RCU Forums
RCU Forums (http://www.rcuniverse.com/forum/)
-   RC Nitro Stadium Trucks (http://www.rcuniverse.com/forum/rc-nitro-stadium-trucks-243/)
-   -   Best way to use after-run oil? (http://www.rcuniverse.com/forum/rc-nitro-stadium-trucks-243/7586148-best-way-use-after-run-oil.html)
buky221 06-05-2008 10:20 PM
I have geard putting it in the fuel line and covering the exhaust pipe hole for a few secs.
Then I heard you can take off the air filter and put it in there then open the throttle.
what is the best way???
Chris_RC 06-05-2008 10:24 PM
RE: Best way to use after-run oil?
I take my glow plug out and put 5 drops in the engine, then put 3 drops in the carb. Then I spin it over to get it coated and repeat it 1 more time
yakfish 06-05-2008 10:27 PM
personally, I will put it directley into the carb and remove the glowplug and put it directly into the cumbustion chamber. then just slowly pull the starter cord a few times to make sure all the internals are coated nicely. but thats just me. I don't know if there really is a "best way" just get it in there however you can!
brett65 06-06-2008 10:09 AM
I put 3 in the carb 2 down the plughole and give 3 pulls or a couple seconds with rotostart.
NitroTherapist 06-06-2008 01:14 PM
Do you guys use it after every run or just when your not gonna run it for a couple days??
MJAsony2305@aol.com 06-09-2008 10:30 AM
i use it only if i am gonna store for 2 weeks +
motorhead91 06-09-2008 12:27 PM
i use it every time....just a habit i guess
bean-a-reano 06-11-2008 12:49 PM
About 4-5 drops in motor. After every use which is once a week.
cgad18 06-12-2008 12:42 AM
now if you have nitro fuel with the after run oil in it do you still have to put some in after running it?
calvino 06-12-2008 01:09 AM
Quote:
ORIGINAL: cgad18
you can never be to safe[8D], IMO just because it has it, does'nt mean a little more does't help:D
