Integral Hinges
AZ
Integral Hinges
I'm weighing purchasing either a Valiant or Integral. Have some concerns over the durability of the Integral hinges. Would appreciate any comments
MI
RE: Integral Hinges
I built 3 Integrals and the hinges were fine thru thousands of flights. I'm sure the Valiant hinges are equally as good.
Verne Koester
Verne Koester
ORIGINAL: jkruger
RE: Integral Hinges
I can pretty much echo what Verne just said. Lots of Integrals around this area with no hinge failures I am aware of. My own Integral has over a thousand flights on it with no signs of any problems with the hinge areas.
Woodie
Woodie
RE: Integral Hinges
ORIGINAL: jkruger
My Spark uses the top hinge method and it works very well. One of my Sparks has well over 500 flights too.
Cheers,
Jason.
RE: Integral Hinges
ORIGINAL: Jason Arnold
I believe the Integral has the kevlar top hinge style and the Valiant has centre hinges.
Cheers,
Jason.
Cheers,
Jason.
Exactly the same like this:
http://easycomposites.co.uk/products.../peel-ply.aspx
RE: Integral Hinges
Thats a trick !!! Yes im 100% sure there is PEEL PLY.
Im preparing now all my staff for World Cup F3A in UK ( is after tomorrow but tomorrow in the morning im going to Ashford).
After comp. i will put here some very precice pics.
For me that was also shock when im finded there just... peel ply ( in Integral wing).
All hinge thats :
100 grams glass cloth/ (on top surface wing)
peel ply/
50 grams glass cloth.
I have maked few tests about peel ply and in the end i maked my own composites wings using Peel Ply. Thats works very well without any problems.
Sorry for my English
All hinge thats :
peel ply/
RE: Integral Hinges
Peel ply works fine, don't forget when you peel it out you're breaking the bond at a small area by pulling back on itself, like tearing a piece of paper.
There's no way you'd pull the peel ply out in shear, and while there is a risk that you've introduced an area for delamination to occur it's minimal because if the wing skin is peeling back on itself you've got bigger problems to deal with
