Theme Bodies
PA
RE: Theme Bodies
Yes i use an airbrush. I use an Iwata HP-CS. http://www.arttalk.com/iwata/new/new...ushes.htm#HPCS
PA
RE: Theme Bodies
The Iwata HP-CS is a very good brush. It is able to make very detailed lines and is very controllable. The only problem is it does not spray metallic colors that well. For metallics I use a Paasche VL with a #3 or #5 tip.
RE: Theme Bodies
The CS has a .35 Needle and Nozzle thats why it is hard to shoot metallics with...I have 4 BCS's 3 of them have the larger .50 setup that does great with metallics, I use the other BCS with the .35 for laquers and Alclad II chrome. I also have a Custom Micron SB which has a crazy small .18 Needle/Nozzle, I use it for fine shadowing of flames and stuff. You can get the .50 Needle/Nozzle for the CS but it's a pain to swap them out all the time, it's better to have another brush (Like you already have Jason) for the different paints.
Bigmike
Bigmike
