is there a way to tell if too hot without a gauge
LA
see i dont have a temp gauge but i always see smoke so i dont know how to get the perfect temp is there any other way to tell? thanks
RE: is there a way to tell if too hot without a gauge
Takes time to learn by experiementation how to get a good tune. Reading up on tuning is not a bad idea too. You kind of have to grow a ear, eye, and hand for it all to be a "good tunner". If you put water on the cooling head and time it how long it takes to sizzle you can get a idea of how hot its running, but a temp gauge is much more accurate.
LA
see i used spit its about the same i use water to but niether sizzles at all and over the time iv been running iv tuned several cars and its all of a sudden that this car is bursting with power now i did make some adjustments but i didnt think they would effect the car this much
LA
i had the little blue one from duratrax but it wasnt accurate at all it would say my motor was 212 when it was just sitting inside what should i get then and im running a dtx .18 and i just adjusted suspension and spur gear mech also it rained today so the dirt isnt wet but has tonnnsss of grip the motor still is acting AMAZING without those factors though. please send a link with a good temp gun its appreciated thanks. goin run again be back lata
The outside temp and pressure has alot to do with performance. After it rains it usually cools down that could be a reason for more power. You can calibrate that Dura trax temp gauge if you want or at least try to. Boil a pot of water and adjust the reading to get your boiling point on the gauge.
CA
[link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXKAX3&P=FR]HERE[/link] is a pretty good one. It gives me a pretty accurate temp.
WA
i just lick my finger and touch her gently~ hahahah but no really... if it sizzles then your pretty hot! usually 250+
Banned
If your engine hits more then 230, your in trouble. 210, 220 tops. I have 5 different temp guns and they all very accurate. These nitro engines should not run any hotter then the engine in your car you use to drive to work, school, parties!!
1 guy said his engine runs at 500 degrees, I think he was from Pluto!
WA
500 will melt about everything within a yard yard range around it! hahahahahaha those tires would be a pile of liquid on the floor
GA
ORIGINAL: robbio4422
ORIGINAL: Pearl_414
GA
i dont agree with the "hot more than 230 and your in trouble" thing. i wouldnt go above 260, maybe 270 or 280 if it is a traxxas motor
Banned
ORIGINAL: youwish16
MN
dude i have a traxxas nitro sport it runs like 250 to 280 if im driving it like i stole it if i got it down to 200 or 210 it would probably flood or be so slow it would be boring to drive it
NY
Get a Tempgun.com PE1. It's cheap and works good.
http://www.tempgun.com/main.html
There are some on Ebay.
Banned
I drive mine hard to, but it only runs at 210 degrees and is anything but a slouch. I have a Trinity .12 Draked, 1.5 HP. I buy only the highest quality nitro's the world has to offer.
ORIGINAL: Pearl_414
Dude, 270 and 280 are much too hot. At those temps if your car/truck doesn't catch on fire your engine will start to lose power and certainly won't last long.
ORIGINAL: youwish16
Banned
ORIGINAL: Mspeed
Try posting that in some of the other forums and see what reaction you get.
ORIGINAL: Pearl_414
ORIGINAL: youwish16
Engine temps depend on many things such as : budget, bashing, engine life, fuel ratio, local, regional, world racing levels.
I believe 220-240 to be a good starting point without a noob ruining their engine that some had to save money for a period of time to acquire.
