fasglitter
IL
fasglitter
Hey guys i no that when you use the glitter you are supposed to mix it with the fascoat but i have found out that if you spray the faskoat thined out wiht water it looks like i got water spots should i spray it straight fascoat im just scared that it will be cloudy thanks guys.
GA
RE: fasglitter
spray it right out of the bottle, don't reduce it, it will not cloud up.
Good luck
P.S. Clean your airbrush as soon as you are done spraying!! That faskoat will dry up really quick and it resembles glue more than paint.
Good luck
