If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 10 of 10
  1. #1
    Join Date
    Dec 2001
    Sammamish, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Same engine or change
    I just picked up a used Epsilon 90. the previous owner flew it with a Saito 125. Question should I stay with that since it was setup for it or switch to a YS110? It was an airframe only purchase so have flexiblity.
    Mike
  2. #2
    Join Date
    Aug 2002
    Newell, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Same engine or change
    YS 110 more power. Saito less problems.
  3. #3
    petec's Avatar
    Join Date
    Jan 2002
    Beaver Falls, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Do you already have an engine or do you need to go buy one? Either will server you well but the YS will allow you to put the tank on the CG.
    Team YS, Pattern Junkie
    Revver Brother #82, Gear Head
  4. #4
    Join Date
    Feb 2005
    oakland, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    For simplicity, a simple two stroke OS 120 AX should do the job. However, if you're proficient with four strokes especially the YS system, I'll go with the 110 or the replacement 115.
    There is still a lot of us here flying YS, & we can provide you with suggestion should you run into trouble.
    Good luck.
    Adrian
  5. #5
    Jetdesign's Avatar
    Join Date
    May 2008
    Mason, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I tried messing with a YS early on in my rc/pattern career. Great power until I started having problems, spent a lot of down time trying to solve, or waiting for engine to return from YS parts and service.
    They are awesome engines if you have the time to learn and understand them. I learned the hard way that I'd rather have a reliable motor and spend my time concentrating on flying, not tuning.
    OS 120AX is an awesome engine, Saito should be fine too. Personally I might try a pumped OS 4-stroke, but expensive and again asking for things to go wrong.
    As you can see, I switched to electric power (still experimenting though)
    Joe Marri
    Enjoying all things aviation.
  6. #6
    Join Date
    Dec 2001
    Sammamish, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I don't have an engine as I'm working on getting back into things. I have had YS's before and understand them pretty well. I think this just might come down to cost and what the wallet fits the best.
  7. #7
    Join Date
    Jul 2006
    Ossining, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    You could use the Saito and a Perry Oscillating pump and put the fuel tank on CG, which is highly desired for a precision aerobatic model. No constant trimming the elevator, and mass in the center of the model.
    In the past, I did this with an OS 120 4-stroke and it worked quite well.
    Bob
  8. #8
    patternflyer1's Avatar
    Join Date
    Jul 2003
    Tracy, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Don't listen to Adrian, he is building a super secret electric Bipe!
    Mike, it depends how much time you want to put into getting the YS put in, and getting it set up right. Do that, use the right fuel, and I would say go with the YS. If you just want to get out there flying, the Saito will be quicker and a little more user friendly, but I've seen them have plenty of issue's also.
    There should be plenty of folks here who could hook you up with a good motor at a good price I would guess.
    Chris
    Team BJ Craft
    Team JR
  9. #9
    Join Date
    Aug 2004
    CebuCebu, PHILIPPINES
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    If you are comfortable with a YS, go for it. Nothing beats a YS for glow power. Having said that, I recently switched to electric and am not looking back. If anyone needs a YS 170 CDI tuned by Mr Yamada himself with less than 3 gallone run thru it for a cheap price, shoot me a pm.
  10. #10
    Join Date
    Feb 2005
    oakland, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: patternflyer1
    Actually, I'm building a pattern triplane with a Jet Cat turbine ...
    Adrian
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
