Radiance F3A - new pattern kit
Old 07-18-2012, 12:20 PM
  #76
Rune
Default RE: Radiance F3A - new pattern kit
hi Alex
I see that option , how thick is the sheeting off the fuse?? I know its not supplied with the kit the wing and stab I think 2mm should do the job.
How long engine is the plane designed for it should be pretty easy to modified the engine mount
Old 07-19-2012, 07:23 AM
  #77
Alex Voicu
The flat fuselage sides are covered with 3mm balsa, the curved areas with 2mm. I attached an image from the instructions manual that shows the thickness of the balsa sheets used in different areas.
For the wings you can use 2mm or 2.5mm balsa, depending on the weight and strength of the balsa sheets. Stabs should be ok even with 1.5mm balsa sheeting.
Distance between the front of the cowl and motor box is 80mm, so depending on the length of your motor, you need to use some spacers between the X mount and motor box. For example the Axi 5330 needs 6mm spacers, other motors maybe a little longer. I had 4 different motors installed in my prototype without problems: Scorpion 5525, Infinite 5030, Xpower XC6325 and now the Himax 6330-210, so i think the majority of the current backmounted outrunner motors can be used.
robin24 (04-17-2021)
Old 07-19-2012, 09:22 AM
  #78
Rune
Thanks Alex
dont really know what I will do !
But I think the Himax is a really good motor I have one 210 in my spark and it have now somthing like 200 flights my old one the 200 has after I gave it away over 600  both with no issues so I think either a new 210 or maybe a Hacker Q60 ..we have to see.
Well thanks for the answers so fare , I need some time to descide on the plane so going to Greece for a week to enjoy some that hasnt been i Norway this summer , sun and temp over 25 deegreds.
You know anything about the stock off this plane ? Its not like 2-3 months off waiting after ordering?
Old 07-19-2012, 10:51 AM
  #79
Alex Voicu
I'm really happy with the Himax 210 too. I had some problems with bad connectors causing some power issues, but it's running fine now.
Tommie has a few Radiance kits in stock, but shipping may take 10-14 working days.
Old 08-28-2012, 09:20 AM
  #80
Alex Voicu
This weekend the V1 Radiance took its first win at a local contest here in Bacau, Romania. The prototype was completed and test flown in 2010, but i wasn't able to practice regularly until august 2011. It now has over 250 flights and i think i got it pretty well trimmed out.
The weather was calm but extremely hot (41°C or 106F) so i was a little concerned about the motor and ESC temperatures. Fortunately the Himax 210 and CC80HV performed flawlessly, allowing me to fly 3 rounds of P13 without any serious mistakes.
A few pictures from the contest:
ID:	1796103   Click image for larger version
ID:	1796104   Click image for larger version
ID:	1796105   Click image for larger version
ID:	1796106   Click image for larger version
ID:	1796107   Click image for larger version
ID:	1796108   Click image for larger version
ID:	1796109   Click image for larger version
Old 11-07-2012, 04:22 PM
  #81
warrior10
The new building season special price is announced on the website: www.radiance-f3a.com
The first 2 orders even get a further $50 discount.
Tommie Prinsloo
Old 11-09-2012, 09:33 AM
  #82
Alex Voicu
I received a few images from a customer building a Radiance V4 here in Romania. Very nice work so far:
ID:	1818865   Click image for larger version
ID:	1818866   Click image for larger version
ID:	1818867   Click image for larger version
ID:	1818868   Click image for larger version
ID:	1818869   Click image for larger version
ID:	1818870   Click image for larger version
ID:	1818871   Click image for larger version
ID:	1818873   Click image for larger version
Old 11-09-2012, 09:34 AM
  #83
Alex Voicu
More images:
ID:	1818875   Click image for larger version
ID:	1818876   Click image for larger version
ID:	1818877   Click image for larger version
ID:	1818878   Click image for larger version
ID:	1818879   Click image for larger version
ID:	1818880   Click image for larger version
ID:	1818881   Click image for larger version
Old 11-21-2012, 06:37 PM
  #84
orlando16_25
hello I'm from Colombia, I want to know if there are airplanes in stock, I can buy it and send it to my country, how long it takes to get a greeting from Colombia
Old 11-21-2012, 06:47 PM
  #85
SuperViking
Me Too!
Old 11-21-2012, 09:25 PM
  #86
warrior10
Hallo Orlando and Superviking
There is still one kit on the above special price left.
There is also more kits , but on the normal price at $500.
First come, first serve
Welcome
thanks
Tommie Prinsloo
Aviaform
South Africa
Old 11-22-2012, 06:29 AM
  #87
orlando16_25
warrior10 hello I know that using courier company to send the plane and if you have tracking number of the merchandise, I buy it next week, can you tell me where I buy landing in www.f3aunlimited.com and what are the right wing tubes, greetings
Old 11-22-2012, 08:07 AM
  #88
Alex Voicu
Hello Orlando,
Tommie will reply to the questions about shipping, but i can assure you that you will receive the tracking number of the package.
Here are the carbon tubes needed:
Wing tube: PBG 107TS 1" X 30" (tube and socket)
[link]http://www.f3aunlimited.com/webstore/index.php?main_page=product_info&cPath=13_31&products_id=578[/link]
Stab tube: PBG 90TS 7/16" x 12" (tube and socket)
[link]http://www.f3aunlimited.com/webstore/index.php?main_page=product_info&cPath=13_31&products_id=81[/link]
For the landing gear you can use this (or something with similar dimensions):
[link]http://www.f3aunlimited.com/webstore/index.php?main_page=product_info&cPath=74_61&products_id=537[/link]
If you order these from F3A Unlimited you may also want to add the wing and stab incidence adjusters:
[link]http://www.f3aunlimited.com/webstore/index.php?main_page=product_info&cPath=14_67&products_id=425[/link]
[link]http://www.f3aunlimited.com/webstore/index.php?main_page=product_info&cPath=14_67&products_id=461[/link]
Old 11-22-2012, 08:14 AM
  #89
orlando16_25
Hi Alex, I think buying the plane in early December, the final cost of the plane including shipping to my country (Colombia), the value is about all, a greeting and excellent product
Old 11-22-2012, 08:37 AM
  #90
warrior10
Hi Orlando
The image from the manual shows you dimensions for the main landing gear.
I just shipped one kit this afternoon and they stated a delivery time of 5 working days, but i cant guarantee it, usually no more than 2weeks.
The price of $550 includes the shipping, you get a tracking number.
Thanks Alex, for the quick reply.
Just to mention that i am on leave from 29Nov-to 13Dec after when i will again be available.
Tommie
Old 11-23-2012, 12:55 PM
  #91
orlando16_25
hello warrior 10 great answers and very good job on that plane, I buy the kit in mid-December, maybe after the 15th of that month. I hope I explain in advance what is the procedure to proceed to buy the plane, I own a paypal account to make the transaction easy greetings from Colombia
Old 01-16-2013, 10:14 AM
  #92
Alex Voicu
More progress images from Dragos Enache building the Radiance V4 here in Romania.
Landing gear is too big and will be replaced with one of suitable size.
ID:	1841147   Click image for larger version
ID:	1841148   Click image for larger version
ID:	1841149   Click image for larger version
ID:	1841150   Click image for larger version
ID:	1841151   Click image for larger version
ID:	1841152   Click image for larger version
ID:	1841153   Click image for larger version
ID:	1841155   Click image for larger version
ID:	1841156   Click image for larger version
ID:	1841157   Click image for larger version
Old 03-09-2013, 02:58 PM
  #93
flyva
flyva's Avatar
Hello Alex
Do you have or are you working on a new Radiance front end to work with a Hacker Q80?
Old 03-09-2013, 10:58 PM
  #94
Alex Voicu
Hello,
Unfortunately the Hacker Q80 is front mounted and also has a very large diameter, which means it's very difficult (if not impossible) to design a motor box around it that would fit inside the cowl.
I think the Hacker Q60 would work fine though.
Old 03-09-2013, 11:17 PM
  #95
Alex Voicu
More pictures from Dragos Enache:
ID:	1860159   Click image for larger version
ID:	1860160   Click image for larger version
ID:	1860161   Click image for larger version
ID:	1860162   Click image for larger version
ID:	1860163   Click image for larger version
ID:	1860164   Click image for larger version
ID:	1860165   Click image for larger version
ID:	1860167   Click image for larger version
Old 03-09-2013, 11:19 PM
  #96
Alex Voicu
More:
ID:	1860169   Click image for larger version
ID:	1860170   Click image for larger version
ID:	1860171   Click image for larger version
ID:	1860172   Click image for larger version
ID:	1860173   Click image for larger version
ID:	1860174   Click image for larger version
ID:	1860175   Click image for larger version
ID:	1860177   Click image for larger version
Old 03-10-2013, 07:44 AM
  #97
flyva
flyva's Avatar
Thanks Alex for your reply.
Would you please post a 1 to 1 pdf front elevation of the main fuselage firewall, the motor mount firewall, and a side view of the two firewalls "in place" so I can play with the possibility of using something besides a rear mounted motor.
Thanks for your help.
Old 03-10-2013, 11:18 AM
  #98
Alex Voicu
I attached a PDF file showing the nose of the model in 3 views. I hope this helps.
File Type: pdf
Old 05-15-2013, 12:56 PM
  #99
Alex Voicu
A few more images from Dragos, showing the assembled model before painting and film covering:
ID:	1882221   Click image for larger version
ID:	1882222   Click image for larger version
ID:	1882223   Click image for larger version
ID:	1882224   Click image for larger version
ID:	1882225   Click image for larger version
ID:	1882226   Click image for larger version
ID:	1882227   Click image for larger version
ID:	1882229   Click image for larger version
Old 07-01-2013, 09:52 AM
  #100
Alex Voicu
Dragos finished his Radiance V4 and with only a few trimming flights on the model, took part in our pattern training camp and competition last week.
I tested the model after the contest and i can honestly say it's already flying better than my prototype, so it's nice to see that all the improvements we made for the kit version are really working.
I attached a few images of the finished model; Facebook users can find more high resolution pictures from the event in my album at the following link:
[link]https://www.facebook.com/alexandru.voicu.754/media_set?set=a.466380566779281.1073741836.1000022 20265252&type=3[/link]
ID:	1896749   Click image for larger version
ID:	1896750   Click image for larger version
ID:	1896751   Click image for larger version
ID:	1896752   Click image for larger version
ID:	1896753   Click image for larger version
ID:	1896754   Click image for larger version
ID:	1896755   Click image for larger version
ID:	1896757   Click image for larger version
ID:	1896758   Click image for larger version
