Wish me luck!
Wish me luck!
This is going to be my first multi color body. i am praying it comes out ok. here is what im looking like right now, next pic is expected end result.
[img][/img]
[img][/img]
RE: Wish me luck!
190mm from hpi, also available in 200mm
here it is, i special ordered mine to be 190mm
http://www.hpiracing.com/products/en/7452/
RE: Wish me luck!
looks good so far but if you havent already use a toothpick or something and clean up those line by the headlights and stuff ( just trying to help a little)
RE: Wish me luck!
those lines are supposed to be there, took alot of work to make to like that. if you look at second pick i posted of expected results, you will see they go up there.
RE: Wish me luck!
still have alot of work to do, will cover up most errors with decals, started to rain during drying of white but a final coat should fix it.
CA
RE: Wish me luck!
Wow, i definitely need to get me a HPI body if it comes pre-masked. Probably wont be as advanced as you and go multi-colored cause it's my first body. But I'll try my best. Light buckets are needed for lights right? Could i just take a piece of styrofoam, cut it the shape of the headlight and poke holes where the LEDs go and glued that onto the shell? It should shine through the decal if I leave the headlight part clear?
RE: Wish me luck!
some hpi body's come with light bickets, my lambo did but none since. have to find out before obviously.......here we go. with exception of spoiler needing adjustment i think it came out ok.
RE: Wish me luck!
ORIGINAL: eckosof
RE: Wish me luck!
yea headlight wasnt as bad as originally looked, headlight covered most, didnt have anything to remove excess paint, everything pretty much came out good except the red. next time i will spend extra time masking.
RE: Wish me luck!
ya i wasnt trying to be negative just giving a few pointers that I have lanred through out my painting journeys other thanb that it turned out nice good job
