resinator outlaw or THX? in Jato 3.3
I have a jato 3.3 and I am building it for wheelies and excelleration rather then for top end. I bought a lot off an auction site and I have a THX pipe, a resinator 5541x and an outlaw pipe. Which pipe should i use for low end tourq for wheelies and quick off the line stuff. I am not real into top end and plan to gear it down. That being said what is the lowest gearing that will fit? I tried to look up and did not find a good thread so if there is one i missed jut point me in the right way, thanks
RE: resinator outlaw or THX? in Jato 3.3
Well I was using the THX pipe and a 24 tooth bell gear. I switched to the resinator pipe and a 22 tooth gear and it wheelies like crazy now. Not exactly the scientic method. Now I just have to deside if i should put the THX pipe back on and test it with the 22 tooth gear, unless some knows which pipe has better low end torcq and tells me......
I believe it's THS Racing. They make quality products and really think it's the best of the three you listed. The change you made with pipes didn't cause the wheelies to happen. It's when you switched out the clutch bell from 24T to 22T. Keep the THS pipe and sell the others.
