FAA ceiling on R/C
CA
RE: FAA ceiling on R/C
ORIGINAL: jeide
What happens to pattern if the FAA new rules limit R/C to 400 feet maximum altitude? Also R/C gliders and IMAC.
Derek I hope you are right. If you don't mind my asking- the workgroup you are involved in- is it made up of just modelers? Or is someone who would be in a position to have some "inside info" inovolved? Like a lot of flyers I've been paying attention to this issue lately(albiet, just what I can find on the internet) and this is the first I've seen this kind of information.
My Feedback: (8)
We will need to see how this whole thing pans out. Nothing is official or really published yet (according to the AMA newsletter I read).
What I heard was that the ceiling limit was for non-AMA regulated activity. Pattern events are AMA regulated, so if this were the case we would be fine.
I believe everything right now is more or less speculation, unless there was an official decision and announcement that I missed.
Latest from the AMA.
"You're receiving this email because of your affiliation with the Academy of Model Aeronautics.
December 2010
Potential FAA regulations on model aircraft still up in the air
Your AMA leadership made yet another trip to the Washington DC offices of the FAA in late November. Negotiations, led by AMA Government Relations and Regulatory Affairs Representative Rich Hanson and AMA President Dave Mathewson, continue to focus on national airspace safety, model aircraft operations and potential regulations that may create serious restrictions on aeromodeling. Click the link below to read Dave's latest report on this important issue.
Got a question for the FAA concerning its attempt to regulate model aircraft operations? Take the Quick Poll survey at the right, which will ask you to submit a question for a discussion forum with FAA officials at January's AMA EXPO."
I received this as well as the link referenced from the AMA email service 12/9/10.
You probably did too.
December 2010
ORIGINAL: Derek.Koopowitz
I honestly do not see this happening. I've been on a workgroup that involves all R/C disciplines and the feeling was that the FAA will leave it up to the AMA to determine what the ceiling should be...
ORIGINAL: jeide
That seems at odds with what I have gleaned from conversations with people like Rich Hanson and extensive reading of the available documentation. Initially it was the case but lately I have gotten the impression that things have changed.
The FAA folks that briefed the EC in January mentioned altitude caps within a certain radius of an airport and lateral operating limits. Dave Mathewson's column and Rich's comment seem to imply that they are tightening up from there.
Given that every time you see the FAA mention models they cite AC 91-57, which is where the 400 foot limit comes from, it seems reasonable that this is the direction they are headed. The attached pdf file is an FAA Fact Sheet on sUAS. From that memo, dated July 2010:
Recreational use of the NAS is covered by AC 91-57 which generally limits operations to below 400 feet above ground level and away from airports and air traffic.
The most recent comments from the AMA definitely indicate that the FAA is moving towards more restrictive definitions rather towards greater flexibility.
The AMA has a good web page with the latest info that they are able to share:
http://www.modelaircraft.org/news/ama-faa.aspx
CO
Check here to see what the FAA should really be worried about ifits not already:
http://fpvpilot.com/default.aspx
Run a Google on FPV RC to get an ida of the scope of this activity.
My Feedback: (21)
ORIGINAL: jeide
hook
My Feedback: (21)
ORIGINAL: Gulliver
hook
Interesting, the third tab on the left menu is "FPV Safety"yet one of the videos shows the helicopter flyingright at an individual, looks close too. Dumb and safety don't really mixin my book.
It is my understanding that they intend to publish this as SFAR Part 107.
It is also worth noting if you look at the ARC memo past the model sections to note the operating limits for those aircraft. Groups I and II are limited to 400 feet. Group III can go to 700 and Group IV can go to 1,200. However, all of the operations above 400 feet require a dedicated spotter AND altitude and position reporting equipment with a real time down link to the pilot.
All of the sUAS commercial/civil groups have lateral limits on them ranging from 1,500 feet to 1/2-mile. Their operations will be excluded from Class B airspace and will have set backs from all airports as well. An additional requirement will be to operate outside populated areas, which in FAA-speak is anything depicted in yellow on a sectional chart. Their operations will likely be restricted to VLOS, day VFR under 100 mph with the altitude caps noted above. In addition a 2nd class medical and other pilot and airframe certifications will be required.
To me the most logically consistent approach is for them to allow modelers to operate with the same physical limits on altitude and lateral areas while relieving us of the more onerous pilot certification requirements, medical certificates, airframe certification and so on. I have a difficult time understanding how the FAA could justify allowing models with much more lax operator certifications and training requirements to have greater operational flexibility as compared to the more stringently regulated pilot group.
If we are allowed to operate above 400 feet I predict that it will only be allowed well outside any populated area, away from airports and other busy airspace and will require some sort of waiver similar to what the rocket guys have to do now. If that is the case it is difficult to understand how we could practice!!
My Feedback: (21)
ORIGINAL: Silent-AV8R
It is also worth noting if you look at the ARC memo past the model sections to note the operating limits for those aircraft. Groups I and II are limited to 400 feet. Group III can go to 700 and Group IV can go to 1,000. However, all of the operations above 400 feet require a dedicated spotter AND altitude and position reporting equipment with a real time down link to the pilot. .......
hook
Yep, 1,200 feet. I misremembered that one!! It also requires a Letter of Authorization confirming that the intended operation area is considered uninhabited.
My points remains the same however, that is seems logical that we as modelers would not receive more liberal limits than the regulated sUAS does. My opinion is that the major difference between recreational and commercial/civil is going to be that they will have higher training standards and aircraft certification requirements than we do. It would not surprise me to see a stepped altitude cap as well for us such that if we want to fly in the middle of nowhere we would have fewer restrictions. As you say, the closer we get to things the greater the restrictions will be.
My Feedback: (42)
NJ
ORIGINAL: DMichael
Assuming that is right- we'd be fine for events- but not practice.
We've been following the 400' limit set forth by AMA for years and years. Since our club is only about 5 miles from a full scale airport, we try and regulate ourselves to 400' above ground level anyway.
See paragraph 2 - sub section (C)
http://www.modelaircraft.org/files/105.PDF
I don't know what all the fuss is about. 400 feet above ground level is pretty darn high for normal, every day flying. Why would you need to fly higher than 400' above the ground?
I can see an IMAC contest where large planes will exceed that during uplines, and I could see a pattern plane exceeding 400' on an upline. But those instances are rare when compared to the number of RC flights being flown on a daily basis.
We've put monitoring devices in a UAV that I work on part-time. It's a long ways up to 1200 feet above ground level. A 44lb UAV starts looking pretty darn small up there. I can't imagine flying a glow or gasoline powered RC model up to 1000 feet above ground level. I've flown thermal gliders up over 1500 feet above ground level. Gliders with 150" wingspans look like a DOT at that altitude.
So why all the fuss over a 400' limit?
Since the FAA is trying to regulate the sUAS's then it seems that they should make a definitive statement about what is and isn't an sUAS. I have a simple definition that might help. If it has any capability of gathering information external to the aircraft (cameras, sensors etc) for live transmission or post flight downloading then it is an sUAS. Anything else is a model. Yes, models carry cameras today. I would say that if they do so then they must comply with sUAS rules. Leave the pure model aviators alone.
I guess this is too logical and simple.
ORIGINAL: Rcpilot
We've put monitoring devices in a UAV that I work on part-time. It's a long ways up to 1200 feet above ground level. A 44lb UAV starts looking pretty darn small up there. I can't imagine flying a glow or gasoline powered RC model up to 1000 feet above ground level. I've flown thermal gliders up over 1500 feet above ground level. Gliders with 150'' wingspans look like a DOT at that altitude.
Many sport flyers basically fly a racetrack pattern and I guess that's OK for them- but not for me.
You might also be flying a lot higher than you think you are. Keep me honest on my math but, by my calculations, at 60mph a plane is traveling 88ft every second. Assuming you are flying even 50 feet above the ground, if you were to pull vertical and maintain speed you'd be past 400 feet in about 4-5 seconds. If you count it out, that's not very long- and I bet many of us are flying faster than 60mph.
The last I read from Dave implied (very directly) that we WERE in for changes.
That all of the regulations had not been decided.
...and that the first publication of the proposed regulations would be made in June 2011.
I'm with those who have commented as to the negative aspect of FPV flights and their
published pictures (such as the one of the statue of liberty at night).
In the USA 9/11 rings quite loudly still .....regardless off what the rest of the world might think
My bet is that we will have some less than desirable regulations imposed upon us and that fields closer to functioning
airports will have more stringent requirements than those further away.
I've heard "within three miles" and also "within four miles" . All distances are as the crow flies.
I can think of two fields locally which are too close to full scale operations right now. And I'm not the FAA !!
Now, define "functioning airport".
Commercial ?
Or with operating tower ?
Or ?????
Hang loose as there is nothing yet .......BUT there will be !
The only certainty at this time is that changes are coming.
All of our speculation is just that.....SPECULATION .
One good aspect is that I haven't seen any rants lately putting down the AMA .
Commercial ?
Or ?????
My Feedback: (42)
NJ
Afew of us Pattern and IMACtypes did some informal testing one day with an onboard unit to record max altitude. Some testing was done by flying the sequence, and other testing was done to see if what we each thought was 400 feet was about right. We tried this with 2M Pattern airplanes and with a 40% Sukhoi. Suffice it to say that there is no way you can fly aerobatic sequences as we know them today without busting through 400 feet AGL. It was also very revealing that what we all thought was 400 feet, just flying straight and level, was wrong. Very wrong. Anyone who thinks that they have a good handle on on how high they are flying at all times, even with ordinary sport flying, is just fooling themselves. A 400 foot celiing is simply unrealistic, and is also unenforceable with RC flying as we know it today.
ORIGINAL: shannah
I should add in the definition for sUAS the capability of autonomous flight.
In reading the ARC memo the FAA classifies models as sUAS. The difference is they want to make us essentially an regulated sUAS. Autonomous flight does not look to be part of the sUAS concept. sUAS, us and the regulated ones, will be VLOS only. They will require a spotter pilot for FPV operations.
This is from the July 2010 Fact Sheet:
Introduction
Unmanned Aircraft Systems previously referred to as “unmanned aerial vehicles,” “UAVs,”“remotely operated aircraft/ vehicles,” or just “unmanned aircraft come in a variety of shapes and sizes, and serve diverse purposes. They may have a wingspan as large as a Boeing 737 or smaller than a radio-controlled model airplane. UAS operations always have a pilot in command who is flying the aircraft.
Its easier for them that way, for sure. If the definition is broad and non-descript then everything falls under the guidelines and, therefore, under the regulations. I don't have a good feeling about this at all...
If we were somehow able to draw a distinction between truly recreational flying and the real intent of an sUAS then maybe we could get somewhere. After all, I doubt that the purpose of an sUAS is to take off, fly a prescribed set of aerobatic maneuvers in a 60degree box and then land. As I see it, there really isn't any gray area there. But, from the sUAS pilot/developer standpoint, they look at the hardware involved and say "hey, my heli/airplane is similar, why do I have to be regulated and not those guys????"
ORIGINAL: NJRCFLYER2
A few of us Pattern and IMAC types did some informal testing one day with an onboard unit to record max altitude. Some testing was done by flying the sequence, and other testing was done to see if what we each thought was 400 feet was about right. We tried this with 2M Pattern airplanes and with a 40% Sukhoi. Suffice it to say that there is no way you can fly aerobatic sequences as we know them today without busting through 400 feet AGL. It was also very revealing that what we all thought was 400 feet, just flying straight and level, was wrong. Very wrong. Anyone who thinks that they have a good handle on on how high they are flying at all times, even with ordinary sport flying, is just fooling themselves. A 400 foot celiing is simply unrealistic, and is also unenforceable with RC flying as we know it today.
