Official RC10GT Thread
#2531
RE: Official RC10GT Thread
I have a team orion wasp .18. A lot of people say that its not that good but I have run it against os max .18 and mine wins every time we drag race.
But, thats not good enough. I am going to get an O.S. Max .18 with a rear exhaust because its another 1.6 hp Muhahahahahhaha.....
#2532
The most powerfull engine to date is and should remain the OS 18TZ ,it has scored a 2,2hp and i haven't found so far anything able to beat it ,with that my GT goes as fast if not more than any good 1/8 buggies ...
#2533
ORIGINAL: Fast Guy
I built a FT over last winter. The instructions are very good for any one building their first truck. The kit wasn't missing anything and was well packaged. The only thing I changed on the kit was the rear tires (step pins) to suit our track. I finished the kit off with a CV-r 12, Orion 1100ma receiver pack and a JR XS3 radio. It took me about 15 hours to build including painting the body. This was not my 1st GT though.
Originally posted by Master
Lol,anyone built the rc10 ft gt? how are the intructions and stuff? How long did it take you to build the whole thing?
#2534
Banned
ORIGINAL: Mindless_Chaos
Who needs instructions?? I build them in less then 2 hours in one sitting.
ORIGINAL: Fast Guy
#2537
My Feedback: (27)
I figured there had to be a GT thread on here somewhere, I Had to dig deep to find it though!
any body know where I can get a screw kit for th GT? I hate the tiny hexxes on the factory screw. I would like to find a kit that either has a phillips head or maybe bigger hexxes. I have had about 10 different nitro RC's and this is the first ascossiated car I had and these are the smallest hexxes I have seen on a car. I usually use blue locktight on most all of the screws but I don't want to with these because I afraid I will stripp them if I do.
#2538
WA
ORIGINAL: yakfish
#2539
Hey, I have a rc10 gt and today, I was running it and had to put it behind a post to adjust the fuel intake, while doing so I went the wrong way and it just reved super high and I went to go drive it and it wouldnt go. The big fly wheel was stripped and the small fly wheel, the one that goes into the engine just spins now freely in both directions. What do I need to replace?
#2540
WA
ORIGINAL: ryanhackler
if you have other issues, you should take a pic of it so we understand what you are talking about a bit better
#2541
I have recently bought a rc10 gt and the throttle was runnig high so I put it going forward against a post to turn down the fuel in intake. well I turned it the wrong way and I reved way up as it was stuck against the post. I turned it down and tried running it. Now it wont go. the clutch bell runs freely in both directions with my finger and the pitch spur does not grab to drice the tires. Im not sure what is wrong and need some direction. Thanks.
#2543
so you put it agnst a post running that is the best way to overheat and kill your motor andit sounds like your idle is to high ,nitro engines get cooling from the fuel keeping a car pinned agnst a post with the clutch burning and heating up is so bad just watch your temps and se how fast they go up doing that .
#2544
Thank you, that helps alot. I ordered another spur gear and took the transmission out and everything seems to be ok. So ill replace the spur and hopefully that will take care of it. Now when I roll the car, you know how when you roll it manually it kind of catches and clicks a little? Well its not doing that, it just rolls. What do you think? I am getting a digital camera soon and will take pics so you can see. Thanks for the help.
#2545
WA
if you hold the spur gear and spin one wheel. the other should spin the opposite direction... dont worry about if its clicking or not
#2546
My Feedback: (27)
anybody ever literally MELT a spur gear? I'm not sure why but it got real hot for some reason. the engine is still running around 230-250 degrees which is about perfectbut the spure got really hot. any ideas? I also just had agear strip while the car was just sitting at idle. I heard it start to rev a bit higher and looked and the spur was stripped. thats the second stripped gear in 2 tanks of fuel!![:@] I'm thinking I might get one of the RRP steel spurs.
#2547
it is hot because the grippy tires are getting good bite and the slipper is slipping verry fast building up friction ,if you want toi keep running it that loose you have to get a rrp steel spur.
#2549
My Feedback: (27)
ORIGINAL: robbio4422
where did you get the red dogbones?
I guess that makes sense with about the clutch splipping too much with the new tires. I looked at the RRP gear but the only one that I can see is a 65T spur. I would like to find one that is smaller. My 24T CB won't fit with a 65T spur. I have an 18T bell that will work with it. but I want to go FAST!!
