F3A plans
Old 12-30-2010, 12:47 AM
highfly3D
Default F3A plans
Hi all,
I had downloaded a pattern plan sometime back its was in a pdf format from some Japanese or Chinese website don't remember. It was similar to the F3A "addiction" now i cannot find that plan. If any one know the site please help me out.
High
Old 12-30-2010, 01:10 AM
Rune
Default RE: F3A plans
Hi
Is this what you was thinking about???
ID:	1539698   Click image for larger version
ID:	1539699   Click image for larger version
ID:	1539700   Click image for larger version
ID:	1539701   Click image for larger version
Old 12-30-2010, 02:38 AM
highfly3D
Hi,
Yes this is similar to the one PDF plan i had but the landing gear was not below the wing. If you have the PDF please help me I am planning to build it with a OS 1.60 engine.
Harry
Old 12-30-2010, 03:43 AM
Rune
have no more plan but the landing gear should be easy to move to the fuse..... but I know Papaone has some drawings out on som nice planes in the french forum . those are in full size and should be easy get them printed if you find the right printer
Old 12-30-2010, 07:25 PM
bjr_93tz
I know the one you're asking about. I have it on my PC at work. I also converted the PDF to and AutoCad file and have drawn up complete templates for the wing and stab ribs spars etc.
Next time I drop into work I'll post them.
Old 12-31-2010, 06:45 PM
flywilly
My Feedback: (121)
THANKS!!
Old 01-04-2011, 10:07 PM
bjr_93tz
I Hope this is what you were looking for. The two text files need to be renamed to the .dwg and .dxf extensions.
The filenames have turned up a bit funny, the first .txt file should be renamed .dwg and the second should be renamed .dxf...... dwg files need AutoCad.
File Type: pdf
File Type: txt
File Type: txt
Old 01-05-2011, 01:18 PM
MarkGrabowski
I have a copy of the first file. One the second and third, what is contained in those two?
Old 01-05-2011, 01:55 PM
bjr_93tz
Hi Mark,
the second .txt file is is the .pdf converted to an Autocad .dxf file so you can modify the drawing. The first .txt file is an Autocad .dwg file that contains the same drawing but also the drawings of the parts to make the wings and elevators.
With regard to the wing and elevator drawings I made some pretty large assumptions in that the airfoils at the tips were the same as the root, this may or may not be the case in real life. I also assumed that the wings and stabs are straight without any weird twists built in. Interestingly enough I have one plane where the fin was straight but I had built the rudder with a twist (by accident) the plane didn't seem to mind, however years later I ended up rebuilding a straight rudder for it and it now needs a rudder to elevator mix for inside and outside loops. This is something I would like to explore more.
I'll convert my Aries 07 to Cad one day and use that as a reference for future projects...
Old 07-03-2011, 09:50 AM
emreozcakmak
Hello Dear Modellers ,
Thanks for sharing this valuable drawings.I plan to construuct one from fiberglass with mold.But formers , bulkheads are very necessary , they can be seen on the picture of plan ( black one ) but not existing on pdf . Is there any seperate file insisting them ? or if not how can ı derive formers for my foam plug ???
Old 07-09-2011, 04:03 AM
slickporsche
I am also interested in these files, but cannot open the last two. I tried a converter, but it stated there was an error. Is there an easy way to covert to DWG, and DXF?
Old 07-09-2011, 04:14 AM
Flyitorcrashtrying
No need to convert the files. they are in the proper form, you just have to rename the file extension.  When you go to save it, Use "Save As" and where it says .txt in the name, rename it with .dwg so it will be called Attachment.dwg for the second file, and the third file will be renamed Attachment.dxf
Old 07-11-2011, 04:02 AM
batsoyol
Hi give me F3A plan please. [email protected]
Old 07-17-2011, 07:18 PM
slickporsche
I tried to change the name to dwg,and dxf, but that does not seem to work either. I Will try it again, and see if I can make to work.
Old 07-17-2011, 07:26 PM
slickporsche
When I click on it here in rcu, it comes to me in Note Pad, and the first line is File Name Xv64068, and the second line says Save as type, and it has a drop down, that only gives me an option of "all files" Itried it like this, dwg Xv64068, and Xv64068dwg, and when I go to where it was save it does not seem to have changed. I'm doing something incorrectly for sure, but do not know what.
ORIGINAL: slickporsche
Old 10-26-2011, 06:00 AM
ya33a
Hi,
Ok, on the link, you 'right click' on it and 'save as', then when the dialogue box opens, you carefully click on the same line as the Xv64068 and you just type in " .dxf " and / or " .dwg " at the end so it looks like " Xv64068.dxf " and " Xv64068.dwg "
Then download a free 'viewer' and look at the detailing it's very well done
Old 09-15-2021, 07:54 PM
ehsanmorshedi
Hi
does any one has the plans above in the right format to share? (DWG - DXF)
[email protected]
Regards,
Ehsan
Old 09-18-2021, 02:52 AM
bjr_93tz
Originally Posted by ehsanmorshedi
Hi
[email protected]
Regards,
Ehsan
At the time, RCuniverse would only accept files with certain filename extensions for uploading, so I simply changed the filename extensions so they could be uploaded. The files are complete.
Please just change the three letter filename extensions back to what they should be as detailed in the previous messages.
You may have to enable viewing of filename extensions on your file explorer to do that?
Old 09-18-2021, 09:06 AM
ehsanmorshedi
I tried to do so, but couldn’t open the file even by changing the extension.
that would be your kindness if you email me the file/s in true format.
my email address: [email protected]
Regards
Ehsan
Old 09-19-2021, 02:41 AM
bjr_93tz
Regards
Ehsan
I'll check it out when I go back to work on Tuesday.
Old 09-20-2021, 07:12 PM
bjr_93tz
Regards
Ehsan
Hi Ehsan, I've just downloaded each file using a right click "save link as" and changed the .txt to .dwg (and .dxf for Zu64106) and they both opened in AutoCAD as normal.
Sorry if this doesn't work for you.
Change extension from .txt to .dwg
ehsanmorshedi (09-20-2021)
Old 09-20-2021, 11:22 PM
ehsanmorshedi
Thanks for the time you spent 🙂
