Jato Beadlocks on RC10GT??
MB, CANADA
Hi,
i seen some super sweet beadlock wheels from Integy for the Jato.... im wondering if the Jato wheels can me mounted on the RC10GT?? ive seen posts where a guy says he needed an adapter, i think a hex adapter, but dont the Jato wheels mount the same way as tghe RC10GT? the the little pins in the rear axle/hub, and the "pins" lock into the wheel??
if so, wouldnt the Integy beadlocks have the same setup??
i need clarification here, as i want to get the Integy aluminum beadlocks for the jato, for my RC10GT super project! ;-)
here is a pic of the wheels.
if anyone call tell me if the jato wheels will in fact fit, or how they attach, anything! id be very gracious!
regards
ginnz
regards
ginnz
RE: Jato Beadlocks on RC10GT??
As you can see I was able to fit Jato wheels on my RC10GT. The rears do not go on like stock GT wheels. You need to get the hex adapter for the Jato. Place it on the GT axle and then you can put Jato rims on it. The front is a little tricky. You can use the bearings from the Jato but you will have alot of play in the front wheels. I had gotton some from Boca Bearings that worked grea. I just cant remember the size and I ended uo selling my GT.
MB, CANADA
cool, yeah, i think id seen you post something on this somewhere else! and thanks for the confirmation! ill get the 12mm hex adapters, and buy the blue/silver Integy beadlocks and get it all set up them! ill find appropriate bearings for the front as well.....
it should look awesome when completed!
thanks again!
ginnz!
thanks again!
ginnz!
