If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 50 of 51 FirstFirst ... 4048495051 LastLast
Results 1,226 to 1,250 of 1270
  1. #1226
    Join Date
    Dec 2007
    MIAMI, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Official Traxxas Jato 3.3 Thread
    ORIGINAL: superflyboy1988
    ok i know this has been asked 100 times but im going to ask again im giving the 3.3 the boot and going with the o.s 21 tm and i need to know what all i need to get to make it work like a new pipe and what not i was thank of going with this one but dont know if it is worth it or even if it will work
    http://www3.towerhobbies.com/cgi-bin...?&I=LXUAB2&P=7
    i have a mip clutch on it now can i still use it \
    thanks for any info
    Brandon
    The pipe and header should work. Do you plan on keeping the EZ Start? If you do plan on keeping it then I would test fit the header first at my LHS to make sure it will fit. I kept my EZ Start when I did the swap and ended up getting a header from an HPI RS4-2 and it fit perfect.
    A wise man can play the role of a fool. But a fool can never play the role of a wise man...... This is so true.
  2. #1227
    Join Date
    Dec 2007
    MIAMI, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: CaliJato
    So I just got the Integy piggyback shocks for my jato however even with 45 wt shock oil and Heavier springs Im having a hard time getting the shocks to lift the rear end, *It still has a droop and bottoms out. *Any suggestions? *Maybe I'm filling the shocks wrong or something.
    I still run the stock shocks and springs on my Jato. The only difference is I run 55wt shock oil in the front and 75wt sick oil in the back. It works perfect. She runs true and straight, soaks up the bumps with no problem, and handles very well. No bottoming out for my Jato. Give it a try and let me know how it goes.
  3. #1228
    Join Date
    Apr 2010
    Pearland, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ya that is the one i got to glad to know it will work with the ez start but i hope it will work with the roto starter too
    how dose ur gears hold up with the 21 i was thank of getting these
    http://www.hot-racing.com/index.cgi?...SJT1000X;c=180
  4. #1229
    Join Date
    Dec 2007
    MIAMI, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I actually want to get the same gear set. I have gone through 3 plastic sets so far but I'm going on a whole year on my last set with no problems yet. I just loosened the slipper clutch a very tiny bit and I don't slam on the gas from a dead start anymore.
  5. #1230
    Join Date
    Apr 2010
    Pearland, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    lol thanks for the heads up will be for sure getting them now and a handful of spur gears
    and do u know the stock LSN setting
  6. #1231
    Join Date
    Dec 2007
    MIAMI, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Man I can't remember the stock setting. I'm going on 3 yrs now the .21TM.
  7. #1232
    Join Date
    Apr 2010
    Pearland, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ya i really like o.s motors and i thank with the 21 and the trenchers i have on it it will be a beast
  8. #1233
    mattster1971's Avatar
    Join Date
    Jan 2012
    Glen Burnie, MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Cali, I had the same problem. The issue with the piggyback shocks are the springs they come with are too light. Also they come with the two hole dampening installed, you need to switch that to the one hole dampening and use the springs from the original shocks. That should clear up the problem.
    ORIGINAL: CaliJato
    So I just got the Integy piggyback shocks for my jato however even with 45 wt shock oil and Heavier springs Im having a hard time getting the shocks to lift the rear end, It still has a droop and bottoms out. Any suggestions? Maybe I'm filling the shocks wrong or something.
    I love RC and RC loves me! Lets make AMERICA great again!!!
    Traxxas Jato 3.3 Custom(2), HoBao Hyper 7(2), HoBao Hyper GT, Associated MGT 4.6, Kyosho Javelin, Axial YETI kit build maxed out, Axial Wraith kit build, Traxxas Slash, Hobao Hyper ST, Tamiya M-05 Pro R
  9. #1234
    Join Date
    Feb 2012
    , CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Well I have uped the shock wt to 45 and did install the single hole dampers. Along with some stiff shocks springs for the Jato. Waiting to put it all together and see what happens.
  10. #1235
    Join Date
    Apr 2010
    Pearland, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    finely got my roto start back plate other then having to cut off a little bit of the side piece it went in peaty easy
  11. #1236
    Join Date
    Apr 2010
    Pearland, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Attached Thumbnails Attached Thumbnails Click image for larger version.
  12. #1237
    Join Date
    Dec 2007
    MIAMI, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    superfly that's a nice fit bro. Let me know how it performs.
  13. #1238
    Join Date
    Mar 2012
    ExeterDevon, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I am looking to get a replacement battery apposed to the stock AA in the rear. I dont want to spend the £25 on the Traxxas 5 cell 6 v battery they offer and am looking at a different brand with more nimh.
    I need to know about the plugs because the one i am looking at on ebay has a futaba connector, i dont know if this is a J connector it could be any type. The traxxas battery has futaba J and the stock traxxas AA pack i have has JST connectors. Will any futaba connector work with the JST connectors or will all connectors fit in the traxxas link reciever? Do all futaba connectors work with JST connectors? And for charging a futaba connector can i just get an adapter or something to plug into the charger i already have for my 7.2 v EZ start battery charger with the standard large size tamiya plug?
    I am a newb to battery connectors as you can tell and any help would be much appreciated.
  14. #1239
    1QwkSport2.5r's Avatar
    Join Date
    Oct 2006
    Cottage Grove, MN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: RockerTom
    I really like MaxAmps battery packs. I use the 1600mah 5 cell packs myself, I have 2 of them. My packs have two connectors on them, one 2-pin (JST I think) and one 3-pin Futaba. If you're using the stock radio, either connector will work. The little 2 pin JST will fit with a little care, into a Futaba connector. I've done it, you just have to be careful to not bend the pins in the receiver.
    The MaxAmps pack costs about the same as the traxxas pack, and has a 2 year warranty I think. Most guys put the flat Rx pack in front of the engine in the small compartment there, but I dont know for sure if the big 1600mah pack will fit in that compartment.
    GlowHead Brotherhood #3
    Real engines use glow plugs.
    R.i.P Jacob Wetterling #11 10/22/1989
  15. #1240
    Join Date
    Jan 2012
    Glen Burnie, MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    This is my Jato 3.3 It has 2 gallons through it now since January. Ihave really enjoyed modding it and buying parts for it and just all round bashing. Iam in Maryland if anyone else is in the area. Ihave made some changes and thought Iwould post again because Ilove looking at all the Jato's.
ID:	1751690   Click image for larger version.
ID:	1751691   Click image for larger version.
ID:	1751692   Click image for larger version.
ID:	1751693   Click image for larger version.
ID:	1751695   Click image for larger version.
ID:	1751696   Click image for larger version.
ID:	1751697   Click image for larger version.
ID:	1751698   Click image for larger version.
  16. #1241
    Join Date
    Jan 2012
    Glen Burnie, MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    part2
ID:	1751700   Click image for larger version.
ID:	1751701   Click image for larger version.
ID:	1751702   Click image for larger version.
ID:	1751703   Click image for larger version.
  17. #1242
    Join Date
    Dec 2007
    MIAMI, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Love that roll cage you have on there. Looking real nice.
  18. #1243
    Join Date
    May 2013
    leuvenvlaams brabant, BELGIUM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    what body did you use
  19. #1244
    nitro-rob's Avatar
    Join Date
    Jul 2008
    Cambridge, ON, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Looks like there isn't a lot of activity on this truck anymore. I am enjoying mine quite a bit and was looking into a big block conversion since I have some pretty nice .21 buggy engines sitting around but newera says they aren't in stock and they seem like the only option. Mine has a lot of life left in it, though, it is maybe just broken in now with half a gallon through it.
  20. #1245
    Hi,
    I am looking to modify my Jato with the Roto start backplate. Can you advise the part you used, and maybe where it was purchased. I have found a few on Ebay that might fit, but not sure...
    Join Date
    May 2002
    Dover, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Wing mount.
    Did a search in this thread and received 10 results back on the subject "Wing Mount". The only wing mount mentioned is the New Era mount, but I'm not sure if New Era is still in business. The link provided did not work. Does anybody know of a wing mount that will work on the Jato?? Any help with this would be GREATLY appreciated.
    Thanks....
  22. #1247
    nitro-rob's Avatar
    Join Date
    Jul 2008
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Integer has one that I think is integrated with a roll cage. I think others have modified the jato wing mount to fit. Thats about it as far as options. My Jato has been sold.
  23. #1248
    Join Date
    May 2002
    Dover, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks for the reply nitro-rob.....
  24. #1249
    Join Date
    Jan 2012
    Glen Burnie, MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Quote Originally Posted by superflyboy1988 View Post
    Dont bother with the stock gearing, just spend the money now and upgrade to hardened steel from Hot racing. Best money you will have spent.
  25. #1250
    nitro-rob's Avatar
    Join Date
    Jul 2008
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    You should be able to drive the hell out of your Jato all day and night for months and years with the stock plastic spur gear regardless of how powerful the engine is. If you are burning them up or breaking them then there is another unidentified problem. This is true for any RC.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
