Nitro won't start?
#52
RE: Nitro won't start?
that there is tricky
your gonna have to take your spur out and try and figure out its pitch. I know MT2s are MOD1 not sure what that one you have is.
If it happens to be MOD1 like mine was your going to have to make a driveshaft adapter (piece of hollow tube with a 5mm diameter) to shove on the motors driveshaft
#53
NY
Here is towerhobbies listed spur gear for it if this helps any?
http://www3.towerhobbies.com/cgi-bin...?&I=LXWZ80&P=Z
#56
NY
OK i am confused. The spur gear is hooked direct to the tranny right? So i need the little gear that goes on the motor that matches the spur gear to make it work right?
#59
ORIGINAL: sullivanracing06
thats actually the tower hobbies nitro stadium truck, they sell the entire truck with out a radio for 119.00
#62
NY
Well i talked to my father about rc and decided i will give this one to him. He wants a beginner truck and this would do just fine. I will help him find the parts he needs to get it going again.
#63
ORIGINAL: dudecat
Kewl so what exactly do i measure to make sure the gear will work with the motor and spur gear?
