Will YS ever go gas/petrol?
RE: Will YS ever go gas/petrol?
I said intercoolers for turbochargers, and actualy the terms are not due to the way they work, as there are turbochargers belt driven as the superchargers are also.
Turbocharge is when the pressure is increased before the air mixes with fuel, and supercharge is when the presure of the mixture is increased(after air anf fuel has been mixed), the supercharged system can not use intercoolers as the mixture is already in the engine and the mixture lowers the temperature already.
On the turbocharger the intercooler lowers the air temp to increase the air mass , thus being able to use more fuel maintaing the stoichiometric constant.
Because supercharging happens in the engine itself it is ussually shaft driven, but on the YS there is no blower, but the concept still applies and that is why is called supercharged engine on the YS. Superchargers do not use cold clean air, as by concept is only related to the fuel mixture pressure increase.
Regards
Alejandro P.
Regards
Alejandro P.
My Feedback: (8)
ORIGINAL: apereira
Regards
Alejandro P.
Regards
Alejandro P.
Supercharging just means the engine uses shaft power to compress air prior to intake; I'm sure there are many ways to accomplish this. YS uses a piston compressor rather than a rotating compressor.
Intercooling is to increase the efficiency of a multi-stage compressor, as it is harder to compress hot gases. Basically you take heat energy out of the gas so more energy (pressure) can be put back in. As on the YS, there is no need for an intercooler as it is a single-stage compressor, drawing in cool, (relatively) clean air.
Arguing about concepts is completly off topic and boring to most. Turbos are associated with centrifugal impellers, and OS had a supercharged engine which did not have an impeller, still supercharged but not turbo, my car for example has a one stage turbo but it also has an intercooler. Maybe I should have explained before turbos can only be before mixture where
supercharging can be before or after mixture, Anyway, concepts are off topic.
Regards
Alejandro P.
Regards
Alejandro P.
1 Post
ORIGINAL: DagTheElder
TimBle
A few facts may be good to understand why a small gas engine does not produce the same amout of power. Before i will try to show you some chemical facts re petrol and methanol I will stress that engines not built up as racing engines with all sort of externally remedies to enhance power output is not considered here.
The IC engines may be considered as air pumps which may be considered as how efficient they are. The fuel used, in this cases are petrol and methanol.
Petrol can burn in an engine in the ratio in this case 1:12.5 (one part fuel and 12.5 parts air). Methanol can burn at the ratio 1:4.5.
Further, one pound of petrol has the energy potential of about 19000 Btu/lb, methanol delivers around 9800Btu/lb. This means that methanol produces less than ~52% of heat energy. However, the air fuel mix ratio clearly show that (petrol 1:12.5 and methanol 1:4.5) methanol air can be burnt at 12.5 : 4.5 = 2.78 times more than petrol. If we multiply this with the energy potential of methanol at 9800Btu/lb x 2.77 = ~22246. This indicates that methanol in correct fuel air ratio will produce (22246:19000)=1.17 ie 17% more heat energy than petrol in at the correct fuel/air ratio.
With nitromethan mix in methanol the percentage difference will increase in disadvantage petrol engine.
So mine conclusion is clear, hope i contributed to yours.
Best regards
ORIGINAL: TimBle
by simply converting a glow engine to gasoline its clearly not going to produce the same power.
There are internal changes that need to be made wrt to port timing, ignition timing and also perhaps heat rejection.
MVVS only kept their crank cases when they converted their larger glows in gasoline. Ys would have similar issues but exaggerated by the 4 stroke design.
The power in the fuel is there, the design just needs to be altered to suit the fuel.
Best regards
Thanks for the snotty and unimaginative reply. I do understand the stoichiometry.
Fact remains, the power in gasoline is there, it needs an engine to exploit it. Current two stroke are not there yet. Its a design problem.
Is it worth it for YS to attempt a gasoline engine? Who knows, they are now at CDi Methanol engines. If they design a petrol powered 4 stroke it ma gain some weight but that weight will be ofset by the lower fuel mass that needs to be carried for the same flight duration.
Perhaps YS will go with electric motors in future but that would be quite sad since they've built a reputation as an engine manufacturer for the hobby. Anyone can wing an electric motor and I don't think there's much challenge in it for them. For YS a bigger challenge would a competitive petrol engine so I think they will have a go because it still allows them to maintain uniqueness in a conformist segment of the hobby.
#31
I think we all agree gasoline engines do not produce the same power a YS does in fair comparison by size and displacement. But one thing to consider is the way YS has developed their engines, and that is to be the lightest most powerful available, and the YS is on the very edge of the mechanical and efficiency design, that is why it is so critical that a defective o ring, not necesarily broken or severely damaged can cause so many headaches, high performance engines are like that, as they are designed to produce every bit of power posible.
Maybe YS could develop a gas version, but if the glow version produces more power and a lighter engine, they will continue to aim at that fuel, I don't really think they care that much for the fuel price, or maybe they do, and that's why they produced the CDI so it can work with no nitro, or up to 25%, which they reduced from 30%, so was it to lower operating cost? or is it because it really does not needs it?
It has been taking YS about two years to come with a new engine for F3A, and that only shows in my opinion the long testing and dedication to their new engines, it happened to the 170 then the 170 CDI then the 175. I think the Japanese market call their desitions(about 460 pilots in their ranking), as in the USA there are only 5 pilots at the Nats flying YS(I think), so a YS gas will be a waste of resources for them?
Has anyone thought about asking Richard Verano about a gas version? Or Yamada himself? Maybe there is an answer already and they have explored that.....
Regards
Regards
#32
Hi apereira,
Just wonder if your calorifc values is Btu/lb?
Further i think your comments are valuable for understanding why thing is as is and why its hard and costly to develop other options.
Best regards
Best regards
#33
Hello Dagtheelder,
They are in BTU/Lt I think,but As I mentioned, they are not accurate as That is what I remember from many years ago, the important thing is methanol produces less heat when burns, also Nitromethane even though is an oxidizer also contributes to lower the combustion temperature. Gasoline is much more hotter so it's difficult to control the temperature on a engine with small cooling fins, that's one of the reasons the cooling fins on most gas engines are so big and with a bigger separation between them.
Best regards
Alejandro
Best regards
Alejandro
#34
You guys are discussing from a weak position since you don't have any experimental behind you in the model scale.
Forget about turbos and any other mechanical gizmo one could add to a model engine. There are enough moving parts in a 4 stroke to fail at any inopportune time; to me it makes no sense at all for a mfr like YS or OS to put a blower on an engine (OS at least has done that but look how much they sold) to further complicate a model engine and allow more parts that could fail.
Pattern people need "simple" and easy to maintain. The vast majority of you will not take the time it will require to figure out how to run such a rig reliably. Hell you couldn't do it with simple two strokes.... If a mfr decided to build such an engine, who would buy it and at what cost? I wouldn't
The simplest route for liquid power is for a larger displacement, purpose built, LIGHT and QUIET, rear exhaust 2 stroke that uses gas with the YS fuel delivery system. We want and demand simple...this would be the simplest of the liquid burning powerplants. It may not be sexy since you won't be able to boast about your supercharger/blowerific putting 4 pounds of boost blah, blah, blah!!! But how sexy is a simple electric motor turning at 6500 rpm? Better yet, how simple is the electric?
#35
MTK,
Please read the posts again, where in my case I also said about simple to operate engines and most of your last commenta ,and talked about concepts, not putting a turbo an a model engine, as well as mentioned you are probably the one who has experimented this the most, read again please.
Alejandro
Alejandro
#36
ORIGINAL: MTK
Pattern people need ''simple'' and easy to maintain. The vast majority of you will not take the time it will require to figure out how to run such a rig reliably. Hell you couldn't do it with simple two strokes.... If a mfr decided to build such an engine, who would buy it and at what cost? I wouldn't
I think you are da....n right in your approach for an viable F3A set-up. any comparison between petrol and methanol will end in the sand. Any mods to a petrol engine can/may be done to a methanol engine. The chemical fact stands!!!!!
An other matter is if one can provide a fuel that is much richer on oxygen to run the petrol engine, but that has not been discussed in this thread. I think I will not paticipate in such chemical debate.
Matt, iam looking foreward to read about your progress with the OS.
Best regards
#37
My Feedback: (90)
What I would like to say is that gas engines are not reliable as one thought. This is from my experience with rca180, zdz40 fai, dle55, da50, da85 for both pattern and imac. Maintenance (both to the engine and airframe) is constant and too much of a headache for pattern. I have sold all my gas engines since I switched to e-power.
#38
ORIGINAL: gaRCfield
Intercooling would be for a turbocharger, not a supercharger. Turbochargers use exhaust gases to drive the compressor; superchargers use the shaft directly, thus it could utilize clean, cold air on every stroke.
#39
My Feedback: (8)
I was just trying to illustrate the point that YS engines are the most powerful glow motors for pattern primarily due to their supercharging technology. It lets a 1.10 size engine compare to a competitor's 1.50 or more. They've added this technology without external moving parts, basically by adding a simple rotary valve inside the case.
Why not do the exact same thing for gas?
I agree technical stuff can get boring for some; I'll try to keep it below and quoted for those interested in reading. But to me, the topic pretty much looks like "Will YS move their technology into gas engines?" which I think includes discussion on what that technology is, and how appropriate it might be for exploring it's options in pattern.
Bill, I figured out the intercooling thing: one of the cycles of a piston enging is indeed compression, so an intercooled 'single stage' compressor in a car would actually be intercooling between the compressor and (some point before) the compression stroke. Anyway, I agree there is only so much you can compress and heat the air before cooling is needed to maintain efficiency/effectiveness, but going back to the purpose of gas-powered pattern engines, I'm not imagining an external compressor or much more than YS is already doing in their glow engines, thus not much need for intercooling. (lol, in the time I've been working on this, just realized you could add fins to the YS air box and basically intercool! haha
If you want to get into stoichiometry, our compressors at work generally come out to a pressure ratio of 1.4 per stage (driven by length in an axial compressor). I haven't done the math on a model gas engine yet so don't know how relevant that number would be, but it's pretty easy to see that stuffing 40% more air into the engine lets you burn 40% more fuel in the same size cylinder. Just need to know the bore and stroke of an appropriate engine to figure the pressure ratio, and thus power gain from a supercharger.
Alejandro, I have to respectfully disagree on your definitions.
#40
1 Post
I agree.
The YS DZ175CDi can swing props between 19x11 and 21x10 some where between 6000rpm to 8000rpm. Its a 29cc engine (28.87cc)
So thats the target range a petrol has to aim for.
Currently the 30cc -33cc petrol's can manage 19x8 at just under 8000rpm. So those are not quite there but they don't have a forced induction system like the YS does.
So the options to increase the bhp of the petrol is to either increase the capacity or raise the BMEP through forced induction or increase the rpm.
Increasing the rpm is possible but requires moore careful design of the engine. This solution is not really good because it brings with it an increase in noise.
Increasing capacity increases weight.
So that really leaves increasing the BMEP. This really relies on different port timing, higher compression ratio's.
The 2 stroke is also a poor scavenger of exhaust gas so thats an area for improvement. Scavenging could be improved somewhat by placing the exhaust outlet in a low pressure zone under the aircraft. This is a very small win and with the HP numbers we are playing with we can assume that 5% of nothing is still nothing.
That really leaves us with raising BMEP and improved breathing and scavenging. all can be nicely achieved through the use of exhaust driven turbo chargers
#41
My Feedback: (8)
ORIGINAL: TimBle
I briefly took a look at the Saito lineup - they've got 4-stroke gas engines around the size we'd want for pattern use.
For YS to move to gas/petrol, it is not much of a leap!!
#42
1 Post
IF its a YS petrol then yes theres no much to except changes to reflect the fuel change.
For other engine manufacturers to raise BMEP they need to take hobby petrol engines seriously and not just convert glow or industrial engines for hobby use.
#43
NY
#44
Anybody,
In this thread there are many consepts to solve the petrol engines lower power compared to methanol.
One thing that puzzels me is the way the debate takes as soon some facts are brought to the table. Some consepts may charge the IC engine with a mixture that will be adequat for surpassing a twostroker in power. But, and excuse me, have the cooling of piston/cylinder been assesed? If one takes into accout that petrol has the least "Latent heat of evaporation Btu/lb @135 while methanol has 472 ". The danger is that a charged petrol engine will not be adequate air-cooled and rapidly will be destroyed. So, to increase power in a petrol engine without external remedies to increase pumping of air into the engine(silenser excluded) a long list of changes to the engine will be necessary.
It has also been mentioned that an increase of BMEP (Brake Mean Effective Pressure) may be increased. (bemp=work pr rev/volumesvept x rev.pr sec. This is also tuning of engine that can/may be done on both petrol and methanol engines. But in my view this complicates the usage of such engine. A successful tuning requires a purpose built tuned pipe.
As long as there is no fuel that has the calorific value of petrol and latent heat of evaporation as methanol, we have in my opinion two choises, listen to MTK or go tune a petrol engine.
Best wishes
Best wishes
#45
Probably a good reason the motocross engines are water cooled now using 4 valves per cylinder. For good reason motocross prefer 4 stroke water cooled engines and two strokes are not as popular. Some years ago (~2003) I saw a 4 stroke gasser in RC scale competition. It was a propotype engine and they had very hard time to get it going. Looks like that engine didn't go anywhere for RC application. Clearly, if YS wants to use gasoline fuel cooling is going to be an issue and water cooled could be the solution but it is not practical in RC application.
#46
NY
This may all be moot with the new battery technologies such as Lithium-Air promising energy densities comparabe to carbon fuels.
Imagine flying a 4kg 2-meter model with a 250-gram battery!
#47
ORIGINAL: cmoulder
Oh yeah, I have switched to electric myself. Beeing to lazy to maintain engines and planes.
Take a look! http://www.bbc.co.uk/news/science-environment-14852073
Regards
#48
ORIGINAL: cmoulder
Nah....I just like the sound of internal combustion in the morning and absolutely love tinkering.
#49
NY
Dag,
I hadn't even seen that one yet! They're coming out with new stuff at a furious pace these days.
In Norway, what is the IC:Electric ratio in Pattern?
