CA Model XURAMA BIPLANE Build Glow Powered
Reply
Old 03-01-2011, 07:52 PM
  #51
tuny
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: CA Model XURAMA BIPLANE Build Glow Powered
More work...
started mounting the bottom wing. it will be attached to the fuse with 3 6-32 screws. two on the back and one on the front, the back mount for this screws in the fuse is from 1 piece of 1/8 plywood, and 2 pieces of 1/8 lite-ply. they are sanded to anangle so the blind nuts match the angle from the screw coming from the wing.
the front mount is made of 1/8 lite-ply, plywood and balsa, laminated on both sides with carbon
both mounts glued to thw fuse with epoxy and microbaloons.
on the wing I inserted 3/8 hardwood dowel pieces tosupport the screws (there will be more reinforcement to this area later.
pics...
ID:	1572042   Click image for larger version
ID:	1572043   Click image for larger version
ID:	1572044   Click image for larger version
ID:	1572045   Click image for larger version
ID:	1572046   Click image for larger version
ID:	1572047   Click image for larger version
ID:	1572048   Click image for larger version
ID:	1572050   Click image for larger version
tuny is offline
Old 03-01-2011, 07:54 PM
  #52
tuny
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
more pics...
ID:	1572052   Click image for larger version
ID:	1572053   Click image for larger version
ID:	1572054   Click image for larger version
ID:	1572055   Click image for larger version
ID:	1572056   Click image for larger version
ID:	1572057   Click image for larger version
ID:	1572058   Click image for larger version
ID:	1572060   Click image for larger version
tuny is offline
Old 03-01-2011, 07:55 PM
  #53
tuny
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
more...
ID:	1572062   Click image for larger version
ID:	1572063   Click image for larger version
ID:	1572064   Click image for larger version
tuny is offline
Old 03-03-2011, 07:24 PM
  #54
tuny
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
more...
mounted the bottom wing with 3 6-32 screws and blind nuts, then I removed some material in the fuse to save 5 grams. finally aded the carbon and glass reinforcement to the wings.
pics...
ID:	1572898   Click image for larger version
ID:	1572899   Click image for larger version
ID:	1572900   Click image for larger version
ID:	1572901   Click image for larger version
ID:	1572902   Click image for larger version
ID:	1572903   Click image for larger version
ID:	1572904   Click image for larger version
ID:	1572906   Click image for larger version
ID:	1572907   Click image for larger version
ID:	1572908   Click image for larger version
tuny is offline
Old 03-03-2011, 07:27 PM
  #55
tuny
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
more pics...
ID:	1572910   Click image for larger version
ID:	1572911   Click image for larger version
ID:	1572912   Click image for larger version
ID:	1572913   Click image for larger version
ID:	1572914   Click image for larger version
ID:	1572915   Click image for larger version
tuny is offline
Old 03-03-2011, 09:32 PM
  #56
highfly3D
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
what thickness fiber glass cloth are you using for the wing joiner? nice build.
highfly3D is offline
Old 03-04-2011, 05:52 AM
  #57
tuny
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Highfly3D, the fiberglass is 2oz.
TUNY
tuny is offline
Old 03-05-2011, 08:01 PM
  #58
tuny
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
more...
made the former that goes in the back of the bottom wing, its made from 3/32 balsa and 2oz glass cloth on both sides. then added 1/32 plywood reinforcements on the wing, in the bolts area.
pics...
ID:	1574013   Click image for larger version
ID:	1574014   Click image for larger version
ID:	1574015   Click image for larger version
ID:	1574016   Click image for larger version
ID:	1574017   Click image for larger version
ID:	1574018   Click image for larger version
ID:	1574019   Click image for larger version
ID:	1574021   Click image for larger version
ID:	1574022   Click image for larger version
ID:	1574023   Click image for larger version
tuny is offline
Old 03-08-2011, 06:33 AM
  #59
tuny
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
more...
Rudder servo tray. its 1/8 balsa and 4oz. glass cloth on both sides.
ID:	1575251   Click image for larger version
ID:	1575252   Click image for larger version
ID:	1575253   Click image for larger version
ID:	1575254   Click image for larger version
ID:	1575255   Click image for larger version
ID:	1575256   Click image for larger version
ID:	1575257   Click image for larger version
tuny is offline
Old 03-08-2011, 06:37 AM
  #60
tuny
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
more...
top wing... its mostly same as the bottom, the fiberglass center reinforcement is a little different, its wider at the trailing edge, I did this because this is where the plane is lifted at the field.
ID:	1575266   Click image for larger version
ID:	1575267   Click image for larger version
ID:	1575268   Click image for larger version
ID:	1575269   Click image for larger version
ID:	1575270   Click image for larger version
ID:	1575271   Click image for larger version
ID:	1575272   Click image for larger version
ID:	1575274   Click image for larger version
ID:	1575275   Click image for larger version
ID:	1575276   Click image for larger version
tuny is offline
Old 03-08-2011, 06:38 AM
  #61
tuny
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
more...
ID:	1575290   Click image for larger version
ID:	1575291   Click image for larger version
ID:	1575292   Click image for larger version
ID:	1575293   Click image for larger version
ID:	1575294   Click image for larger version
ID:	1575295   Click image for larger version
tuny is offline
Old 03-10-2011, 07:00 PM
  #62
tuny
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
more...
Finished glassing the top wing. thenmade the former that support this wing and the fuel tank, its made from 1/8 balsa with 2oz. glass cloth on both sides and a lite ply doubler on the top, on the tank area I put foam to protect the tank.
pics...
ID:	1576765   Click image for larger version
ID:	1576766   Click image for larger version
ID:	1576767   Click image for larger version
ID:	1576768   Click image for larger version
ID:	1576769   Click image for larger version
ID:	1576770   Click image for larger version
ID:	1576771   Click image for larger version
ID:	1576773   Click image for larger version
ID:	1576774   Click image for larger version
ID:	1576775   Click image for larger version
tuny is offline
Old 03-10-2011, 07:03 PM
  #63
tuny
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
more...
ID:	1576777   Click image for larger version
ID:	1576778   Click image for larger version
ID:	1576779   Click image for larger version
ID:	1576780   Click image for larger version
ID:	1576781   Click image for larger version
ID:	1576782   Click image for larger version
ID:	1576783   Click image for larger version
tuny is offline
Old 03-11-2011, 05:56 AM
  #64
jim woodward
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Awesome work and ingenuity Tuny!!
Jim
jim woodward is offline
Old 03-11-2011, 06:52 AM
  #65
highfly3D
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Tuny,
How will the side wing holder (top & bottom wing) be fitted on a foam wing thats what i want to know.
Old 03-11-2011, 07:03 AM
  #66
Torben Parsberg
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hallo
NICE Job, I like to follow this build,,
I think ,, its look you made , the fueltank support , fore a tetra tank ,,
i can tell , you can save 35g ,, to take a K,S fueltank.. 600ml , VS Tetra 450ml, its same price!
look
http://modelflyvning.dk/forum/showth...t=34032&page=4
Torben Parsberg is offline
Old 03-11-2011, 09:34 AM
  #67
MarkGrabowski
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: tuny
more...
Interesting tank mount.... at first glance it would not appear robust enough to handle a full tank and maximum G's....
It is nice and light!
MarkGrabowski is offline
Old 03-13-2011, 11:53 AM
  #68
tuny
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Jim!!! I´m glad you like it.
Mark, that tank mount is not complete, there willbe more support after I calculate the exact CG to place the tank there. (you will see ina few posts)
Thanks Torben, yes,I will be using tettra tank, I know the K&S is ligther, but I just recently had a failure on a K&S tank, and never had one on a tettra, so tettra it is. BTW check te cap on the K&S periodicaly, it can came loose in flight and you dont want to know what happens.
Highfly3D, the nexpost will answer all your questions....
Regards.
TUNY
tuny is offline
Old 03-13-2011, 12:01 PM
  #69
tuny
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
more...
Wing struts.
I will install the wing struts with 4 4-40 screws each, two on top and two on the bottom. I think this is stronger that just the wire and will hold better to the YS vibrations in time (is longer to put the airplane together at the field)
the wing has an internal plywood plate marked in the picture with masking tape, there is where the mounts will hold.
pics...
ID:	1578097   Click image for larger version
ID:	1578098   Click image for larger version
ID:	1578099   Click image for larger version
ID:	1578100   Click image for larger version
ID:	1578101   Click image for larger version
ID:	1578102   Click image for larger version
ID:	1578103   Click image for larger version
ID:	1578105   Click image for larger version
ID:	1578106   Click image for larger version
ID:	1578107   Click image for larger version
tuny is offline
Old 03-13-2011, 12:03 PM
  #70
tuny
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
more...
ID:	1578109   Click image for larger version
ID:	1578110   Click image for larger version
ID:	1578111   Click image for larger version
ID:	1578112   Click image for larger version
ID:	1578113   Click image for larger version
ID:	1578114   Click image for larger version
ID:	1578115   Click image for larger version
ID:	1578117   Click image for larger version
ID:	1578118   Click image for larger version
ID:	1578119   Click image for larger version
tuny is offline
Old 03-13-2011, 12:05 PM
  #71
tuny
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
and more...
ID:	1578124   Click image for larger version
ID:	1578125   Click image for larger version
ID:	1578126   Click image for larger version
ID:	1578127   Click image for larger version
ID:	1578128   Click image for larger version
ID:	1578129   Click image for larger version
ID:	1578130   Click image for larger version
ID:	1578132   Click image for larger version
ID:	1578133   Click image for larger version
tuny is offline
Old 03-15-2011, 06:58 PM
  #72
tuny
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
more...
the tail former.. this former goes atthe back on the fuse and takes most of the torsion of the airframe, so it has to be glued very good. its made from 1/8 balsa and 2oz. glass clth on both sides.
pics...
ID:	1579396   Click image for larger version
ID:	1579397   Click image for larger version
ID:	1579398   Click image for larger version
ID:	1579399   Click image for larger version
tuny is offline
Old 03-15-2011, 07:08 PM
  #73
tuny
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
stabs...
cutted the elevators, on this case I dont cut the elevs all the way to the tips, this way is easier to set up the plane, then started working on the stab tube. I sanded the tube sleeve tosave some weigth. then cut the pieces that goes inside the stabs. Inside the stabs there are two plywood ribes that hold the tube, so the tube shoud pass this ribs, no tube pass the second rib is needed so I cut the sleeves to go about 3mm pass that rib, then I will cut the tube to the required length this way I can save a couple of grams without compromising the structure.
pics....
ID:	1579404   Click image for larger version
ID:	1579405   Click image for larger version
ID:	1579406   Click image for larger version
ID:	1579407   Click image for larger version
ID:	1579408   Click image for larger version
ID:	1579409   Click image for larger version
ID:	1579410   Click image for larger version
ID:	1579412   Click image for larger version
ID:	1579413   Click image for larger version
ID:	1579414   Click image for larger version
tuny is offline
Old 03-15-2011, 07:10 PM
  #74
tuny
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
more pics...
ID:	1579416   Click image for larger version
ID:	1579417   Click image for larger version
ID:	1579418   Click image for larger version
ID:	1579419   Click image for larger version
ID:	1579420   Click image for larger version
ID:	1579421   Click image for larger version
ID:	1579422   Click image for larger version
tuny is offline
Old 03-15-2011, 08:23 PM
  #75
stuntflyr
stuntflyr's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What a builder! I love biplanes.
Chris...
stuntflyr is offline
Reply
Display Modes
