RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
Official Traxxas Jato 3.3 Thread
Reply
Old 12-13-2008, 02:23 PM
  #176
dwjr8
dwjr8's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Official Traxxas Jato 3.3 Thread
Here's a couple shots of mine. its a 3.3 with RPM arms, Modified Hard Bodyz roll cage to cut weight. TRX CVDs, GTR shock bodies, 5 cell center pack, Aluminum turnbuckles, Pull start 58 tooth spur. In these shots its on 2.8 Imexs with Imex ATs and a HPI 200mm Dodge Ram body. also have the Proline Basher set up (2.2 Wabash wheels and Dirthead tires) this is a great cheap set up. $32 mounted. have a new motor to break in atm. took a huge jump and landed on its top, broke the motor right at the mounts. One complaint on the Hard Bodyz cage it does leave about 1/4" of the back half of the head unprotected. in this shot it does not have the cage installed.
ID:	1088948   Click image for larger version
dwjr8 is offline
Old 12-13-2008, 03:15 PM
  #177
rcphanatik
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: bullittube
i no i am a noob and i should keep my mouth shut but everything i have herd about the jato said the front wheels are normally off the ground so why would u wont 2 add a spoiler would that just worsen the problem
You've got a point. maybe i'm just checking them out cause they look sweet. i've heard the same thing from my local hobby shop expert.
Also, to dwjr8, do u know how many sorts of 200mm bodies would fit? i thought they were meant for touring.
rcphanatik is offline
Old 12-13-2008, 03:18 PM
  #178
f0rb3s
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
all 200 mm and 190 bodies will fit with tthe proper trimming...
mainly wanna look for something that has the trunk and the hood at the same heights,
f0rb3s is offline
Old 12-13-2008, 03:20 PM
  #179
rcphanatik
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks, i've looked around my hobby shop and noticed a sweet mustang that might fit well.
Old 12-13-2008, 03:21 PM
  #180
dwjr8
dwjr8's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
im sure you could make em all fit. you can see that i did some serious cutting to make clearances. ive seen 200mm truck and sedan, and sports car bodies on Jatos. Lambo's, Lotus's you name it. there are plenty of tricks to keep the front end down just set up differently. Gearing, slipper clutch, battery location, even lead weights if you need to.
dwjr8 is offline
Old 12-13-2008, 03:22 PM
  #181
rcphanatik
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
lead weights? the first time i heard that, i took it as a joke. i'll try for the mustang
Old 12-13-2008, 03:24 PM
  #182
rcphanatik
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i was checking out some new tires from proline- the road rage 30 series. is it really good for rough asphalt, like sidewalk and pavement?
Old 12-13-2008, 03:25 PM
  #183
f0rb3s
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
another way to keep the front down is to go with revo gearing... like a robinson cb/ and a 38 spur...
i am runnin a custom grind ab mod mill and i dont wheelie at all...
secondly, move ur batt pack up over the shock towers... it will help in turning but be carful cause the rear will follow around...
f0rb3s is offline
Old 12-13-2008, 03:27 PM
  #184
rcphanatik
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
yeah, i've heard about putting the battery in front. i think i'll try it. i've got an old hump pack that won't fit in the normal places anyway.
one week left
Old 12-14-2008, 09:32 PM
  #185
ajk2649
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey man I have the same engine im bout 2 put in mine as well. What header pipe did you use. I noticed the stock jato 1 wont work. I just got a buku pipe for the engine and just need 2 know what header will work.
Have you ran yours yet and if so how much of a diff is it from the 3.3? was it worth the money?
ajk2649 is offline
Old 12-15-2008, 09:16 AM
  #186
f0rb3s
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
run an rs4 header... and then take ur buku and toss it....
if u ask revonitro on here.. who has the same install the radar proves the buku actually robbed that mills performance
f0rb3s is offline
Old 12-15-2008, 01:46 PM
  #187
ajk2649
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well I have ran the buku with the 3.3 and had crazy gains and was really happy with it. I have heard nothing but good things about it. I havent tryed it on the 12tz spec II yet and maybe I wont have the same kinda great gains. what pipe do you suggest running with that engine and what header cuz the rs4 header I dont think it will work.
ajk2649 is offline
Old 12-15-2008, 01:48 PM
  #188
ajk2649
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I think this 1 may work but I dont know if its any good
http://www3.towerhobbies.com/cgi-bin...?&I=LXNWX3&P=7
ajk2649 is offline
Old 12-15-2008, 01:52 PM
  #189
f0rb3s
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
sorry man i thought it was a 21 my bad....
f0rb3s is offline
Old 12-15-2008, 01:58 PM
  #190
bullittube
bullittube's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
would the OFNA Hyper 21 8 Port work with a jato and what about the pipe, could u just slot it in or would u have 2 do some mods???
bullittube is offline
Old 12-15-2008, 08:36 PM
  #191
nitrorevo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: ajk2649
I here some of the 3.3 guys had improvement with the BUKU. I tested it with the .21TM no improvement from mid range to top end. Only some low end imrpovement which is not needed for the .21TM. Tested is on my JLR.12 and it was a complete NO NO. Another test done not by me on the .18TZ and the stock pipe was better. Only 2 or 3 tanks on the pipe and it is boxed in the closet. Biggest waist of $100 bucks I ever spent in the hobby.
BTW all tests were done with Bushnell Velocity, with the gains or lack of logged and recorded with each gearing change and distance of the run.
Also forbes got his best runs with the stock pipe, after many tests and different setups on radar and video. You can't just go by what you see or thought you saw. Eyes can be tricky.
nitrorevo is offline
Old 12-15-2008, 09:02 PM
  #192
ajk2649
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
So you think its a poor choice of pipe for a 12 size engine all together? After seeing some test runs and reading up on things I think they may all be true about it being overrated. What pipe would you suggest for the 12tz? Im still trying 2 think of what 1 I wanna get.
ajk2649 is offline
Old 12-16-2008, 10:47 AM
  #193
f0rb3s
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i would run a ths pipe...
f0rb3s is offline
Old 12-16-2008, 02:31 PM
  #194
devo208
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i just run the LHS for the jato's
devo208 is offline
Old 12-16-2008, 02:47 PM
  #195
ajk2649
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
what header do you use?
ajk2649 is offline
Old 12-16-2008, 02:55 PM
  #196
ajk2649
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Also what THS pipe and header because the exhaust port on the trx engine is a tad smaller then the 12tz exhaust port and I wanna make sure it will fit.
ajk2649 is offline
Old 12-16-2008, 04:36 PM
  #197
bullittube
bullittube's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: ajk2649
Sorry for stupid question but what is a THS pipe ???
Old 12-16-2008, 05:02 PM
  #198
braddddddd991
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Do I tune the motor during break in? or just make it smooth to run then really tune it?
braddddddd991 is offline
Old 12-16-2008, 06:02 PM
  #199
ajk2649
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
its an exhaust pipe
http://www3.towerhobbies.com/cgi-bin...EARCH=ths+pipe
ajk2649 is offline
Old 12-16-2008, 06:09 PM
  #200
ajk2649
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You do not need to tune it during breakin. Leave it at the factory settings to allow rich running with proper lubrication. After break in you can then tune for proper running. If ever you are having trouble with the engine and it just does not want to work with your adjustments and is acting all kinds of crazy on you and you lose track of what you have done as far as tuning, remember to always return all carb settings back to factory settings and start all over. It always works for me. You can fnd the factory settings in the owners manual or online somewhere. The internet is great for finding just about anything.
ajk2649 is offline
Reply
Display Modes
