New motor, and aluminum diff cases, for nitro mt?
TX
I want the aluminum diff cases purely for the bling factor, I know they're not necessary or particularly useful. Do the make the(aren't the rs4-3 diff cases the same thing?). Is the center diff case the same thing btw, and is there a 2 speed available?
The other question is on a new motor. I want something slightly overpowered, probably as large as will fit easily. Truck will be purely for screwing around with, so I'm not worried about race classes etc. Suggestions?
RE: New motor, and aluminum diff cases, for nitro mt?
ORIGINAL: txaggie08
As far as an engine. I am running the OS 18 CV-R, pretty nice engine. If you wanted to get the best/fastest/most ridiculous engine you can, you could go for the OS 18 TZ, for some extra money of course. The CV-R you can find for 100-130 new, while the TZ is 150ish new.
If you have trouble finding parts, let me know and I can hunt down some links for you. Good luck with the upgrades!
TX
how much is compatible between the one and the two?
I apologize for the questions, I'm not new to RC but definitely to the car side of it. I acquired this car(it's a first gen HPI mt) for 100$ as a toy to mess with, and I'm trying to learn a bit.
I also need a set of turnbuckles(assuming that's the right term for the upper suspension linkage...), are there a better set than what comes on the car stock, or do I just need to acquire another set of the HPI ones.
Some parts. I am sure the difference between the two were, new body, tie rods, drive shafts and engine. Just look at your MT1 diffs and look at some pictures on ebay.
I know you only want the diffs for bling factor but if you want stronger diffs go for the carbon graphite ones that HPI makes. You can get a whole set for $15 which is you centre diff, rear diff and front diff boxes. Much better then 22 for one aluminum diff. GPM parts are quite cheap and I have heard them snapping after a while. Some of its ok. Just becareful, integy use a stronger aluminum as with GPM have a weaker type of aluminum, less % of everything whem smelting.
