Body Patch
My Feedback: (12)
MO
Body Patch
Ihad to cut a hole in my rc10b4 body to compensate for the velineon ESC i put in it. What do you recommend for a patch? Is there a resource to buy "body" material to cut and glue onto the hole? Should I just buy another body and cut off a portion of it? had the same issue with my spur gear protector piece...had to cut a hole for my motor pinion so I coud get it on.
Any advice is greatly appreciated
RE: Body Patch
i know they sell different sizes of lexan that come in sheets you could cut to fit or just buy a new body and start over it would be less hassle then trying to patch unless you already have a nice body and want to keep it. check out towers website they have it on there
My Feedback: (12)
MO
RE: Body Patch
Well, buying a new body would be futile since the hole would need to be there for the body to fit. The ESC protrudes high enough that the low profile rc10b4 body will not sit how it is designed unless the modification is made. The patch would have to be 3 dimensional as oppose to a flat piece of lexan to compensate for the ESC.
It is fairly handy having the hole there as I can turn on/off the ESC without removing/altering the body at all, but of course it leaves it a bit exposed if I happen to roll the car. (which has happened a few times). Guess Ill have to get creative with the lexan sheet and a lighter to mold the piece Ill need
thx for the response.
NY
RE: Body Patch
ORIGINAL: Shenanigans
My memory is rough about this, but I know I saw something like what I described. It is used I believe by the plastic modelers when they are trying to create custom designs. Look for a site that caters to these modelers.
Jim
