Aluminium bolts
Aluminium bolts
Hi,
One way to save a bit of weight is to use Aluminium bolts, nuts etc for motor mounts, landing gear attachments etc. Aluminium is way lighter than stainless steel. Titanium is extremely strong but the weight is in-between Aluminium and Stainless steel and Titanium is a lot more expensive. So from a weight perspective Aluminium is the best, but is it strong enough? Have you guys been using say 3mm Aluminium bolts for the likes of landing gear attachments and if so have you had any unexpected failures?
Regards
Clint
Regards
Clint
RE: Aluminium bolts
Hi
I have been using aluminium 4/40 bolts to mount my undercarriage for years with no failures I also use them to mount the motor where appicable again with no problems
John
John
NY
RE: Aluminium bolts
ORIGINAL: mtcarey
On the undercarriage I use Aluminium in the rear bolts an nylon in the front. They brake before the plane does.
Even if the gear break away you're going to do extensive damage to the side of the fuse where the gear insert, and potentially even more to the belly of the fuse.
I'd rather crack the landing gear than damage the fuse!
RE: Aluminium bolts
ORIGINAL: MTK
You guys still use bolts to mount your landing gear?? How...old fashioned, hehehe
RE: Aluminium bolts
ORIGINAL: bjr_93tz
My money's on pop rivets
ORIGINAL: cmoulder
Pony up! Let's see pix!!
ORIGINAL: MTK
No fasteners at all
RE: Aluminium bolts
ORIGINAL: MTK
Oh my goshki.....What's the matter with you boys? You can't think outside the box can you?
No fasteners at all
ORIGINAL: bjr_93tz
ORIGINAL: cmoulder
ORIGINAL: MTK
No fasteners at all
RE: Aluminium bolts
ORIGINAL: bjr_93tz
Hot melt glue [X(]
Hot melt glue [X(]
Now that the cat is out of the bag, you may be able to figure out the mechanics of the system I've developed. BTW - The concept is patent pending and I will be looking to license it
RE: Aluminium bolts
heres a link to aluminum fasteners made from 7075 t-6 which is about 85.000 psi tensil http://www.fastener-express.com/alum...s-washers.aspx. a alloy steel socket head cap screw manufactured to standards is about 180,000 tensil
1 Post
RE: Aluminium bolts
I've developed quite a niffty landing gear system myself. I believe in keeping parts in tension to achieve maximum strength.
Landing gear on model planes is poorly thought out
My Feedback: (90)
RE: Aluminium bolts
I thought pattern pilots will never damage the landing gears:-)
On a serious note, I like the idea of replacing four front steel motor mount mounts with itanium counterparts. Seems a good way to spend a couple dollars to cut 1oz. Of weight.
I use aluminum bolts to hold wing tip blocks to the wing body on my Passport.
BTW, I still have some spare 1" 4/40 alum socket bolts from bolts-express.com. Send me PM and I can mail you 10 for $3 shipped to cont. USA.
RE: Aluminium bolts
ORIGINAL: TimBle
RE: Aluminium bolts
ORIGINAL: TimBle
The very lightest landing gear had to be Nat Penton's. He mounted a pair of carbon tubes through the wing. The wing mounts are 1/32" ply plates, about 3 sq inches on both sides of the wing, with a through hole or socket connecting the two plates.
The carbon tube has more than enough strength and flex to handle 11 pounders. All up weight, including everything, was around 3 ozs. That's a fine weight...juuuuust a little out of the box thinking
