e-Power Throttle Curve Tweaking
My Feedback: (198)
Forgive such a basic query....but I'm really new to e-pattern setups, and I've already found that there is a HUGE difference in the feel of the throttle/power management in electric pattern setups.
Would appreciate any tips or pointers (already am aware of the "tweak curve to suit"suggestions)....is there a general sort of curve that translates from YS 4 stroke power to e motors, or is the fact that one just has to learn and adapt?
Any suggestions or help??
RE: e-Power Throttle Curve Tweaking
I have the YS170 and the Hacker C50-14Xl, I have tried to match the Hacker to the YS but have not been able to be very close, so I had to adapt, and it is not easy.
Sorry I'm not helping much.
Alejandro P.
Alejandro P.
OH
I'm by no means an expert, but when I transitioned to electric I found that the motor didn't come up soon enough. I tweaked my throttle curve to get quicker response at the bottom end and it felt more like what I was used to with my OS 160 setup.
Scott
Scott
My Feedback: (198)
Thanks. That's what I'm finding, but now seem to have bad non-linearity from 3/4 stick to the top. If I recall, we used to tweak IC curves to move the power band more toward mid-stick, but honestly can't remember.
I know a straight linear setup means the stick is way further up nearly always, which isn't computing to the "finger memory" of roughly-mid-stick for almost everything...
Maybe the solution is just to program multiple flight modes with different curves and switch those for a better trial and error approach.
The electric behaves like a 2 stroke for shure, almost the same, it is very difficult to match the curve of a YS, wich in the 170 is almost linear and you can fell every click of power, that is not possible in the electric set ups, unless a Q80 22 poles. Multiple conditions will complicate things more, I will suggest just to get used to it and refine the curve the best possible way to fit your liking.
Regards
Alejandro
Regards
Alejandro
My Feedback: (31)
My biggest problem changing to Electric was not getting a "report" back from the engine when I moved the throttle. I had no idea how big a deal that little tid bit was.
Tim
Tim
ORIGINAL: Bob Pastorello
My Feedback: (198)
ORIGINAL: Mastertech
Tim
Tim
ORIGINAL: Rendegade
I understand there is one you can buy that doesn't require any extra electricity, it runs on fuel believe it or not!
NY
Okay, I am just starting to work on this with a new set-up.
We don't want to reinvent the wheel, and surely there is a methodical and logical approach we have been unable to ferret out with google.
After ESC programming, my first step was to set the end points. Next, I flew the model with an unmodified throttle curve (actually it was a straight line at that point) and noted ther throttle stick position when the model was flying at a comfortable straight-and-level "cruise speed" in relatively calm winds. Back on the ground, I tached the prop to see what rpm's it was turning when the throttle stick was in the "cruise" position and tweaked the curve to achieve that rpm with the throttle stick centered (curve point 5 on my 9-point curve).
After that, I tweaked points 4 and 6 so that there was a little "ramp" in the curve so that it won't be so difficult to find that nice cruise speed - the stick need only be close to center.
So there's a start to the discussion and the process, at least the way I'm going about it. It might be totally moronic or misguided, but perhaps some experts will chime in here with some of their advice.
Hey Bob, you need to fly the plane a little more and figure if you want power more toward the bottom of the stick or somewhere above half, then adjust your throttle curve to match. I am running a 20.5x14.5 prop at times, and I like the power to be more at the bottom of the stick so I adjusted my throttle curve to make this happen. I have the 14mz and can do this with EXP2 and get a very nice curve. The more you fly the plane, the more you will know where you prefer the power to be.
My Feedback: (8)
I had my glow plane out this past weekend, almost thinking twice about selling engine. Elrctrucdoes.have some disadvantages, but not enough (imo) to go back.
Was flying a 120 two stroke, propped down to 16*6 for better throttle response, flew just like the YS 110 on the same prop.
Maybe higher C rates give better throttle response?
My Feedback: (198)
ORIGINAL: rgreen24
I didn't realize that I was doing it, but basically I did what cmoulder wrote to try, and if it cools enough for me to go try it soon, I will.
rbyrd - got your p.m. - please email me and let's reconnect.
Hi all
I think, the solution of that problem is easy.
I am using a governor system for F3A. The position of throttole stick is allocated to RPM.
I think, operation is easier than YS DZ170.
However, there is only Japanese in the instruction manual though it is that it is disappointed.
kobago
