ARIXTRA, new french F3A design
Old 07-15-2013, 12:08 PM
  #126
Torben Parsberg
Default RE: ARIXTRA, new french F3A design
Hi Ola it looks great...
Old 07-16-2013, 12:29 AM
  #127
Rune
I was in to look at the Arixtra on the webpage, but could not open it.
Old 07-16-2013, 01:01 AM
  #128
Rune
Found it aerocompet.com
Old 07-16-2013, 01:04 AM
  #129
Salander
Hi Ola, it looks like the stabs on your two Arixtras are at a slightly different position with slightly different elevators. Do you notice any difference between the two? They both look fantastic well done!
Old 07-16-2013, 10:36 PM
  #130
ofremmi
ofremmi's Avatar
The one from last year was build from a basic-kit, ie. I had to sheet the foam-cores myself, cut out the control surfaces etc. The good thing about doing it myself is that I can hand-pick the wood and thus the older one is lighter by about 150g (5.2oz). They behave slightly different, but if that is due to the stab. position, controlsurface differences,different weights, different sanding of leading edge or whatever, is hard to tell. Most likely it is a combination of it all. Anyhow they both fly rather excellent, andI hope to bring them both to WC in SouthAfrica in August.
Old 05-13-2014, 03:24 AM
  #131
papaone
papaone's Avatar
Hello
Friend of mine Jacques's Arixtra with built up wood wings I did for him.
Claude
ID:	1994940   Click image for larger version
ID:	1994941   Click image for larger version
ID:	1994942   Click image for larger version
ID:	1994943   Click image for larger version
Old 05-13-2014, 07:49 AM
  #132
Malydilnar
Here are our three Arixtras. The Seahawk themed bird is electric while the other two are Ys-185 CDI powered. I like the ys more as the extra momentum helps carry this airplane with speed. Once I'm finished with the USA bird I will experiment with fing fences on the electric as she has a tendancy to tip stall when slowed down. The electric weighs 4850g with 1300g batteries and the ys birds weigh just a little over 4600g.
Old 05-13-2014, 09:38 AM
  #133
Portlandflyer
Alex,
Not to be outdone...
ID:	1995011   Click image for larger version
Old 05-13-2014, 06:19 PM
  #134
Malydilnar
Patrick you need to bring that baby and your Sensation to the Wenatchee contest, we have to get a group photo!
Old 07-07-2014, 02:53 AM
  #135
papaone
papaone's Avatar
Hello
Others pics of Arixtra
ID:	2012284   Click image for larger version
ID:	2012285   Click image for larger version
ID:	2012286   Click image for larger version
ID:	2012287   Click image for larger version
ID:	2012288   Click image for larger version
Old 07-07-2014, 07:45 AM
  #136
MTK
Originally Posted by papaone
Hello
Claude
Well done Claude. Really like the look of your built up wing panels. I also am heading down that path on my Delta. Am in process of completing the stab halves this week and will soon start on the wings. Rib spacing on the stab is 1.6 inches (10 ribs each side)
What rib spacing did you use on the wing? What was the weight savings over sheeted foam?
Old 07-08-2014, 11:29 AM
  #137
papaone
papaone's Avatar
Hello Matt
Rib spacing is 50 mm.
Build up is about 80 g (2.8 oz) lighter than sheeted foam.
It is possibel to be more light with less ribs, balsa sheets 1,5 m (0.06 ") instead of 2 mm (0.08 ")
Claude
Old 07-08-2014, 11:11 PM
  #138
RuneG
I think 50mm spacing is ok same with 2mm ribs , if its to fragile its almost impossible to handel the plane
Old 02-09-2015, 12:02 AM
  #139
papaone
papaone's Avatar
Hello
Maiden flight for Arixtra of Jacques :
ID:	2071619   Click image for larger version
Old 07-22-2015, 12:32 AM
  #140
papaone
papaone's Avatar
Hello
Maiden flight Arixtra's Léo was made by Loic Burbaud coach of Léo.
Leo Heckmann 14 years old joined french team F3A. He will do word championship in Zurich with his Arixtra (design Pascal Nowik).
http://www.aerocompet.com/index.php?
claude
ID:	2110541   Click image for larger version
ID:	2110542   Click image for larger version
ID:	2110543   Click image for larger version
ID:	2110544   Click image for larger version
ID:	2110545   Click image for larger version
ID:	2110546   Click image for larger version
