OS 33GT Gasoline Engine for Pattern
Reply
Old 01-20-2012, 01:43 AM
  #201
bjr_93tz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: OS 33GT Gasoline Engine for Pattern
Quote:
ORIGINAL: MTK
Attempted again last night and was successful in turning the engine over with the dynatron starter and successful in starting the engine:
Hope you noted the position of the moon, so you can orientate the motor correctly for starting when you take it out to the field
Seriously, best of luck. IIRC some Austrian guy re-porting OS .61's 25+ years ago helped bring to F3A one of the finest engines ever made. Maybe OS just need another push.
bjr_93tz is offline
Old 01-20-2012, 03:25 AM
  #202
airborne2.4
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Timble,
Yep, lol. I probably will get a 30cc Breitling MXS-R from Red Aero a long time before I place an order for the GT33. If the GT33 doesn't turn out to be a winner, then I pick up a Syssa
airborne2.4 is offline
Old 01-20-2012, 06:45 AM
  #203
MTK
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: airborne2.4
Timble,
In my very limited running of the OS and extensive running of the Syssa, I can make some general statements from experience:
The SAP needs to turn fast. Don't try for less than about 8400 rpm. It requires a smaller prop to turn that fast like a 16x12 on pipe. It's a terrific sport engine but just doesn't have what we are looking for in Pattern. I think it would have been fantastic back in the heyday of the 140RX, 8 or 9 years ago since it has more raw power than the 140RX
Having said that, modifying a spark plug to accept a glow plug and running an Avgas-MeOH mix is one option I will look into. I suspect the exhaust duration is just too long but we'll see
The OS33GT on the other hand, develops it's power at lower rpm. Due to its compression ratio and Bore:Stroke ratio and timing, it can turn considerably more prop. It is better suited for Pattern needs today. I am currently turning an 18x12 in mine but I know it can turn as large as a 20x10 prop more suited for 40-45 cc engines. The 18x12 really moves my Temptress around very well, better than the 16x12 I was using on the SAP. I can state with certainty that it moves Temptress around better than my Webra 160 ever did. The verticals and diagonals are where I see a very big difference...
I am expecting that the learning curve will be tamed and I will get great runs under my belt. I also expect the engine to become a lot more user friendly as it breaks in
MTK is offline
Old 01-23-2012, 07:35 AM
  #204
DagTheElder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
MTK
Take a look
3D Hobby Shop 71 AJ SLick- OS GT 33 gas motor
Best regards
Sorry for the wrong line to link
www.youtube.com/watch?v=R8YA0bwLaBw
DagTheElder is offline
Old 01-23-2012, 08:45 AM
  #205
JRgraham
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
MTK, Thanks for sharing all this information on the GT33. It seems that OSis on the right track with petrol. (you know how americans love stuff like GT something on an engine model!!)
Maybe Ioverlooked it in here somewhere, but any idea what your sound level is... about??
Ifeel that petrol will really evolve as soon as someone designs a carburetor four our needs. Walbro is great, for sure.. but Ithink its fairly clear there is much room for improvements. (for one, they are not designed for our R/C style servo linkage.. Iknow, thats a pettycomplaint.. but still)
OSseems to be the most likely to do this, if Iwas to imagine who would first. Ithink it only makes sense.
Or am Iwrong to think that the walbro is not the most perfect carb, that needs no improvements?? It seems that is the next leap for petrol RC engines.. a carb designed for for these r/c engines.
Anyways, thanks again for the reports!
JRgraham is offline
Old 01-23-2012, 10:06 AM
  #206
TimBle
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
fuel injection is entirely possible. Even direct fuel injection is already available on outboard engines.
forced induction of sorts is also possible.
but yes I would agree that the humble petrol engine will only start to come into its own when the Walbro goes the way of the RC dinosaur.
Michael Chow at NGH has developed his own carb for his little 9cc. Perhaps if it works and works well it will be a game changer....?
TimBle is offline
Old 01-23-2012, 11:18 AM
  #207
MTK
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mel,
Sound level of the 33GT (piped, soft mounted, 2 blade 18x12 carbon-wood hybrid prop) is probably around 94-95 dB. It probably would pass the sound test. I have a 3 blader I am developing that should reduce the dB a bit... Final word not yet developed. The engine should have the guts to turn an 18x10 3 blader at useful rpm and good mid range response with this much load
Walbro is amazing for what it does but to me, needs either a mid range needle, a servo controlled low speed needle or both. Servo controlled low speed needle is not new of course and will tend to complicate things a bit but Pattern people want crisp response at any setting. That's one way to do it as my good friend Jersey Jim Martin has said time and again. That's straight forward implementation; not a difficult thing to do. I am not sure an OS developed purpose carb is a good thing unless cost could be controlled at a reasonable level. I am actually surprised their 33 is as cheap as it is
You are very welcome. We are in this together so we should help one another and learn from each other
MTK is offline
Old 01-27-2012, 05:01 PM
  #208
airborne2.4
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
So, is it to soon to say that the OS GT33 is a winner? http://www.youtube.com/watch?v=GHPK-WvNyGo
Old 02-01-2012, 10:05 AM
  #209
MTK
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I squeezed out of work yesterday and got in a little flying. Last day in Jan, 50 degrees but windy, not terrible in north Joisey for January
Used the starter on the OS and had no problems. Two solid flights some 30 minutes of flying, and a little closer to break in. I'm still using the 18x12 hybrid; even in 20 mph wind the engine pulled great. Half throttle for everything it seemed.
Have also started to finish the 18x10 3 blade. We'll see how the weather co-0perates in next couple weeks.
Edit, Feb 5:
Got 3 in this weekend....Cool conditions and a bit breezy, but I am only interested in the engine's performance, and not the flying necessarily. Flying full Masters schedules with all the vertical stuff included. But have only got 2/3rds gallon through it so far
The engine is beginning to really impress me. After the early problems, it seems that it has settled down. Starter starts are really simple
MTK is offline
Old 02-27-2012, 07:50 PM
  #210
MTK
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: MTK
Edit, Feb 5:
These terrific days keep on coming it seems. This has got to be one of the warmest, nicest winters up here in the NE in quite awhile. Every day brings us closer to spring.
Took the day off (B'day) to go out and play. Five X 15 minute solid flights. I finally got to try the 18x10 Mezjlik 3 blader and 19x11 apc which is all the rage for YS170 users. The 33GT had no problem with either prop. In fact neither prop was overloading the engine in any particular way which tells me there is still room for more load. Actually the 18x10 3 blader was a lighter load than expected and more pitch would help. Both props produced a lot more speed than I have ever had on Temptress. Both props were quieter than my 18x12 hybrid
Right now the 19x11 is the prop of choice. I will dial the engine in on this prop and fly it a few dozen times and try to tone it down a bit. The 33GT is trully impressing me with its apparent limitless appetite for big loads and its overall output
MTK is offline
Old 02-27-2012, 08:04 PM
  #211
CustomPC
CustomPC's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
How loud is it with the pipe?
My club has just introduced noise restrictions.
I was all set to put together a Giant Big Stik with GT33 but now have reservations due to the noise. If the pipe is significantly quieter i may still go ahead and build one.
CustomPC is offline
Old 02-27-2012, 08:08 PM
  #212
MTK
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My set-up is not a sport set-up. It is extremely quiet by your typical muffled glow/gas standard....... more like large 2 stroke glow set-up on pipe (Webra 160). But it takes a lot of prep to get it that quiet. A soft mount, full cowling and large, pattern props are must do's
MTK is offline
Old 02-29-2012, 02:10 AM
  #213
TimBle
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
How does the OS 33 handle the schedule?
Are you able to accelerate on a vertical line after snap?
TimBle is offline
Old 02-29-2012, 06:20 AM
  #214
airborne2.4
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Up line, down line, 45 degree line. Tumbles, rumbles, shake it and throw it at the OS GT33, looks like she can handle it lol
http://www.youtube.com/watch?v=EaYlGd4lcR8
Old 02-29-2012, 07:18 AM
  #215
MTK
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: TimBle
How many snaps on the vertical up line? Even at half throttle where I have to fly it, the model will do several snaps going up before dropping off. A blip of throttle has it back on the line, and if I go to full, she'll take off like a rocket. The plane is 11 pounds, BTW, if anyone is thinking this is a light plane.....
I am quite pleased with the piped performance, finally, after all the crap at first. To me, having played with several engines in this displacement size, up to the 40ZDZ and Mintor 38, the OS is the best of the lot by wide margin. I am buying another for a new project
MTK is offline
Old 02-29-2012, 07:22 AM
  #216
MTK
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The AW Edge is small compared to the pattern planes we fly. The OS on muffler or can works well on this smaller airframe but it can handle a bigger airframe. And if you use a pipe, holy merde!!
MTK is offline
Old 03-01-2012, 12:12 AM
  #217
TimBle
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
excellent MTK. Looks like I will opt for the OS 33GT based on your findings.
TimBle is offline
Old 03-01-2012, 06:36 AM
  #218
MTK
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: TimBle
Timble please remember that I have never used the muffler that comes with the engine. My set-ups are piped only.
I am also finishing up a 19x12 and 20x10 hybrid for this engine. I will have some info soon
MTK is offline
Old 03-01-2012, 02:28 PM
  #219
TimBle
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes I am aware that you are using a pipe. Its the way I will go as well.
TimBle is offline
Old 03-04-2012, 01:48 PM
  #220
airborne2.4
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: MTK
The OS GT33 out performs the Mintor 38?
Old 03-04-2012, 04:51 PM
  #221
choihjin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: MTK
Dear Matt;
I have not flied my Smaragd with OS GT 33 in these cold windy days. But I did another Gas/Glow converted DLE 20 on Accipiter.
It will be helpful for conversion.
It works more than I expected:
http://youtu.be/Cyquiy6UTDo
http://www.rcuniverse.com/forum/m_80...m.htm#10983505
Regards
choihjin is offline
Old 03-04-2012, 08:39 PM
  #222
MTK
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I am not surprised. Glow plugs work because of the platinum/methanol catalytic activity. I also believe that a bit more output could be had from any gas engine with a little extra oxygen in the fuel.
The most important thing for us in Pattern is getting useful mid range. If methanol gives a better responding mid range then it will be worth quite a bit to the few of us who still use wet fuels.
I finally got a few numbers using my brand new TNC tach. I checked the engine's low end, mid throttle where I fly normally, and top end. I got the following:
Low end was reliable (19x11 apc 2 blade) down to 1750; engine only has 1 gallon through it so far so this may get a little lower, but it is low enough. Sounded like a YS 170 on low throttle...very neat sound
Half throttle stick, same prop, gave me approximately 6575-6780. Temptress will do everything in Masters pattern at half throttle
Full 7450-7600 average; The tach also records the hi or peak values and at full throttle the engine would occasionally hit 7800. So full throttle gives me an average of around 800 rpm more; that's what I have in reserve. Now I know why the engine drives Temptress to ballistic speeds.
Acceleration is instant even with this large load up front but it was 41 degrees today so cooling was not a factor. I leaned the low end needle a hair and it helped a little bit. How it does in warmer weather waits to be experienced
MTK is offline
Old 03-05-2012, 08:47 PM
  #223
MTK
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey folks, just read Clarence Lee's column in MAN....He has a very short piece in there about the 33GT. He claims he got 5.4 HP out of this engine at 7000 rpm on stock muffler. If that's true, then the engine better turn a heck of a lot more prop than a 19x11.
It has to be a misprint; I think he meant 4.5 HP....I believe that's likely.
MTK is offline
Old 03-06-2012, 12:34 AM
  #224
TimBle
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
yeah 5.4hp out of a 33cc is quite a lot of stress and would make it one of the highest specific power output engines in the world at 122Kw per litre!!
That would place it in Honda NSR 250 R territory in full race tune on a pipe..........highly unlikely indeed
i vote for the misprint where 4.5bhp seems more reasonable
TimBle is offline
Old 03-06-2012, 02:45 AM
  #225
clivemc
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mattk
Thanks for sharing all your info.
I have not read all your posts, so please forgive me if I ask what has been before.
As for the mintor Vs OS compression – you cant really compare this by turning the engines over cold. Mintor have alu pistons in steel liners hence the design is such that the bore tolerances are larger to allow for the piston to swell when the engine runs and heats up. Not sure though on the OS design though. I belive that ring and ring land design can also play a part here, meaning some designs have low compression until the force of the explosion actually pushes the ring outwards against the cylinder walls. I am no expert with regard to this though.
What pipe setup incl header length are you using. Have you played with the header lengths. I have a Mintor 38cc on the test bench and brand new out the box after 10mins got 7600 rpm using a JXF / Xoar 19x8 wood prop. The JXF wood are higher load props than APC to my knowledge. This is also on the std exhaust system and not a pipe.
clivemc is offline
Reply
Display Modes
