makes for a nice stiff well handling ride. For the diff I also use the same 70wt shock oil and the Jato hooks real nice.
Old 05-11-2009, 07:02 AM
  #612
kamicowzi
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
All I have is 50wt shock oil and I refilled all four with it last night.....I am also going to refill the diff with actually diff fluid....is it really hard to get to the diff?
Old 05-11-2009, 08:09 AM
  #613
quietnas1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It is a bit of a pain but not that hard at all. Look a little further back in this thread. Should be this page or the previous page that I explain how to get to the diff. Good Luck,
Old 05-11-2009, 10:07 AM
  #614
kamicowzi
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks man.
Old 05-11-2009, 02:51 PM
  #615
JattoMan3.3
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi guys, got a problem, well actually two.
1) I bought a new ez start moror and ez harness to replace my old ones (damaged) fitted it, seems to work... well it spins the motor anyway but does not work on the glow plug which is also brand new, got 4 plugs of which none work with the EZstart but do with the glow starter.
2) I primed my engine too long, so I followed the procedure as normal but no fuel came out of the engine, put the glow plug back, tried again but it still seems to be flooded.
Just to give you an idea of the condition of my jato, its a year and a half old and has been driven no more than 5 times from new, Stupid me crashed it in final part of break in, replaced the rear suspension arm, next time gave it a v.good run apart from the collision with the curb (cracking the bulk head and partially damaged top chassis), Third drive took Very long to get the engine going (its probably not used to being run) once going it was fine till battery for reciever run low, Took home and forgot to do after run procedure, (I know what your thinking, this guy should not have a nitro car) I really do love them despite how it may sound.
Anyway since then I just can't get it going.
Please Please Help.
JattoMan3.3 is offline
Old 05-11-2009, 03:19 PM
  #616
worstluck
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
jatoman.
if the easy start is flippin over the motor just get yourself a glow ignitor. d-cell size lasts the longest. your starter wand will last longer too.
worstluck is offline
Old 05-11-2009, 04:02 PM
  #617
1nitrohead
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Jatoman
I would check needle seetings go back to factory
Check tank for crack/leak (check O ring on lid)
make sure carb has no leakin around neck where it mounts to crankcase
check to see if any leakin around easy start
Check carb needdle and make sure no dirt allowing too much fuel in
Plugs need replaced after breakin
Hope this helps
1nitrohead is offline
Old 05-11-2009, 06:48 PM
  #618
devo208
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Jatoman- Also check that the ground wire is still attached to the motor mount and tight. And make sure your ez start battery is charged.
devo208 is offline
Old 05-14-2009, 05:04 PM
  #619
jbrobertsonjr
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
quitenas1 what glue do you use, i was running real good when i had a tire come loose ,i have glued them using ca glue does not stick good.
Old 05-14-2009, 08:26 PM
  #620
rcphanatik
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
yo, r u supposed to break in the motor or run it easy for a few tanks after you change cooling heads? i have no clue.[&o]
rcphanatik is offline
Old 05-14-2009, 09:21 PM
  #621
jbrobertsonjr
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
if the motor is broke in before you changed heads it should be fine .
Old 05-15-2009, 12:10 AM
  #622
quietnas1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Oh man I forgot to answer you the 1st time you asked. Sorry about that. I dont like CA Glue. I have always used Super Glue. It comes in a yellow bottle with a red cap on it. Grips like hell. Just the tires are harder to take off.
Old 05-15-2009, 01:21 PM
  #623
Road Warrior
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sorry Jato lovers here is that video of my storm vs a jato. These were close, but there is another video that I need to edit down that I leaned out the low speed 1/4 turn and just blow him away by 15 feet at the end. There will be more to come soon with a rc 10 gt with a 18 tz in it. [link]http://www.youtube.com/watch?v=Mm6dLf-xhFk[/link]
Road Warrior is offline
Old 05-15-2009, 02:37 PM
  #624
rcphanatik
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
THANKS!!! i'm going to run the crap out of it when i get home. lol
Old 05-15-2009, 04:14 PM
  #625
Road Warrior
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sorry first time posting liks it's [link]http://www.youtube.com/watch?v=Mm6dLf-xhFk[/link]
Reply
Display Modes
